» music vids.. some of your favoritesby 1/2A Nut Yesterday at 11:26 pm
by roddie Yesterday at 11:01 pm
by davidll1984 Yesterday at 8:49 pm
» Green vent..
by roddie Yesterday at 7:49 pm
by rsv1cox Yesterday at 6:59 pm
by Cox International Yesterday at 4:33 pm
» PSA propellors!!!
by robot797 Yesterday at 2:39 pm
by roddie Yesterday at 11:42 am
by roddie Yesterday at 10:51 am
by davidll1984 Wed Oct 16, 2024 6:15 pm
» OK Cub .024
by 049kid Wed Oct 16, 2024 12:31 pm
flat framed construction
Page 2 of 2
Page 2 of 2 • 1, 2
thread-bump for Bernie
Hey ya'll. I hope some of you had a chance to go-over this thread. Bernie (Cox International) is willing to publish this concept in their quarterly e-magazine.
Richard (RKflyer) applied the concept.. to a couple of builds in this thread. I think you'd agree that they look great!
Just another point to make.. There are lots of sheet-wing (flat-wing..) 1/2A (as well as 1/4A..) airplane designs out there to build. Framing that wing can save on balsa. It also affords the application of a spar. Multiple clean-fitting frame pieces, make a flat-wing (frame) less-resistant to warping.. because of multiple grain-direction between the pieces. My flat-wing panels were all covered with TF Mono-Kote.. which is still drum-tight after 25 years. I can't speak for other covering-methods. This construction-method wouldn't warrant a doped rubbed-out finish any more than any little solid sheet-wing build would. It does provide for a different-approach to just butting two sheets of balsa together.. and trimming the perimeter to form the wing-profile. I installed a 1/8" x 1/2" stub-spar made from dark hardwood (walnut possibly) in my Rare Bear's wing. It was basically the leading-edge of the wing. I needed a scale/wing-mounted landing gear. This required making separate right and left gear-blocks.. also from hardwood.
The blocks were mounted to the bottom of that hardwood spar, to absorb the shock of a hard landing. I used to have a "one-method" approach to attaching 1/2A landing-gear. It was a single inverted "V-bent" music-wire gear, running-through the front of the wing-slot in the fuse.. and anchored by straps with screws through the ply fuse-doublers. That's the age-old approach to gear-installation on a c/l profile model.. that has gear. Plenty of flyers don't want landing-gear on their model. That's fine. A hard strip-wood spar in their wing will provide rigidity.. and could also serve as the ultimate bellcrank-mount.
Re: flat framed construction
You may discover you can actually make rolling landings without the usual 1/2A nose-over if the grass is reasonably smooth. I'll be interested to see how that works.
RknRusty wrote:You may discover you can actually make rolling landings without the usual 1/2A nose-over if the grass is reasonably smooth. I'll be interested to see how that works.
What...and abandon the traditional "bounce 'n flip" landings made famous by "hollow logs" being flown over grass?
gcb- Platinum Member
Page 2 of 2 • 1, 2
» *SOLD* Walt Musciano Scientific "Red Tiger P-40" kit
» Space Bug Jr. box construction
» tank construction
» slab-wing/built-up construction
» Ring Master Gold KIt
» tank construction
Page 2 of 2
