by roddie Today at 9:22 pm
by rsv1cox Today at 3:38 pm
Rough Babe Bee with Small Diameter Cylinder & Head Assembly
I won this of eBay a little while ago (last year).
It is a little rough but it does seem like it should run. It has a single bypass small diameter Space Bug Jr. cylinder and head. As you can see, someone used a pliers to grip the head and cylinder. The head glows. It has "ok" compression, it could be worse but it could be better. I'm going to run it with the piston that is in it just to see what is gets for RPMs and then I'm going to drop a different piston in it that has a very good fit in the cylinder to see if the RPMs is any better. It has one of its filler tubes broken off but that doesn't affect anything performance wise. It appears to have a dent in the crankcase but there is no dent visible from the inside of the case. I'll try to get a video of it when I start it up sometime this weekend.
Probably overpaid a little, Babe Bees usually go for around $12, but the shipping was cheap. http://www.ebay.com/itm/150724581003?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1439.l2649
Re: Rough Babe Bee with Small Diameter Cylinder & Head Assembly
Glad to hear you got it and our suspicions were correct.
Hope it makes a good runner and can't wait for the video.
hmmm... do i see a broken off tank nipple?
GermanBeez- Platinum Member
I was looking at this on EBay, but as usual.....Quote: " Not Available to United Kingdom
See more services See shipping discounts
See all shipping details
Item location: Elk Grove, CA, United States
Ships to: United States See shipping location exclusions"
Ivanhoe- Diamond Member
Ivanhoe wrote:I was looking at this on EBay, but as usual.....Quote: " Not Available to United Kingdom
Mr. Ron Cribbs, (cribbs74) can buy the item for you, then mail it to you. A very generous offer.
Okay, I (somewhat) ran the engine today. It ran for 30 seconds or so then it slowly slowed down until it stopped. It had no compression until it cooled down (cylinder must have expanded). The engine already had a poor piston and cylinder fit, I do have a piston that fits the cylinder perfectly but I wanted to run it with the original one first. I tried to get a video of it but I stopped the video right when it was slowing down (to play with the needle) the video is only 3 seconds long, I'll rerecord it once I replace the piston and get it going again.
nitroairplane wrote:Great video Jacob
But seriously can't wait for the real deal!
I noticed that regular cylinders fit my space bug jr. Maybe that is how this one came to be.
Godsey3.0- Platinum Member
Yes we figured it was most likely the only replacement parts the user had.
I propose a "Wall of Shame" featuring pictures of abused Cox engines. The one shown would be a good candidate.
SuperDave- Rest In Peace
Godsey3.0 wrote:I noticed that regular cylinders fit my space bug jr. Maybe that is how this one came to be.
That's what I figured too. I remember reading (probably on RCU) that after Cox quit carrying the #302 heads, modelers had to replace their cylinders with ones off later engines or ones bought as parts. I also read somewhere that people sometimes find Space Bug Jrs with twin bypass normal dia. cylinders meaning someone replaced that cylinder with one from a Babe Bee sometime down the line for more power as the Space Bug Jr had a single bypass cylinder.
Mudhen- Gold Member
How well does the driveplate fit?
Could it be a little less sloppy?
nitroairplane wrote:There is already one somewhere here
OK, Indra, where is it located?
SuperDave wrote:nitroairplane wrote:There is already one somewhere here
Here ya go ~
http://coxengineforum.forumakers.com/t247-the-wall-of-shame?highlight=shame
Mudhen wrote:If it does this again with a good cylinder/piston and compression, then it means the crankshaft fit is too tight. In that case, you may have to run it rich, (and cool) for several minutes, wind it up, then quickly slow it down. Keep doing this until it won't slow down and stop.Admin wrote:...It ran for 30 seconds or so then it slowly slowed down until it stopped...
Mud
It feels as loose as my other crankcase assemblies. When I flipped it over right after it stopped, it was loose and had no compression, you could hear the cylinder leaking every time you turned it over (sounds like a loose glow head). That "loose" moment only lasted until the cylinder cooled down. I dropped a good fitting piston in it this time, see if that fixes the issue...
Mudhen- Gold Member
Admin wrote:Mudhen wrote:If it does this again with a good cylinder/piston and compression, then it means the crankshaft fit is too tight. In that case, you may have to run it rich, (and cool) for several minutes, wind it up, then quickly slow it down. Keep doing this until it won't slow down and stop.Admin wrote:...It ran for 30 seconds or so then it slowly slowed down until it stopped...
Mud
Yeah that is a bad PL fit.
IT RUNS!
» Small diameter glow head adaptor
» OK Cub head on early small thread Cox?
» Cox cylinder pre 1955 which fit small thread head
» ebay Cox Mercedes, rough.....but check out that glow head.
