» COX .020 RC PROJECTby TD ABUSER Today at 6:04 pm
by 944_Jim Today at 6:03 pm
by getback Today at 5:25 pm
» Ode to a dead cat
by rdw777 Today at 3:28 pm
» Peewee power
by rdw777 Today at 3:04 pm
by rsv1cox Today at 8:53 am
» some pics....
» Thrust Washer
Piston resetting
Piston resetting
One of my engines has a play and I need to buy a reset tool to make it true again it but I noticed that if you want to speak with numbers it's not very easy to hold this tiny piston and measure it. Things can be very easy with a piece of fuel silicone tube and a toothpic! This way you can keep the Conrod against the piston while at the same time you can compress it with the caliper or with the micrometer. In this case play is 055mm or .021in
Gordinir8- Silver Member
Re: Piston resetting
A smart setup! I cannot measure the play though just keep knocking until there remains a hardly tangible one when you pull on the rod. I also spin the rod around to make sure it doesn't stick to the edge of the cup
Iceberg- Gold Member
.002 is the number that is usually thrown around. Enough for the oil to creep into. To be honest though it isn’t super critical. At least not in my experience. I do resets mostly for longevity and not for performance. I measure play by feel. Some are tight and some are probably just right. After being run they settle out pretty even with each other.
I like the apparatus you made to measure.
By paying subscription I guess but I am not willing to do.
Just attach the original image to this forum instead.
Are you sure? I thought that image has to be host somewhere! Gonna try it thanks.
It will technically be hosted on the forum (or another service "servim"?), and everyone will be able to se it here. Just use the "Host"-button with a tiny floppy drive disc on it.
Hi, I saved your photo and it previews fine for me with Windows Photo Viewer.
I have the Cox .049 reset tool. When I use it, I place the "cup" on a very solid surface. An anvil usually. I like to use a small hammer and tap very lightly on the tool; checking the ball/socket clearance after each tap. Being careful NOT to get heavy-handed; I rotate the tool approx. 120 degrees after each tap.. until the rod will not drop by gravity.. but will move if shaken. If your "setting" feels a little tight.. it might be fine. Some people here have mentioned that they set theirs' on the snug-side.
I'm led to understand that the ball-socket joint need only be reset "once".. as part of a break-in measure. Under normal operation, it shouldn't need resetting again and should hold it's setting due to work-hardening.
Copycat
roddie: That is exactly how I do my piston resetting. Always being sure to rotate the tool, and light to medium hits with a ball peen hammer. Anyone remember those?? My dad used those when putting rivets into sheet metal. WW2. He was a single parent before he met my mom.
Happydad
happydad- Rest In Peace
Thanks for info, this is what I have in mind also. Tool is on its way.
gasface- Moderate Poster
Tee Bee- Platinum Member
Nice looking tool , cool you can just make up one like that , see you have a piston with the oiler hole in the rod boss 3 piece .
I've found (based on others) that a smooth hard surface (glass) makes an idea anvil, also lots of light taps. set socket to rotate freely, but no real play. I'd also give it a drop of car oil prior to assembly, once its running the gap will open a little.
Cribbs74 wrote:.002 is the number that is usually thrown around. Enough for the oil to creep into. To be honest though it isn’t super critical. At least not in my experience. I do resets mostly for longevity and not for performance. I measure play by feel. Some are tight and some are probably just right. After being run they settle out pretty even with each other.
yep, about the only time it becomes an issue is high RPM and/or tight piston fit.
» Cox TeeDee .09 piston resetting tool
» Resetting Queen Bee piston?
» Cox Piston/Rod Ball Socket Resetting
» Wanted: Cox .15 piston, or piston/cylinder - FOUND!
