TeeDee09-Enya09-OS.10FSR & P-51 (Video restoration) Pag2. Cox_ba12
TeeDee09-Enya09-OS.10FSR & P-51 (Video restoration) Pag2. Pixel
TeeDee09-Enya09-OS.10FSR & P-51 (Video restoration) Pag2. Empty
TeeDee09-Enya09-OS.10FSR & P-51 (Video restoration) Pag2. Empty TeeDee09-Enya09-OS.10FSR & P-51 (Video restoration) Pag2.
Post  MauricioB Tue Aug 23, 2016 4:36 pm
Hello everyone... Very Happy
Which considers it more powerful?
Thank you...
TeeDee09-Enya09-OS.10FSR & P-51 (Video restoration) Pag2. Foto0840
TeeDee09-Enya09-OS.10FSR & P-51 (Video restoration) Pag2. Empty Re: TeeDee09-Enya09-OS.10FSR & P-51 (Video restoration) Pag2.
Post  balogh Tue Aug 23, 2016 5:27 pm
If I look at the test performance curves I see the COX TD09 is more than 2x as powerful as the Enya.
http://www.sceptreflight.com/Model Engine Tests/
Post  1/2A Nut Tue Aug 23, 2016 7:16 pm
I have some TD .09 data to share:
Published on Jul 2, 2016
Best level pass 143mph / per prop calc / 5.25x6.25E
Wavescope: 232.07 kmh / 144.2mph /down wind / Best unloaded 24,100 rpm
The reading was taken at 1.52mins into the vid.
Static 16,975 rpm at launch
Static: 13.8 oz thrust with speed prop
Temp 96F / 30% nitro
Recommend 7x3 for good thrust.
6.5x4 good sport prop option
Post  MauricioB Tue Aug 23, 2016 10:16 pm
1/2A Nut wrote:I have some TD .09 data to share:
HEAVENS!! Shocked
Post  MauricioB Tue Aug 23, 2016 10:17 pm
balogh wrote:If I look at the test performance curves I see the COX TD09 is more than 2x as powerful as the Enya.
Hi, thanks for the information, so your comment, to see if I understand correctly, you say:
according to the Cox Tee Dee curves 09 it is twice as potent as Enya?
Post  RknRusty Tue Aug 23, 2016 11:18 pm
That's what he said. I've heard that the TD .09 is surprisingly powerful for its size.
Post  Surfer_kris Wed Aug 24, 2016 1:44 am
It is not a fair comparison though, it also depends on what you are after...
The TD is all about maximum power, no throttle, no muffler, large venturi (needs pressure) etc. Much more like a combat .09 engine, but there the technology has now gone much further with the Profi and Fora engines.
The Enya will pull larger props, be more quite, easier to handle etc. More like the Cox .09 Medallion with the throttle option.
In terms of outright power the Enya will be pretty close of you make the comparable mods. No muffler a larger CL venturi etc. and the power will be comparable. In fact the CL Enya used to come with an intake restrictor that one could easily remove and just leave the muffler off.
Surfer_kris
Surfer_kris
Post  balogh Wed Aug 24, 2016 2:22 am
The unmuffled maximum performance of the ENYA 09 is 0,115 BHP  as per the link below:
http://www.sceptreflight.net/Model%20Engine%20Tests/Enya%2009-II%20(1).html
There is another test here that puts the output max to 0,175 BHP...
http://www.sceptreflight.net/Model%20Engine%20Tests/Enya%2009-II%20(2).html
The unmuffled output of the COX TD09 is 0,28 BHP
http://www.sceptreflight.net/Model%20Engine%20Tests/Cox%20Tee%20Dee%2009.html
This is still a 60% advantage for the COX even if we take the second ENYA 09 test results.
This is all I wanted to say...Reddies are welcome if I am seen too subjective but numbers like above talk for themselves...
