Prop flange removal Cox_ba12
Prop flange removal Pixel
by batjac Today at 10:05 pm
by gkamysz Today at 9:29 pm
by roddie Today at 9:22 pm
Prop flange removal Empty
Prop flange removal
Prop flange removal Empty Prop flange removal
Post  Rosco Thu Jan 16, 2020 5:15 pm
Hi, I'm wondering how to remove the prop backing plate on a Cox .049 engine without hurting anything. My first post. Rosco from N. Florida. Nice to be here. Thanks in advance!
Rosco
Rosco
Moderate Poster
Moderate Poster
Prop flange removal Empty Re: Prop flange removal
Post  944_Jim Thu Jan 16, 2020 6:02 pm
Hi,
Welcome to the best small engine forum on the planet! Oh, and we like other things that vroom, vroom, or Ding-Ding, or Eeeeow!
Remove the propeller.
Remove the tank or back plate.
Remove the cylinder and piston.
Reinstall the prop screw.
Set the block backside down on a piece of wood.
Tap the screw gently driving the crank down into the block.
Check often...continue driving the crank down as the block "drives" the prop backplate off the crank.
Alternatively, use a vise with wood between a jaw and block, and a piece of hardwood between the prop screw and block.
Use the vise to press the crank in.
Be careful not to drive the crank so hard and fast that:
You bend the prop screw
You smash the conrod pin into the block of wood backing the engine block.
I hope that helps.
Post  NEW222 Thu Jan 16, 2020 6:09 pm
First and foremost, for the love of the engine remove the piston! Don't have to ask me how I know.... Anyways, I have done this a couple of ways many times, and both with good results.
I remove the backplate, or backplate and tank assembly if so equipped first. Second, I remove both the piston and cylinder. Then I put the prop screw back in as far as it will go. Then this is where I have two choices. Then I either put the back of the crankcase down on a block of wood and give it a good, quick tap on the head of the screw. It should then seperate itself from the crankshaft. Or option 'B'. Using a small block of wood against the rear of the crankcase, put it into a vice and rest the block of wood against the jaw of the vice. Then I just simply 'press' it off using the vice while tightening.
Now for reinstallation....
Simply put the crank back into the crankcase. Grab your driveplate, a propeller, and the prop screw. Carefully line up teh splines of the crank and the driveplate. You will feel them 'index' themselves, but will not seat fully, just a tiny bit. Then screw on the propeller and tighten it up good. It will pull itself back into place as you tighten it.
Hope this helps you out some.
Post  NEW222 Thu Jan 16, 2020 6:10 pm
D'oh. Thanks Jim. You definately posted while I was typing a book about it. I like your simplified version.
Post  dckrsn Thu Jan 16, 2020 6:38 pm
We really need a good step by step video detailing
how it's done. I know we all mean well, but some
of the steps to remove the drive plate can be a little
daunting(not to menton harmful to the engine). For
example, removal of the cylinder, if you've never done
it, can turn into an ugly scene.
The best advice I can offer, Rosco, is glean as much
info, using the search feature, and use(safely) plenty
of heat. Also, chime in and keep us posted on your
progress. Hang out and ask questions as you go, and
WELCOME TO THE FORUM
Post  Kim Thu Jan 16, 2020 6:48 pm
DITTO What they said, and...
WELCOME TO THE CEF ROSCO !!!!!!!!!!!!!!!!!!
Post  944_Jim Thu Jan 16, 2020 6:48 pm
Wait until the flange has to go in...that'll be a book!
I prefer a stud all the way in the crank, and a nut to pull the prop and backplate on. If the stud gets ruined over time, toss it an get a new one.
I'd rather wreck a stud than wreck a crank. Using a short screw would only engage a few threads until the plate and crank are really coming together. Those threads in the crank can't be repaired easilly (well, you could get a new crank).
Post  Dave P. Thu Jan 16, 2020 8:53 pm
Removing the prop drive plate is easy once you get the top end off.
Follow the instructions given here.  You can get a removal tool from Cox International or EX Model Engines that's made for the task if you intend to get into the hobby more seriously.  It's nothing more than a stud with a threaded, knurled nut, but it's cheap and works well.
As Chancey (NEW222) said, to remove the drive plate you first have to remove the cylinder, piston and rod. Removing the cylinder is the tricky part and the one most likely to cause irreparable damage. You can still buy new crankshafts, drive plates and crankcases (until they're all gone too), but new-old stock cylinders, especially to replace the older ones is much more of a challenge.  Your choices are limited to the very last production types.  So don't just grab it with a pair of slip-joint pliers like I did the first couple times.  You'll really wish you hadn't.
Like Bob said, search the forum for cylinder removal and figure that out first.  There's lots of good folks that love to help here so don't hesitate to ask.
Welcome to the Forum!  Hand Shake
This Site Rocks!
Dave P.
Dave P.
Post  Rosco Sun Jan 19, 2020 10:18 am
I thank all of for your responses. I wanted to ask the pro's before I dived in. Don't want to bend anything. I acquired a red tank and flange for my p w .020 So I can pretty it up a bit. A good job for today. A cold front is coming are way (N. FL.) Going to play with my engine today. Thanks all again!
