» TEE DEE Having issuesby TD ABUSER Today at 9:43 pm
by roddie Today at 6:17 pm
by TD ABUSER Today at 2:13 pm
by Ken Cook Today at 1:41 pm
by Ken Cook Today at 1:37 pm
by getback Today at 11:52 am
by roddie Today at 10:43 am
Northern Flicker - a 2 chan low wing for Baby Bee
Hey folks! I drew up the plans for the Northern Flicker last night. I think they turned out OK. I've attached a .jpg version of it here, but if anyone wants, I have a .pdf available - just PM me.
The plan is intended to be printed on 36"X24" (Arch D) size sheet. It's full scale.
I'll try 2 versions. This is the full rez version:
This one's more modest, but still easily readable, I think...
Direct link to my photobucket so you can download the full rez:
https://2img.net/h/i7.photobucket.com/albums/y291/JasonB1976/northern%20flicker_zpsopfaprby.jpg
Good luck, Folks!
J
Good luck, Folks!
J
Last edited by JasonB on Fri Mar 13, 2015 6:29 am; edited 1 time in total (Reason for editing : revised drawing)
JasonB- Silver Member
Re: Northern Flicker - a 2 chan low wing for Baby Bee
Thanks Jason. I really like the model. It's a good candidate for RCM fuse-jigs that I built in two sizes. The small one at 24" x 6" probably isn't big enough.. but the 48" x 12" would be. I actually haven't used either one yet.
You commented on my snow-ski gear. You're right.. I need to make some sort of spring-leveler that only permits a few degrees of toe-down. My region got a lot of snow from the end of Jan. thru most of Feb.. with consistently below-freezing temps throughout.. which accounted for total accumulations in the "footage" range. I usually do some "sledding".. but haven't been once this season.
Yeah, we got buried too... Somewhere near 12', with another foot coming this weekend, they say!
To be honest, when I built the Flicker, I just glued the fuse sides to the firewall, then glued the aft ends together. Then I inserted the 1/4" struts starting near the middle and working towards the ends. Straight build is guaranteed if you cut and glue those pieces accurately. Then again, I've never used a jig for any building!
It seems so clear now why all my builds have had near flat-bottomed wings LOL.
I'd love to see some folk try this build and see their results!
J
J
I think I'm gonna have to build this maybe machine a crank and crankcase to make a flat twin engine utilizing two .049 engines
mitchg95- Diamond Member
dude thats goning to be a monster i would do it with two 020's =040 so close enoughmitchg95 wrote:I think I'm gonna have to build this maybe machine a crank and crankcase to make a flat twin engine utilizing two .049 engines
cox24711- Platinum Member
Oh, WOW! That'd cook right along... Might wanna shorten the nose a touch for balance if you do, as it does balance quite well with a single cyl. on there....
It'd look the part, though, with a cylinder on each side like so many early home-builts.
J
J
Nice Looking airplane for a BB 2 Channels are a lot of fun to set back and relax with floating like an eagle searching for food , I got the file from your bucket , thanks Are you using mini servos ? Lipo batt. or standard equipment ? Eric
Thanks!
I powered mine with HS55's (had'em on the shelf, something more durable in a similar size would be better).
The battery I used was a 1/3AAA NiMH pack from a Losi Micro-T. An AAA pack or small Lipo would do as well. For balance, my pack is velcro'd to the back of the firewall. A larger pack would end up a touch further back, all else being equal.
The wing is also easily converted to ailerons with a little imagination, I did that for the wing in my Aquastar, which is basically the same structurally.
There's a half-arsed build thread here that details some equip choices:
https://www.coxengineforum.com/t7959-scratch-built-2-chan-babe-bee-powered-plane-the-northern-flicker
J
J
I'm considering the .049 cylinders because parts are way more readily available and cheaper than the .020 option, if I were to design and build this engine I would, opt for rotary induction through the crankshaft and have a throttle on the carb so I would be able to control the speed a lot better
Such a great looking design, one for a future build for me. We haven't had enough snow here in NY State this year to oblige flying one of these on skis. Skis are a great way (normally) to extend the season. We have had only a couple frigid 0 degree F days here, was 62F here yesterday.
PeterJGregory- Gold Member
I like this plane too. I'm thinking it needs a tee dee to give more power and then I can put a set of floats on it. I have plans for a ROW free flight model with a really light set of floats, should work well. I don't get a lot of snow here.
Whats the wing span?
duke.johnson- Diamond Member
Duke it says 40" at 13oz. at the bottom of the plans first page . Eric
Oh GEEZ! You mean the big bold letters. Sorrygetback wrote:Duke it says 40" at 13oz. at the bottom of the plans first page . Eric
» Scratch Built 2 chan Babe Bee Powered plane - The Northern Flicker
» *Cox Engine of The Month* Submit your pictures! -February 2020-
» baby ring wing
» Caravan 1/2 A
» warped baby ring wing
» baby ring wing
» Caravan 1/2 A
