Breaking-In Glow Plugs Cox_ba12
Breaking-In Glow Plugs Pixel
by rsv1cox Today at 9:38 pm
by GallopingGhostler Today at 9:04 pm
by 1/2A Nut Today at 8:43 pm
by roddie Today at 7:13 pm
by sosam117 Today at 5:32 pm
by rdw777 Today at 3:24 pm
by batjac Today at 3:47 am
by rsv1cox Wed Nov 20, 2024 9:21 pm
by 1975 control line guy Wed Nov 20, 2024 2:17 pm
by rsv1cox Wed Nov 20, 2024 12:35 am
by Cox International Tue Nov 19, 2024 6:01 pm
by getback Tue Nov 19, 2024 12:08 pm
Breaking-In Glow Plugs Empty
Breaking-In Glow Plugs Empty Breaking-In Glow Plugs
Post  gcb Sat Aug 13, 2011 5:10 pm
Some years ago someone on another forum posted that he broke-in glow plugs by applying power to them three or four times for a couple of seconds each time. This was without running an engine. Supposedly this extended the life of the plug. I gave him the benefit of the doubt and do this to my plugs.
Has anyone else heard of this?
gcb
gcb
Breaking-In Glow Plugs Empty Re: Breaking-In Glow Plugs
Post  GermanBeez Sat Aug 13, 2011 5:14 pm
it would make sense because the glow plugs wont be exposed to the excessive heat of the combustion at their first glow, as the
wire probably never has been heated. thermal shock might actually make it more brittle and more liable to break.
it would also be a good way to burn off any oils or dirt left from the production, if there are any.
GermanBeez
GermanBeez
Post  nitroairplane Sat Aug 13, 2011 5:54 pm
I
Have heard of that but I was some other reason why the person did it but I don remember who it was or why.
nitroairplane
nitroairplane
Post  jetpack Thu Aug 25, 2011 1:37 am
Heat cycling a glow plug element allows it to anneal or helps put a set to the winding, taking out the winding stresses before it is subjected to the running stresses.
I have actually seen it written long ago on the back of an out-of-date glow plug package but understand it didn't stay long on the packaging because of the marketing backfire of making plugs last longer by doing this...hence selling less glow plugs.
I am also on a search of its origin but to no avail so far. I am thinking of it being a K&B plug package but cannot find much on vintage glow plug packages on the web.
jetpack
jetpack
Post  PV Pilot Thu Aug 25, 2011 2:58 pm
Used to do this when I raced 1/8 scale offroad and were using $11.00 turbo plugs. Clip on the driver and just let it illuminate the coil, then immediately remove the driver and let the plug cool. Keep repeating allowing it to be lit just a bit longer. Did this about 6-7 times before installing in the motor for use. It seemed to help the life. The biggest thing is to not immediately flood the motor with a brand new plug on a first start try,,because then you could heat fowl the plug coil and shorten the life or make it a hard starter.
PV Pilot
PV Pilot
High Tech Balsa Basher
Post  SuperDave Thu Aug 25, 2011 3:15 pm
Ditto my experience when flying C/L stunt competition.
SD
SuperDave
SuperDave
Post  nitroairplane Thu Aug 25, 2011 3:19 pm
SuperDave wrote:Ditto my experience when flying C/L stunt competition.
SD
Or you could put one in a microwave Smile
Only kidding don't it will explode.
nitroairplane
nitroairplane
Post  jetpack Sat Sep 10, 2011 11:24 pm
I haven't given up my search for the label I've seen that explains breaking in a glow plug.
The picture is a Cox package explaining how glow plugs get better with age (heat cycling as mentioned)
Breaking-In Glow Plugs Glow_p10
jetpack
jetpack
Post  SuperDave Sat Sep 10, 2011 11:31 pm
If there is a benefit i believe that it would "temper" the element for the life that it is about to endure.
Just a supposition.
SuperDave
Certificed Coxaholic
SuperDave
SuperDave
Post  jetpack Sun Sep 11, 2011 5:31 am
I wonder though if it doesn't have to do with the platinum being able to react as well as when "broken in" where it has to form pits or something for it to gain enough surface area to glow like it should with the methanol, transforms that way somehow...
jetpack
jetpack
Post  SuperDave Sun Sep 11, 2011 1:54 pm
In some 60 years of glo flying I have encountered no more than a handful of glo-plug failures. In fact I still have several CHAMPION glo-plugs that resemble spark plugs. (Remember them?)
