» Tee Dee .020 combat modelby rdw777 Today at 5:07 pm
by rdw777 Today at 4:51 pm
by getback Today at 12:05 pm
Vintage O&R fuel tank
Multiple mounting systems. Looks to be about 3-4 ounces and purpose built. Any info on these?
Re: Vintage O&R fuel tank
Those tanks were used on the early O&R engines that did not have beam mounts. Those type engines were normally radial mounted to a firewall.
gcb- Platinum Member
Thanks George. So the tapped holes will accommodate the engines while the other untapped holes attach to the firewall.
I have a couple of old O&R's around someplace, I will have to dig them out and see if they fit.
rsv1cox wrote:Thanks George. So the tapped holes will accommodate the engines while the other untapped holes attach to the firewall.
My GUESS is that engines with or without the beam mounts will fit. Not sure how many crankcases used the same hole spacing, nor whether the side-port spacing is the same as the front intake. My knowledge of O&R is mostly from what I've read. The only one of that size that I have owned was a front intake glow .23...many years ago. I would guess that they made more than one size tank because they made engines from .19 to .60.
Note that the tank has provisions for either an upright or inverted engine, and yes the untapped end is for radial mounting. The tank can also be beam mounted. Note that there is no venting except the small hole in the fill cap so the tank must be mounted with the fill cap up.
Let us know how they fit.
While not exactly relative to this post, the bolt pattern of a Fox .35 is identical to the O&R. Just an interesting tid bit of info. Duke did this so that you bought his engines which pretty much blew away the competition of the time. Good planning as he offered a 7 oz. engine, no more batteries, points etc.
Here is one mounted on a 60
http://www.ebay.com/itm/182422171817?_trksid=p2055119.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
crankbndr- Top Poster
Thanks CB, a picture is worth a 1000. Guess I will have to watch that one.
» Vintage pneumatic Fuel cut off engine timer
» fuel tank ?
» WTB: RR-1 Fuel Tank
» Fuel Tank
» COX 049 Fuel Tank
» fuel tank ?
» Fuel Tank
» COX 049 Fuel Tank
