Winging it - Page 2 Cox_ba12
Winging it - Page 2 Pixel
Winging it - Page 2 Empty
Winging it
Page 2 of 2 Previous  1, 2
Winging it - Page 2 Empty Winging it
Post  VUgearhead Thu Feb 11, 2016 2:33 pm
Why don't you just make the LO guide removable with a couple of screws? (
Assuming you aren't running the LO's inside the wing)
Unscrew the LO guide, wing is ready to depart!
VUgearhead
VUgearhead
Winging it - Page 2 Empty Re: Winging it
Post  pkrankow Thu Feb 11, 2016 3:03 pm
rsv1cox wrote:I think I can visulaize your meaning Phil, but a picture is worth a thousand words. Smile
It seems like I still would have wires sticking out of the fuselage.  I'm thinking a couple of 2/56 clevises similar to the one I used (first picture above) for the elevator control then just unscrewing and removing the rods when I'm finished flying.  But I'm worried about the rods unscrewing in flight.
Here's one version of the second idea much better DONE than I could probably draw.
http://stunthanger.com/smf/building-techniques/build-cartoon-scale-mooney-mite/msg435630/#msg435630
Here's a slightly different version of my first idea.
http://stunthanger.com/smf/scale-models/leadout-guide-how-to/
Post  rsv1cox Thu Feb 11, 2016 3:36 pm
Thanks Phil, I like it. Makes the lower wing detachable and leaves just a couple of short lead-outs. I robbed his picture.
Winging it - Page 2 Lead_o10
My idea is to use threaded 2/56 rods and cleavis's then just unscrew and remove the rods and the wing when I'm finished flying. But they would be heavy and create even more drag on this already draggy model. I haven't glued in the wing tip guide yet, or located the eyelets on the fuselage.
Winging it - Page 2 Aircra22
Winging it - Page 2 Aircra23
Post  getback Fri Feb 12, 2016 9:34 am
Bob its looking good , rebuilding can be challenging for sure I got an ole Shoestring I need to do something with sometime or put It upstairs so I cant see it as often :lol Are you going to leave the control on the BC in that outer hole ? I think that's were I had mine on the Reed speed and was for Max throw? Did you give up on trying to find a pulse system/ I know you were looking at one time , they are $$ when ya find a good one !! Eric RC Plane
Post  rsv1cox Sat Feb 13, 2016 7:24 am
getback wrote:Bob its looking good , rebuilding can be challenging for sure I got an ole Shoestring I need to do something with sometime or put It upstairs so I cant see it as often :lol Are you going to leave the control on the BC in that outer hole ? I think that's were I had mine on the Reed speed and was for Max throw? Did you give up on trying to find a pulse system/ I know you were looking at one time , they are $$ when ya find a good one !! Eric RC Plane
Challenging and fun Eric. I'm enjoying bringing this old timer back to life. I figure someone built it aound the time you were just a pup. Smile
I finally sanded the front cover to shape. I made it detachable so I can get to the front half of the bell crank if needed.
Winging it - Page 2 Aircra24
I have the clevis in the outer hole until I see how well it flys. I figure I may need a good deal of throw at first until I find the balance point. I will be happy if it just goes round and round.
Hopefully fixing the lower wing to the fuselage using a nylon bolt will keep the wing from shifting laterally inside the rubber bands. But I may eliminate the bands by pinning the back of the wing.
Winging it - Page 2 Aircra25
If I'm screwing something up here I hope someone will point it out..... Smile
Post  rsv1cox Tue Feb 16, 2016 10:05 am
Final of three coats of sanding sealer thinned 60/40, last coat sanded this morning w/150 grit.  Now I just have add all of this stuff and spray on a coat of primer, then color/decals and hope for a nice day.  Thinking 52' steel lines and enough space to get it airborne.  Smile
Winging it - Page 2 Ac_san10
Already looking at another project using the tail section of the plane that I used to make the wings on the Aircrate.
Winging it - Page 2 Ac_san11
Winging it - Page 2 Ac_san12
How about vectored thrust????  Kidding.  I will split the elevator and mount the engine between the two halfs.  But...will it fly???  Sorta flat wings work on a hollow log, but on this?  No camber on this R/C model tail section whats-so-ever it's totally flat.  A long nose moment will be required.
