RR1 Gasket /Seal Question
Got my engine apart // When I try to run it before it would only run on prime // Have ck'ed the needle passage and all is clear , I did just replace the hose that had a small kink in it . Q is there a O ring that goes on the Ventura ? (I cant tell from looking if there was ! Thanks Eric And will it go together without the rotor catching the crank-pin??
Re: RR1 Gasket /Seal Question
I have never worked on one of those so I dont know but, it seems to me the crank pin would have to stick through the rod and engauge the hole in the rotory valve. Therefore I wouldnt think it would go together if not aligned. I would think there must be an oring on the backplate to ever be able to get a needle adjustment on it. The other thing is looking at the picture of the rotory valve, I cant see how it could work at all without another hole in it.
chevyiron420- Gold Member
It looks like the gasket is smashed onto the tube, you probably need to replace it, small 0-ring or thin slice of silicone fuel tubing.
If you try hard enough you can screw down tank without aligning pin, trial fit first.
I thought that was an o- sealer there (but) I will take it apart and replace with tube cut , I think I got the putting it back together now, a little tricky a lot diff than a Bee for sure
https://www.coxengineforum.com/t308-quick-and-easy-way-to-make-venturi-gaskets
I see I'm going to have to dig up some pictures that went missing.
Thanks Admin , I had seen this before but nothing wrong with reminders , I have been making them awhile but have not tried the skewer . I have been using a sharp pair of small dikes and stretching the ring over the tube with a probe pick and my finger nail holding it in place. Haven't tried the floppy disc for reeds but need to just another way to cut back on expenses. Eric
» Do newer plastic reed cage still need paper gasket? And TD .15 Special MkI question.
» GB backplate to tank seal
» Cox .049 boat cooling upgrades
» Tee Dee .020 Tank seal?
» Why Seal Bee Tanks?