Post  Surfer_kris Wed Aug 24, 2016 3:33 am
Those tests are for the older Enya .09 II, there are two more test at the same site for the Enya III model; Enya .09 III CL and here Enya .09 III CL&RC
Those show a power of about .24hp, with the larger venturi (still on suction) and similar fuel to the TD test.
The engine asked about in this thread is the later, ball bearing, Enya .09 IV. I have not seen any testnumbers for it, but I have a few of them myself. The stock RC version will spin a 7x4prop at around 14500rpm on 10% nitro, and provides a very nice handling engine, much more suitable for regular sports flying on larger props.
If outright power is the only thing needed, then the Enya will get there too, with easily reversible changes. Smile
Surfer_kris
Surfer_kris
Post  RknRusty Wed Aug 24, 2016 3:58 am
Hi, Andras. I clicked the greenie. I wouldn't give reds for thoughtful posts where the poster believes it to be useful information. I don't liberally apply either one, usually just greens to encourage useful intent... or fun, this case being the former.
Post  Surfer_kris Wed Aug 24, 2016 4:21 am
Reddies? Never heard of it...
I though it was meant to say "Reedies"... Babe Bee .049
Surfer_kris
Surfer_kris
Post  RknRusty Wed Aug 24, 2016 4:57 am
Surfer_kris wrote:Reddies? Never heard of it...
It doesn't roll off the virtual tongue as well as "Greenie" does. Referring to the green or red bar appearing in a post when someone clicks the small - and + buttons. As in your first post in this thread,
Post  balogh Wed Aug 24, 2016 5:42 am
Thanks Rusty for a fair approach, sometimes I feel I am too adamantly defending COX engines against any other brand (Norvels in the first place.... Very Happy no I would rather not be provocative) and this may blow the fuse in some of you guys.......and sorry for my Hunglish, I just flipped the "greenie" to the opposite and arrived at "reddie"
Post  Surfer_kris Wed Aug 24, 2016 6:08 am
I guess no-one on a cox forum will ever object to defending cox engines, but it is always good to be fair. If you read through the engines tests, you'll find that the Enya III and IV models have no common parts with the earlier Enya II. Chinn also states that up to 14000rpm the Enya III is in fact stronger than the cox .09TD, which then comes out ahead at higher revs. The Enya .09 had the highest torque ever measured by a .09 engine at the time....
So to answer the original question, it is all matter of the intended use, each engine has its own merits.
Surfer_kris
Surfer_kris
Post  MauricioB Wed Aug 24, 2016 9:46 am
Thanks for the information herein provided.
I comment to you; long, buy this model to a Mr. that he had given to his nephews, but the nephews were 4 and 5 years old, so playing with the model as if it were just a toy, so to that does not end completely destroyed decided to sell it. It was so I decided to buy it to restore the model never assembled to fly, but just by the play of children, has some nicks and scratches that decided to repair and return it to its original condition, build it and fly it.
I'm at the stage of restoration, and just have the availability of two engines, Enya 09 version IV and Cox Tee Dee 09 with ring speed control, which is why the consult you, because I like the Cox, but it is possible that this model best suits the Enya. You can not say that ...???
TeeDee09-Enya09-OS.10FSR & P-51 (Video restoration) Pag2. Foto0842
TeeDee09-Enya09-OS.10FSR & P-51 (Video restoration) Pag2. Foto0841
TeeDee09-Enya09-OS.10FSR & P-51 (Video restoration) Pag2. Foto0843
TeeDee09-Enya09-OS.10FSR & P-51 (Video restoration) Pag2. Foto0844
TeeDee09-Enya09-OS.10FSR & P-51 (Video restoration) Pag2. Foto0845
TeeDee09-Enya09-OS.10FSR & P-51 (Video restoration) Pag2. Foto0847
TeeDee09-Enya09-OS.10FSR & P-51 (Video restoration) Pag2. Foto0848
Post  MauricioB Wed Aug 24, 2016 9:49 am
so it is becoming work:
TeeDee09-Enya09-OS.10FSR & P-51 (Video restoration) Pag2. Foto0849
Post  1/2A Nut Wed Aug 24, 2016 10:21 am
Looks much better now!!
