Differences between Sure Start And Product Engine With Horseshoe Backplate  Cox_ba12
Differences between Sure Start And Product Engine With Horseshoe Backplate  Pixel
by batjac Today at 10:05 pm
by gkamysz Today at 9:29 pm
by roddie Today at 9:22 pm
Differences between Sure Start And Product Engine With Horseshoe Backplate  Empty
Page 1 of 3 1, 2, 3  Next
Differences between Sure Start And Product Engine With Horseshoe Backplate  Empty Differences between Sure Start And Product Engine With Horseshoe Backplate
Post  NEW222 Thu Jan 29, 2015 10:05 pm
Hi there.  This may very well be a stupid question, but I have to ask.  What is the differences, if any, between the Cox Sure Start and the Cox product engine with horseshoe backplate.  I have each, but after looking at them, I was just wondering if the choke tube and fine thread needle are the only differences?  Thank you.
Differences between Sure Start And Product Engine With Horseshoe Backplate  Empty Re: Differences between Sure Start And Product Engine With Horseshoe Backplate
Post  TDbandit Thu Jan 29, 2015 10:57 pm
Well one of the differences is the surestart cylinder which is a duel port with a single boost port on each side but as far as I know thats the only difference. Some of the other guys here could probably tell ya more than myself though. (Bandit)
TDbandit
TDbandit
Post  balogh Fri Jan 30, 2015 1:17 am
In addition, most product engines had SPI cylinders while Sure Starts are non-SPI.
Post  NEW222 Fri Jan 30, 2015 2:20 am
Great, thank you. This is what I was looking for. The little things. But as per the replies, it would appear the differences are internal.
Post  balogh Fri Jan 30, 2015 2:35 am
The Surestarts came only with the slit exhaust ports while early and pre-Estes product engines typically had open exhaust ports. This is , as you term it, an external difference.
In my eyes an old genuine product engine, though, is usually superior to a Surestart. These latter often came with metal particles left in the engine after manufacturing, and the overall quality of pre-Estes engines is said to be higher than that of the Surestarts. I have a couple of the latter too, they look nice, and had some of them in service as well, but they somehow tend to wear off quicker than the old-stock COX stuff.
Post  KariFS Fri Jan 30, 2015 2:39 am
Which one has the fine thread needle?
Post  balogh Fri Jan 30, 2015 2:56 am
As the COX productline went along a cost cutting program over the years, I would assume the product engines more often had fine-thread (more expensive to make) needle valves than the later Surestarts.
The manual of the latter says you need to open the NV 4 full turns to start the engine...an older manual of a product engine says you open 5 turns, meaning the thread is finer of the product engine NV..
Post  roddie Fri Jan 30, 2015 8:49 am
It is my understanding that Cox made several styles of "Product Engines". These engines were the ones that came installed in their "Ready to Run/Fly" models.. and could be ordered separately as replacement engines for those models. The Babe Bee could actually be called a "Product Engine" because it did come installed in some models in the early days.. IIRC.
Cox then started to design their models with separate (external) fuel tanks.. and designed a "modular" small plastic back-plate for the engine, that would fit into molded slots in all of their model's mainframes/fuselages. These back-plates are referred to as the "Postage-Stamp" because of their shape and had a fine-thread (128 TPI) needle valve. The engines having this style back-plate had no other mounting provisions for a conventional firewall-mount in a balsa kit type model. There were "aftermarket" mounts designed by other companies which would allow the engines to be used conventionally.. because otherwise; after the Cox model crashed or broke, the engine became useless.. even though it usually survived and still ran fine.
Cox later re-designed their plastic back-plate to still be "modular".. but also had a flange molded-in with four small holes for screw-attachment as an option. It was also flat/flush on the backside allowing it to be conventionally (radially) mounted to the firewall in a balsa kit-model. These back-plates are referred to as the "Horseshoe" because of their shape and had an 80 TPI needle-valve. I don't believe that these back-plates were ever made with the fine-thread needle.
These two styles of back-plates are interchangeable between most Cox .049 reed-valve engines.. so if the older (Postage-Stamp) style is found on an engine, it can be swapped out for the easier to mount "Horseshoe" style which is still available separately as a kit. (back-plate/needle/reed/reed-retainer/gasket/case-screws).
I hope that this was useful information.. although it refers more to the back-ends of the Product Engines than the types of cylinders that the engines came with. I'm still learning about all these elements myself. Smile
Post  balogh Fri Jan 30, 2015 8:58 am
In summary, because Surestarts have a horse-shoe backplate, they come with the 80 thread-per-inch needle valve, while the postage-stamp backplates of the older product engines have 128 tpi design.
Post  TDbandit Fri Jan 30, 2015 10:05 am
balogh wrote:The Surestarts came only with the slit exhaust ports while early and pre-Estes product engines typically had open exhaust ports. This is  , as you term it,  an external difference.
Piston/cylinder fit was not good as well. I had one that on the third break-in run, it started loosing compression. I pulled it apart and started fitting pistons, found one that fit better and installed it and never had another problem. (Bandit)
TDbandit
TDbandit
Post  KariFS Fri Jan 30, 2015 12:38 pm
Thanks guys. Has anyone tried to swap needle assemblies from postage stamp to horseshoe? Reason I am asking is that I have one postage stamp backplate that has maybe overheated and it seems useless. It is discolored and the needle assembly practically fell off. Maybe I could transplant it to a horseshoe? Any glue needed and/or recommended?
