Button bellcrank Cox_ba12
Button bellcrank Pixel
Button bellcrank Empty
Button bellcrank
Button bellcrank Empty Button bellcrank
Post  trebor3170 Fri Sep 14, 2018 7:43 pm
Ok, so I signed up a little while ago, and have been more or less just lurking about since. It seems I can find answers to any questions I have just by doing a search. But, I have noticed mention about button bellcranks quite a few times, and I think I've figured out the basic concept, you don't use lead outs, instead, the control lines are connected directly to the bell crank with a "loop and button" arrangement. So, my question is, how do you guys go about making the "buttons" and determining the loop size on the control lines?  Huh...  Thank you in advance.
trebor3170
trebor3170
Moderate Poster
Moderate Poster
Button bellcrank Empty Re: Button bellcrank
Post  Ken Cook Sat Sep 15, 2018 5:51 am
I use button bell cranks all the time. I make my own buttons out of brass on a lathe but I used to do so by using 4-40 blind nuts turned upside down. I would chuck up the blind nut on a screw in the drill press using a jam nut against it and file off the nubs that crush into the wood. Use small screws through the bottom of the bellcrank into the upside down blind nut . Solder or use loc-tite on the assembly. Another method is to use a eyelet for your loop and use a screw and washer to hold it to the bellcrank. I can provide pictures of some if you would like for clarification. Nothing special about making the lines other than when you terminate steel lines, make a double loop when making line sets under .018" vs a single. Spectra lines only need one loop.
Post  trebor3170 Sat Sep 15, 2018 11:23 am
Thanks Ken, sounds simple enough, I guess I was over complicating things in my mind.
trebor3170
trebor3170
Moderate Poster
Moderate Poster
