by getback Today at 5:25 pm
» Ode to a dead cat
by rdw777 Today at 3:28 pm
» COX .020 RC PROJECT
by rdw777 Today at 3:21 pm
» Peewee power
by rdw777 Today at 3:04 pm
by rsv1cox Today at 8:53 am
» some pics....
» Thrust Washer
Tip: Easy assembling 5 cc tanks
Aligning 5 cc backplate screws is somewhat hard work while assembly. I have a tip for this. Buy four long 1" 8 cc tank screws and cut their heads with cutting disc. Screw them on crankcase lightly with hand and mount gasket, tank and backplate on this jig. Then unscrew one of these and screw the 5 cc tank with 3/4" screw. Then unscrew the second one, so on.
Levent Suberk- Diamond Member
Re: Tip: Easy assembling 5 cc tanks
I never found it hard.
Assemble the crankcase, set aside.
Assemble reed assembly, venturi gasket, fuel pickup, etc.
Apply aluminum safe sealant to tank groove and clean excess.
Feed bolt through one backplate hole, into tank. Install gasket. Verify alignment.
Assemble to crankcase lightly.
Install other 3 screws.
» VIDEO: Cox Sportsman .15
» Why is tee dee a better engine?
» New Quickie 100 micro pylon racer project
» More Engine Assembling/Testing. The second Tee Dee tank/mount arrives.
