» My N-1R build logby KariFS Today at 1:56 pm
by bsadonkill Today at 11:31 am
by MauricioB Today at 10:49 am
» Octura engines?
by UncleLumpy Today at 8:16 am
» Tatone EM-7
by sosam117 Today at 7:50 am
» Honoring All Who Served
by rsv1cox Yesterday at 3:30 pm
by TD ABUSER Yesterday at 1:41 pm
by balogh Yesterday at 1:36 pm
» K&B .09 Torpedo Engine
by LooseSpinner99 Yesterday at 12:01 pm
» 3D printing of parts?
by UncleLumpy Yesterday at 9:08 am
» L4 Grasshopper
by bottomgun Yesterday at 7:58 am
K&B 3.5 question
K&B 3.5 question
I just rebuilt a K&B 3.5 engine. When I got it, turning the crankshaft was like turning a pepper mill. I replaced both ball bearings and gave it a good clean. After assembly, the crankshaft is still a bit hard to turn. This is due to a tight fit between the crankshaft and the housing. When I heat up the housing with a torch, the crankshaft turns free.
Is this tight fit normal with K&B engines?
OVERLORD- Diamond Member
Re: K&B 3.5 question
Tighten the prop really tight, whack the side of the case with a solid block of wood. Hit the case repeatedly with the block of wood offering a nice square rap on the bearing housing of the case. This will seat the bearings and all should be smooth.
Thanks for your quick reply Ken, I haven't tried that yet. I knocked the crankshaft both ways a bit but that didn't do anything, also, I thought heating the housing would set the bearings.
Is it better to remove the bearing housing from the engine when doing this?
Ken's advice is sound but 2 cautions
Some cases are easy to damage if you do not slam square! That said the K&B is pretty stout
In my case (pun) I ruined a older Fox MK VI by not hitting/slamming square on my hard wood helper trying to remove a front bearing
yes different place to slam/hit, but just the same, it is possible to damage some cases when being (Needed) Brutal
Do not do this over torque with a light old Rev up 8x8 wood prop or similar.... I did and then forgot I did
The Fox MK IV roared to life and when high rpm and the hub disintegrated.... shaft run on the bench freaked me a but as I was afraid to pinch off the fuel
Use a USED, not going to run, strong big hub like APC, prop and then consider it no good.... Well depending on what you think was deliberate over torque to help seat the bearing
I had to use a combination of over torque, heat, and smacking to seat one bugger front bearing....
Everything remains assembled, you don't take it apart. This seats the bearings. If you ever replaced U-joints on a driveshaft, it's the same procedure. You don't hit with enough force to do damage to the engine, your just shocking the case. I have replaced dozens of bearings and never had an issue.
I knocked the engine several times with the handle of a hammer all the way around and that was indeed better but still not turning smooth. I then heated the engine first and knocked it some more. That improved things but the crankshaft was still rubbing a bit on the inside of the bearing housing. I left the engine alone for a few days and this afternoon, I gave it a spin. After a few pulls, it became alive and that shook everything into place. Now the engine turns as smooth as it can be.
The head doesn't leak, the engine runs well and is a real screamer at full throttle. Due to the aluminium flywheel that gives almost no load and inertia, it was difficult to keep a reasonable idle speed with just the cable connected. I have to change my set up to keep the exhaust throttle more steady and also I have to review the cooling water bottle. I hope to make a video after the changes to add to my marine engine thread.
The heat more than likely did it some good. Running it like that which most of the time won't even allow you to flip it properly will not do it any good. They always run real smooth with new bearings. Ken
» Another Question?.
» A question
» Please, need some help to identify a Baby Bee ?
» Medallion needle
» Tee Dee .09 question
» A question
» Medallion needle