These engines can be found on ebay all the time.
AP .09 Hornet static tests.
MA 5.5x4.5 19,300 / .92lbs thrust / 82mph /.20hp
APC 6.3x4 / 17,280 / 1.3lbs thrust / 66 mph / .22hp
Tuned Pipe /APC 4.75x5.5 / 22.24k / 116mph
TT GP .10 static tests
APC 6.5x3.7 / 19,460 / .28hp / 2.2lbs thrust / 68 mph
5.2x6N 19,380 rpm / 110 mph with 1.5cc Utkam Tuned Pipe
171w / .229hp / 12.6oz thrust
Sirio .09
APC 4.2x4 / 26,990 rpm / 102 mph / 1.5cc tuned pipe
APC 5x5 should be a good prop to fly with.
Post  Surfer_kris Wed Aug 24, 2016 12:53 pm
That is an easy choice then, just go with the Enya and a 7x4-7x5 prop, use plenty of castor in the fuel (20-25%) and 5-10% nitro. Smile
Surfer_kris
Surfer_kris
Post  MauricioB Wed Aug 24, 2016 3:20 pm
Surfer_kris wrote:That is an easy choice then, just go with the Enya and a 7x4-7x5 prop, use plenty of castor in the fuel (20-25%) and 5-10% nitro. Smile
Okay, thanks for helping me decide for one or the other motor (both options are available to me and wanted to use one of them). Then I will install the Enya 09 rc.
Thanks to everyone else for work each time I need! Thumbs Up
I will please ask the site administrator to move this topic to Non-Cox Engines.
Thank you! M.
Post  Mark Boesen Wed Aug 24, 2016 10:48 pm
TeeDee09-Enya09-OS.10FSR & P-51 (Video restoration) Pag2. Sterli10
Post  MauricioB Thu Aug 25, 2016 6:21 am
Mark Boesen wrote:TeeDee09-Enya09-OS.10FSR & P-51 (Video restoration) Pag2. Sterli10
Beautiful model !, thanks for sharing!,Mauricio.
Post  MauricioB Thu Aug 25, 2016 6:24 am
and according to the experience that can have you, which of these two is more powerful:
OS. FSR .10 0r Enya 09 IV ??
TeeDee09-Enya09-OS.10FSR & P-51 (Video restoration) Pag2. Foto0850
Post  Surfer_kris Thu Aug 25, 2016 7:14 am
In their stock version they are very similar on low nitro fuel (5-10%).
The FSR has a rather low compression ratio and benefits from a higher nitro levels or a raised compression level. If you have a lathe you can remove about 0.10-0.15mm from the head and improve the power considerably. On a 7x4 prop and 10% nitro the stock FSR will make around 14800rpm, while with a higher compression ratio it will do about 15300rpm.
The FSR is a slightly nicer engine, in my opinion, it runs a little smoother as is it a modern schneurle ported engine (iron/steel construction).
Surfer_kris
Surfer_kris
Post  MauricioB Thu Aug 25, 2016 11:21 am
so we continue..
TeeDee09-Enya09-OS.10FSR & P-51 (Video restoration) Pag2. Foto0851
TeeDee09-Enya09-OS.10FSR & P-51 (Video restoration) Pag2. Foto0910
TeeDee09-Enya09-OS.10FSR & P-51 (Video restoration) Pag2. Foto0911
TeeDee09-Enya09-OS.10FSR & P-51 (Video restoration) Pag2. Foto0912
TeeDee09-Enya09-OS.10FSR & P-51 (Video restoration) Pag2. Foto0913
TeeDee09-Enya09-OS.10FSR & P-51 (Video restoration) Pag2. Foto0914
TeeDee09-Enya09-OS.10FSR & P-51 (Video restoration) Pag2. Foto0915
Post  getback Fri Aug 26, 2016 8:29 am
Looking good !! is that monokote your using ? You will surly bring it back to life with your skills in building .