I run them ocassionally just for show but NOT in inverted engines where they could easily be ruined in a hard landing "nose-over".
"Break-in" of glo's, to me, is an option and not an obsolute requirement.
SuperDave
Certified Coxaholic
SuperDave
SuperDave
Post  nitroairplane Sun Sep 11, 2011 2:56 pm
SuperDave wrote:In some 60 years of glo flying I have encountered no more than a handful of glo-plug failures. In fact I still have several CHAMPION glo-plugs that resemble spark plugs. (Remember them?)
SuperDave
Certified Coxaholic
Me too a failure is very rare.
nitroairplane
nitroairplane
Post  SuperDave Sun Sep 11, 2011 3:42 pm
SuperDave
Certified Coxaholic[/quote]
You "newbs" may have no experience with these CHAMPION glo's because they harken back to what you might consider "antiquity". They feature a white porcelin inset with the word "Champion" emblazed in red. They larger than today's glo's and quite distinctive in appearance. They often draw quite a bit of spector interest and comment.
SD
SuperDave
SuperDave
Post  balogh Sat Nov 19, 2011 11:04 pm
GermanBeez wrote:it would make sense because the glow plugs wont be exposed to the excessive heat of the combustion at their first glow, as the
My high-compression COX glow heads sometimes burn out after a very few flights. The head deterioration starts with the platinum filament spiral getting distorted and touching the wall of the nest where it sits in the glow head thus short-circuiting a part of the spiral and effectively reducing the heat emmission when the battery is connected to it. I sometimes manage to realign with a needle/pin the spiral inside the well where it sits but it wont last for long.
Even after I add 1 or 2 more head gaskets to reduce compression and thus peak pressure and ignition temperature the filament is soon destroyed...
Any suggestion by someone on how to elongate the life of COX glow heads?
Post  microflitedude Sat Nov 19, 2011 11:45 pm
What Nitro percentages are you running? Are you running over-lean?
microflitedude
microflitedude
Post  jetpack Sun Nov 20, 2011 2:24 am
The freshness of the fuel has a lot to do with how long glow heads last. Water will super heat the glow element by pre-ignition.
Standard glow plugs don't see it that much but the Cox filiments are a much finer, hotter element.
jetpack
jetpack
Post  PV Pilot Sun Nov 20, 2011 12:29 pm
Those high comp heads are a finicky little unit.
Some of them look distorted right out of the package.
Usually when you distort the coil it is extremely lean. It might run right when flying, but when you run out of fuel at the end of the tank, and it leans out and s-t-r-e-t-c-h!.
As you know, cold air is dense air. As a generality, your air/fuel ratio is in the lean side during the winter and the rich side during the summer.
PV Pilot
PV Pilot
Post  microflitedude Sun Nov 20, 2011 3:45 pm
PV Pilot wrote:As you know, cold air is dense air. As a generality, your air/fuel ratio is in the lean side during the winter and the rich side during the summer.
How do you cope with this?
microflitedude
microflitedude
Post  PV Pilot Sun Nov 20, 2011 4:04 pm
Anything that will add extra heat.
Hotter glow plug.
Less nitro content,, make it more of a oil burner. Nitro carries it's own molecule of oxygen and with cold temps it's getting plenty of that.
Raise the compression/advance the timing.
On the really cold days, you could wrap the HEAD with insulating material/tape.
PV Pilot
PV Pilot
Post  gcb Mon Nov 21, 2011 3:02 am
SuperDave wrote: In fact I still have several CHAMPION glo-plugs that resemble spark plugs. (Remember them?)
SD
Yup! These are Champion shorts bought new in the mid fifties. Champion stopped making them because they cost more to make than a spark plug when plugs were selling for about half a dollar.
Breaking-In Glow Plugs 100_0011
Breaking-In Glow Plugs 100_0012
gcb
gcb
Post  Admin Mon Nov 21, 2011 3:10 am
SD
I want those! I remember seeing an ad for those in a old magazine!
Post  nitroairplane Mon Nov 21, 2011 7:04 am
You can get the modern version if you like.
nitroairplane
nitroairplane
