beam mount question Cox_ba12
beam mount question Pixel
beam mount question Empty
beam mount question
beam mount question Empty beam mount question
Post  chevyiron420 Wed Mar 25, 2015 7:22 pm
Has anyone mounted there engine with the cylinder to the inside of the circle? Does it cause any problems? I am considering doing this because mounting conventionaly puts my needle valve to the bottom to be broken off on each landing.
Phil Babe Bee .049
chevyiron420
chevyiron420
beam mount question Empty Re: beam mount question
Post  RknRusty Wed Mar 25, 2015 7:31 pm
Unless it inhibits the fuel flow up the bypass ports(which I doubt), I don't see why not. What kind of engine can't you swap sides of the NV with? I usually cut my top mounted needles short and either bend it into a "J" or solder a nut on top of the cut-off stub of the needle. I have swapped so it points down, and just had to get used to reaching around and underneath the fuselage to turn it.
Post  chevyiron420 Wed Mar 25, 2015 7:49 pm
Rusty, I want to build the 75% sabre with a mkXII wen mac. The needle valve is pressed in and also on an angle. If turned around it would be in the prop. I could radial mount but those tabs are pretty week to me.
chevyiron420
chevyiron420
Post  crankbndr Wed Mar 25, 2015 8:43 pm
The Cox Hyper Viper came that way
beam mount question Img_0310
Post  pkrankow Wed Mar 25, 2015 9:14 pm
Looses the advantage of shifting weight to the outboard tip...
yes, I am fishing. I can't think of any real reasons.
Post  Mark Boesen Wed Mar 25, 2015 10:54 pm
I used to know a guy that had a baby clown with a golden bee mounted to a horseshoe backplate, mounted just like the hiper viper, with fuel line coming off rh side and cylinder flat to left..it flew great!
i don't think the weight-off set is that much of a hardship, glue a nickle to the outboard and go! If you press out needle on Wen-Mac it will likely be loose when you press it back.
