Cox .09 glow plug ? Cox_ba12
Cox .09 glow plug ? Pixel
Cox .09 glow plug ? Empty
Cox .09 glow plug ?
Cox .09 glow plug ? Empty Cox .09 glow plug ?
Post  oldguy Tue Feb 23, 2016 2:47 pm
Is this a better way to go with glow plugs for the .09 medallion? Or just use the standard cox plug?I need a plug for my .09 medallion.
http://www.ebay.com/itm/GLOW-PLUG-ADAPTOR-COX-09-engine-use-standard-long-plug-MADE-in-USA-911-009-/281012094238?hash=item416da0451e:g:0B8AAOxyV85R0PIY
oldguy
oldguy
Cox .09 glow plug ? Empty Re: Cox .09 glow plug ?
Post  Cribbs74 Tue Feb 23, 2016 4:28 pm
Jim,
If you plan on doing a lot of flying it's not a bad idea. .09 heads are a little harder to find than .049's so it would pay off in the long run. It also allows you to use a standard ignitor.
You will loose a bit of compression over the standard head, but you could always sand down the head a little to build it back up of needed.
Post  JPvelo Wed Feb 24, 2016 6:15 am
I like this option, the Nelson plugs last forever and there is no loss of compression.
http://www.flyfreeflight.com/Site/Modified_Glow_Heads.html
JPvelo
JPvelo
Post  oldguy Wed Feb 24, 2016 11:43 am
JPvelo wrote:I like this option, the Nelson plugs last forever and there is no loss of compression.
So basicly drill and tap and original bad plug.What thread is used on the small standard plug?
oldguy
oldguy
Post  fredvon4 Wed Feb 24, 2016 12:37 pm
Need a good way to hold the glow head
A Used cylinder works in a v grove section of a vise
First punch out he glow filament and center post from the inside out the top of the glow head
Next from the outside top you use a 7/32 drill and there are arguments about all the way through or just enough deep for the standard glow plug with one or more copper gaskets to fit...this method requires a BOTTOMING 1/4-32 tap
Drilling all the way through with the 7/32 lets you use any 1/4-32 tap
even though this is soft aluminum you need to go slow taping with light oil and frequent cleaning of the flutes by backing out 1/4 turn before then next turn in cutting
If the is just a sport .09 this is a cheap method but like others have said...the adapters that are out there are set for TURBO plugs or Nelson plugs and either is a good investment as they add RPM and in the case of the Nelson plugs the plug is relatively cheap at $5 most sources
Look up Nelson plugs and you should see why they seal the chamber better
Car guys use TURBO plugs...same idea but different method and shapes and the plugs are outrageously priced...IMO
Post  oldguy Wed Feb 24, 2016 3:26 pm
fredvon4 wrote:Need a good way to hold the glow head
thanks fred.
oldguy
oldguy
