by getback Today at 5:25 pm
» Ode to a dead cat
by rdw777 Today at 3:28 pm
» COX .020 RC PROJECT
by rdw777 Today at 3:21 pm
» Peewee power
by rdw777 Today at 3:04 pm
by rsv1cox Today at 8:53 am
» some pics....
» Thrust Washer
Wild Hair JOE (Ken Willard) Pee wee powered
Hi friends, this winter I´m a little lazy but I need built some model.
Free flight 1/4 A model airplane will be good option
And I think that spanish Wild Man must built the Wild Hair Joe.
Has anyone built it? Not seem very dificult ... How many days will it take to do this?
Nevertheless the master designer Ken Willard is the best guarantee.
II´m sure that I will not forget to turn on the receiver ..... I hope not to lose the Pee wee
Regards
JMCalata
Regards
JMCalata
Re: Wild Hair JOE (Ken Willard) Pee wee powered
Jose,
It doesn't need a receiver - it's a free flighter!
Is it finished yet? A slabby sided, slabby winged plane like this could be finished in an hour
RCing this could add a little too much weight.
Please post the build.
Hi Ian, I imagine that when you say "slabby" you can say boards .. ok? or woody plane? ... well.
Yes ... I can build faster but don´t be impatient Ian, I prefer build slow to enjoy more time.
I´m thinking to ing one channel RC, I fligh over railways, trees, river, road, there are many dangers for free flying.
The Wild Hair Joe plan appears at sixties in Flaps magazine, the most popular aeronautic and model press.
Here explain how build.
Here shown wing platform detail.
HI Jose , i looked over the plans and it doesn't say how many ribs to cut and install ? I read the english version couldn't get the translator to do the spanish version so i could read . Looks like a fun little build , you going with the .035 K&B to pull the extra weight ?
Eric, I think it's as simple as on the drawings: 1 rib at wing root and 1 more at 2/3 of the wing.
José, Good luck with the build. Looking forward to see it flying!!
OVERLORD- Diamond Member
Hi, yes there is a simple construction system like jedelsky profiles.
One rib at root and other a 2/3 span, but I add one more at 1/3 span and I will make the root rib extra thick.
About engines I have three vintage K&B size but I think COX Pee wee has eneogh thrust for small Joe.
However I scale up plans 10 % because I don´t like fly bullets.
See the bigger Skyrida Pee wee powered.
By the WAY anybody want to follow me building another vintage slabby or ebenezer 1952 ( 65 years old)
getback wrote:HI Jose , i looked over the plans and it doesn't say how many ribs to cut and install ? I read the english version couldn't get the translator to do the spanish version so i could read . Looks like a fun little build , you going with the .035 K&B to pull the extra weight ?
Eric, you might check out the plans from Outerzone. In English and will print out full size:
http://www.outerzone.co.uk/plan_details.asp?ID=2031
The Referent Mark
batjac- Diamond Member
That's a lovely plane you have there. Great job with the doped colors. Nice and bright. It flies nice and docile with the PeeWee and oversized prop. What size prop is that? I've admired the Skyrida, but couldn't see when I'd get to building one. Well done!
And, Yes! We always want to see another vintage build thread!
The Envious Mark
Flying over railway, trees and river.. Where do you land Joe? Maybe add one more RC channel.. Nice Winter project! I love to build.. I understand you're wanting to take your time with the model. Relaxing with it is good. I'm relaxing a little too much lately..
The Skyrida Pee Wee flies great , Overloard i just now seen the last pic it dint' pick up earlier and see now where the ribs are , Thanks though. The Pee Wee will do it i am sure Jose , just wondering if you would go with the original in the pic. I may take you up on the winter build i have alot on my plate right now but need some FUN!!!! Copy paste Let me ck out Outterzone thanks Mark!
Hi guys, I have started project ... anybody follow me?
The motor plate mount is a wood circle rest that drills bigs holes
Is a lot oo fun build small models ... you can relax so much and enjoy with them
A 1952 model neede vintage colours painting ... maybe varnish and some black details.
About Skyrida I use normally 5x3" prop at Pee wee but I use 6x3" also as you can see here.
jmcalata wrote:Hi guys, I have started project ... anybody follow me?
Hola José como estas?, veo que tienes un nuevo proyecto en curso!, sigo tus avances! .....(a propósito, pudiste hacer el aro acelerador del acelerador del Pee Wee? Saludos!!!!
Hi Jose, how are you? I see you have a new project underway! I follow your progress! ..... (by the way, could you make the accelerator ring of the Pee Wee accelerator? Regards!!!!
MauricioB- Top Poster
You're getting along well. What a good idea to use a hole saw for making the motor mount. That shape goes well with a Pee Wee or Babe Bee tank. I use children's puzzle parts for motor mounts. The plywood has very fine layers.
I always protect the surface with a piece of Oracover against fuel ingress. Oracover when sanded can be painted in any colour you want!
Keep up the good work
Lieven
Lieven
No Mauricio, I dont made ring ... maybe later ... next year
At hole saw wood mount se add two slots V for landing gear wire
And a big groove rear for fue assembly
Looking Good Jose , you are getting on with the project , How much did you scale up the plans ? If i can get to one it will have to bee early this coming year !
I scaled about 110% for Pee wee .020
Win span is 440 mm
Win span is 440 mm
Looking good Jose, I am following this I am curious to see how you are going to protect the radio stuff from castor goo, as I am also interested in a simple "radio assisted" free flight model.
I also like your engine mount idea. strong, simple, and acts as ballast too.
Oh is true the center hole can be put ballast ... but I check cdg 50 % and need ballast rear at tail
1/16" (1,58 mm) balsa is very thin for stab and wing sheet, I use 2 mm
I have made the rudder down because is more easy mount the wire servo for control.
Two small papel tissue hinges inserted
Looks very nice. The hole saw idea is awesome. Never thought of that.
OVERLORD wrote:You're getting along well. What a good idea to use a hole saw for making the motor mount. That shape goes well with a Pee Wee or Babe Bee tank. I use children's puzzle parts for motor mounts. The plywood has very fine layers.
Lieven
Another great idea. Would be good to post this in the 'Cheapskates' topic in the other forum. I like it!
The 'Cheapskates' topic I was referring to is actually called 'repurposing/recycling items for hobby-use'. My bad, but I do like the sound 'cheapskate'! Anyways, I think it would be a great share on that topic, but did not want to take your work and discovery away from you, so if you were interested in sharing it there, here is the link. Thanks again for sharing.
https://www.coxengineforum.com/t10328-repurposing-recycling-items-for-hobby-use
Kari the best way to insulate the equipment from the oil is to put it inside the fuselage 3/16" wide but for that you have to be a good surgeon
» CEF speed contest Design Discussions (2014)
» Ken Willard's .010-.020 "Pool Boy"
» Fall SMALL -- Oct. 11-14, 2018 (Thr-Sun)--Mayflower, Arkansas
» It is not a hair dryer !!
» hair-pin needle-clip-DIY
