by rsv1cox Today at 10:07 am
Curious Cox 350 Babe Bee
Turned down cylinder fins, high compression head, #3 grooved cylinder with throttle ring, 2 milar reeds. Made up?
Two top fins gone, nicely done probably on a lathe. Too nice to be filed.
As found, ebay $14.50 9 bids.
Cleaned up.
I thought the reed felt a little stiff, cleaned it and when I picked it up it separated into two reeds.
I tried to ID it using the Cox handbook and found two possibles.
No throttle ring.
Throttle ring.
I think it's just a 350-1 that someone had some fun with. Two reeds, some hop up/hop down mod? or more probably just stuck together when installed.
Cleaned up.
No throttle ring.
Throttle ring.
Curious Baby Bee
Nicest looking used back plate I've seen in quite a while.
Re: Curious Cox 350 Babe Bee
Well, it’s really neither of the two. It could have possibly been one of them at one time, but it’s been modified into something else. Something to clean up or use for parts or fly with without worry.
Enjoy!
Enjoy!
ticomareado wrote:Nicest looking used back plate I've seen in quite a while.
Yes, surprising considering how castor locked the reed was. I was expecting a mess when I separated the plate from the tank.
I couldn't find anything else in the book that even came close Ron.
It's a standard #3 cylinder polished for a throttle ring with a high compression head. Perhaps it was grafted on a straight nose non grooved case that at one time housed a starter spring.
I rebuilt it the same only replacing gaskets, eliminating one of the reeds, and adding a spinner.
The most curious part is the elimination of the two top cylinder fins. That's a lot of effort just to clean up some damaged fins and the result is more bad than good cooling wise.
Perhaps a home job to use on an RC boat with throttle and heat sink head?
The Stumped Mark
The Stumped Mark
batjac- Diamond Member
Strange Baby Bee
Good guess but I'd go with a heat sink head R/C car before an R/C boat on this one. A stock Baby Bee tank holds just enough fuel to get an R/C boat out in the middle of the lake and stop.
RE:Curious Cox 350 Baby Bee
Bob,
Regarding the two mylar reeds in place on the Baby Bee, a few years ago, one of the many things I acquired from the Cox R&D batch that showed up, was a Red Cox Shrike car with the Baby Bee pusher setup.
It was totally frozen solid which helped get a really good price from the guy.
Once I got it home and took it apart, it was apparent that the Shrike was a customer store return that made it all the way back to Cox.
The tank had been filled by the original purchaser and was left totally full of fuel for many years to end up as hard gel.
When I got it all apart finally, I found that there were actually two mylar reeds put in by the factory assembly person.
It would never start no matter what that caused it to end up back at the factory.
I totally cleaned it and replaced all seals, gaskets, and one reed and it is mint and never started, yet...
FWIW...Steve.....
FWIW...Steve.....
66 Malibu- Gold Member
I don't know about battery acid but i Know if you leave one in hobbys #9 for a month it will do that to it
getback wrote:I don't know about battery acid but i Know if you leave one in hobbys #9 for a month it will do that to it
The voice of experience. Same will happen with Simple Green. Looks like someone did just that, then replaced the gaskets and reed.
BOb
Curious Cox 350
Forensic guess on photo of 4 engines:
Clockwise starting at upper left-- 1) Stuka, splat in a million pieces on parking lot first attempt to fly 2) PT- 19 with plenty of flight time
3) Lil' Stinker-- busted landing gear first flight 4) PT-19 low time, probably busted a little something or another in a normal training crash on grass
ticomareado wrote:Forensic guess on photo of 4 engines:
Excellent guess.
I just cleaned the 3 .049's (A/F boil) and the upper right PT-19 shows a lot of castor goo while the .020 and bottom PT-19 are quite clean. But I can't agree on #1, a parking lot splat would have lunched that spinner.
» Mail day. 1/2A Brodak Wildcat, Junk .049's, and curious Babe Bee intake screen.
» Cox radial engine
» Just curious..Cox burned engines
» New to these engines, curious about how to tweak them and care for them!
» curious about cox engines
» Cox radial engine
