» My latest doodle...by batjac Yesterday at 9:47 pm
by rdw777 Yesterday at 5:07 pm
A propeller fella........
Recently I have become fascinated by the propellers that I receive on engines and in related grab-bags. Some are really nice, but this 12" Top Flight was particularly grungy.
Using the least invasive method I first tried formula 409 and a kitchen pot scrubber. As expected not much progress.
So giving up on saving the Top Flight logo I threw caution to the wind and hit it with a cutting oil and fine steel wool, better but not good so I graduated to used 400 grit wet/dry and cutting oil. Progress. I finished with more fine wool and Howard Feed-N-Wax.
I wanted to mount it on one of my .60 Enyas, but Enya insists on using 7mm prop shafts on .60's and the propeller had a 6mm hole so I put in on an OS Max .60 which uses a 6mm shaft.
Big fellas, little fellers...........
Much ado about very little, but I think it looks nice as a display and would probably be able to use.
Re: A propeller fella........
Prop turned out lovely Bob, well done thank you for sharing your tricks to
get the prop dolled up!
Those do indeed look very nice. If I see correctly, they are mounted on a kitchen counter? Great way to shred veggies and or mix dip and drinks quickly and efficiently if I do say so....
rsv1cox wrote:Thanks guys. Almost forgot about this one.
I still have plans to make one of my own. I think I can carve a reasonable example out of a clear white pine 2X6.
Now that sir is a real beauty!
I need a nice big wooden prop around here too. Might look good over the fireplace.
pkrankow wrote:I need a nice big wooden prop around here too. Might look good over the fireplace.
Or in the fireplace Phil, especially this time of the year in Ohio.
» Wallpaper images
» Cox Pee Wee .020 ...Which propeller do you use?
» Veco/Dumas "The Little Tom Tom"...65° and the Dope is Flying
» Which propeller ??
» The OK Cub .060/.059