Rosco
Rosco
Moderate Poster
Moderate Poster
Post  Cox International Thu Jan 23, 2020 10:54 am
Here is a link to our online instructions, as they relate to charging a carb body on Tee Dee engines but the principle applies to some degree to reedies as well:
https://coxengines.ca/files/carb%20body.pdf
Cox International
Cox International
Official Cox Dealer
http://www.coxengines.com
Post  Mark Boesen Sun Jan 26, 2020 12:06 am
i always preferred using a vice to press the flange off, tapping with a hammer (i think) is hard on the crank. I made a small hardwood plug years ago to support the crank being pressed in, works great.
Prop flange removal Thumbn13
Post  Rosco Wed Feb 19, 2020 5:08 pm
Thanks all for the replies. I Got it apart, Went to install my red prop flange on my .020 and discovered it was for an .010. Turned out to be a learning curve! Anyway good practice. I did make some oak wood cylinder clamps For my .049 & .020 engines. I did fall victim to using the Cox wrench to removing .049 cylinder. Not a good outcome. Live and learn the hard way. All is good now. Sorry for taking so long to get back. Had a bunch of snow birds down (sunny Florida) Plus I forgot. Getting into tether cars now, Fun.
Rosco
Rosco
Moderate Poster
Moderate Poster
Post  Cox International Wed Feb 19, 2020 5:44 pm
One for regular and one for Killer Bee cranks.
Prop flange removal Drive-10
Cox International
Cox International
Official Cox Dealer
Post  Cox International Wed Feb 19, 2020 5:45 pm
Over 20,000 heads and cylinders removed and no signs of wear Smile
Prop flange removal Glow_h10
Cox International
Cox International
Official Cox Dealer
Post  Dave P. Wed Feb 19, 2020 8:22 pm
OK Bernie, tell me you have those beautiful top-end tools for sale.  I'll take one of each if you do!
I'm kind of thick sometimes, can you explain the size and purpose of the notched and machined bolts for the regular and Killer Bee cranks?
Dave P.
Dave P.
Post  Marleysky Thu Feb 20, 2020 7:41 am
Wow! Now I too want a set of Cox heavy duty tools!!  I’m still watching e bay for those tools made to remove the Venturi on the TD style engines.
I guessing those bolts are “modified” to fit the back face of the two different styles of crankshafts and pins. The flat (flush) one is for the Killer bee crank, the one with the raised crescent fits the curved space on the standard crank. Imagine pushing play dough or modeling clay inside the crankcase and making a impression of the crankshaft, then duplicate that shape on the end of the bolt.
Prop flange removal 92ab0f10
Prop flange removal B8fe4410
Post  Cox International Thu Feb 20, 2020 10:37 am
Basically a 13.5mm (0.53") bolt that was cut down to shortest length possible but still clearing the crankcase and, with a Dremel tool, a roove cut to accommodate the crankpin. Another groove cut to accommodate the shape of the crank face and left plat for Killer Bee / Venom cranks. These "tools" are to press the drive-plate back onto the crank, using a vise.
As to the cylinder / glow head tool set; they would cost around CA$ 300 / set to make and that would be our cost, not resale price. We had the set made a decade ago by a local machine shop but they would cost less if made on a CNC machine and in quantities.
Cox International
Cox International
Official Cox Dealer
Post  Marleysky Thu Feb 20, 2020 2:24 pm
Hey Now! Those are SnapOn prices!!
Was looking for more of a Tool-Time, Binford Tool price!! Arr, Arr, Arrrr.
Very Happy
Post  Dave P. Thu Feb 20, 2020 9:27 pm
So the bolt is actually used as a backing buck for pressing the drive plate with a press or vise, the threads aren't used at all.  I get it now.  I said I was a little thick sometimes.
Dave P.
Dave P.
Post  Levent Suberk Thu Feb 20, 2020 11:06 pm
Cox International wrote:As to the cylinder / glow head tool set; they would cost around CA$ 300 / set to make and that would be our cost, not resale price. We had the set made a decade ago by a local machine shop but they would cost less if made on a CNC machine and in quantities.
Bernie, how much the set would cost if made in quantities? I mean retail price.
Post  Mark Boesen Thu Feb 20, 2020 11:10 pm
Marleysky wrote:Hey Now! Those are SnapOn prices!!
Very Happy
See the wooden one i made above, its 20-25 years old and still works.
Post  Cox International Fri Feb 21, 2020 12:24 pm
Dave P. wrote:So the bolt is actually used as a backing buck for pressing the drive plate with a press or vise, the threads aren't used at all.  I get it now.  I said I was a little thick sometimes.
We just happened to find bolts with a suitable diameter and the threads have no bearing, correct. To be able to press the parts together in a vise, one needs something to push against the crank face and it has to be something that fits inside the crankcase but is as wide as possible.
Cox International
Cox International
Official Cox Dealer
Post  rsv1cox Fri Feb 21, 2020 12:26 pm
Removing the prop drive is easy and a snap, putting it back on is more difficult and cheap tools are readily available for this to get it on straight.  If reusing the same drive plate align the splines first.
It's the cylinder that presents the most problems and invites damage due to twisting (thin walls) and burrs.  Heat here helps along with a buffered Cox cylinder removal tool.
Post  Cox International Fri Feb 21, 2020 12:30 pm
No idea but a wild guesstimate would be $100 if we had 100 units made. However, there is little appetite to bankroll $5,000 for something that may or may not sell and, if it sells, may take years to sell the stock.
They are made of very expensive tool steel by hand from an old-school toolmaker.
Cox International
Cox International
Official Cox Dealer