This whole fine thread thing has made me seriously think about fabricating "Roddie-style" brackets for my narrow-neck, thin-cylinder Two-Ninety (see my current avatar Wink ). First I thought I'll just throw the red backplate away and mount it to a Silver Bee tank but somehow I just can't bring myself to modify this survivor, even though it is "just" a Two-Ninety Smile
Post  anm2 Fri Jan 30, 2015 3:29 pm
KariFS wrote:Thanks guys. Has anyone tried to swap needle assemblies from postage stamp to horseshoe? Reason I am asking is that I have one postage stamp backplate that has maybe overheated and it seems useless. It is discolored and the needle assembly practically fell off. Maybe I could transplant it to a horseshoe? Any glue needed and/or recommended?
Yes, I have swapped the postage stamp needle valve to the horseshoe needle valve. It works very well. You will need to gently heat the postage stamp backplate until you can remove the needle valve. Same with removing the horseshoe needle valve. I believe I just pushed the new needle valve into position without re-heating the backplate. The older red and beige horseshoe backplates already come with Fine thread needle-valves. Hope this helps.
Andy
anm2
Post  roddie Fri Jan 30, 2015 5:05 pm
I'm an advocate for resurrecting the old postage-stamp back-plate.. as you know. Mounts are easy to make. The four-screw mount pattern on the Cox .049 reedie's crankcase is 17/32" (13.49mm) on center. Locate some sheet-steel approx. .031" (0.8mm) thickness and cut two strips 3/4" (19.0mm) wide by approx. 1" (25mm) long. Drill clearance holes for your 2-56 crankcase screws approx. 1/8" (3mm) in from the edge of the short side of the strip. You may need to form a slight radius/relief to clear the protruding venturi housing/stack.
Then you have a choice in how to proceed in the mount-configuration. Using a bench-vise, you can form a two-bend 90 degree "Z" in each mount, for a radial/firewall.. or you can form a single "L"-bend in each mount, for straddling the top/bottom of a custom hardwood nose-block.. as described in the "290 Special" airplane plan.
Differences between Sure Start And Product Engine With Horseshoe Backplate  290_sp10
The above sectional of the "290 Special" plan recommends trimming the postage-stamp back-plate "square". This is not necessary.. and leaving it "stock" will orient the NVA horizontally when the mounts are installed, which is favorable on a profile fuselage for tank/bladder lines to be a short straight-shot to the spray-bar nipple. Your mount's bend location on the engine-side should be approx. 5/16" (8.0mm) from the edge of the mounts.. and if you choose the "L" type mount; the angle will depend on your nose-block design. The "Z" bent mounts require a radial firewall size of approx. 1.375" (35mm) by 3/4" (19mm).. so airplane kits designed for Cox "Bee" engines may need a "taller" plywood plate to attach the engine.
Here are some aluminum "Z" mounts that I made (shown below with a "horseshoe" back-plate for comparisson).
Differences between Sure Start And Product Engine With Horseshoe Backplate  11-11-10
Aluminum may not be the best material though. I sent a set of these to Eric Greeson (getback) and one of the mounts developed a stress-fracture along one of it's bends after he flew it on his hotrod speed model. It could have been a "fluke".. but needs mentioning.
Differences between Sure Start And Product Engine With Horseshoe Backplate  8-24-110
Post  NEW222 Fri Jan 30, 2015 6:28 pm
roddie wrote:It is my understanding that Cox made several styles of "Product Engines". These engines were the ones that came installed in their "Ready to Run/Fly" models.. and could be ordered separately as replacement engines for those models. The Babe Bee could actually be called a "Product Engine" because it did come installed in some models in the early days.. IIRC.
Thank you for this. I was actually going to ask the question that you have answered above regarding the Baby Bee as a product engine. As I was going through MH Aerotools, I saw what looked like a Baby Bee engine that they call Super Bee. It has a description of the transfer ports, which I will look at. Also you mention that you did not recall that Cox made a 'Horseshoe' backplate, then I thought that all horseshoe backplates were created equal as the same as on my Sure Start. So I then go look at my horseshoe backplate engine and lo and behold, a fine thread needle! Who would have thunk? In case it makes a difference, it is a red horseshoe backplate.
Post  NEW222 Fri Jan 30, 2015 6:30 pm
Ok, again, I must not be all here today. As I re-read anm2's post, he lays it out in his post: 'The older red and beige horseshoe backplates already come with Fine thread needle-valves.' Right there in front of my closed eyes....
Post  roddie Fri Jan 30, 2015 6:45 pm
NEW222 wrote:Ok, again, I must not be all here today.  As I re-read anm2's post, he lays it out in his post: 'The older red and beige horseshoe backplates already come with Fine thread needle-valves.'  Right there in front of my closed eyes....
Don't feel bad! There isn't a member here who hasn't been surprised at the numerous different combinations that Cox produced over the course of time!!!! Smile
Post  GallopingGhostler Fri Jan 30, 2015 8:50 pm
TDbandit wrote:Well one of the differences is the surestart cylinder which is a duel port with a single boost port on each side but as far as I know thats the only difference. Some of the other guys here could probably tell ya more than myself though. (Bandit)
Postage stamp Cox 290's had SPI, were considered powerful enough for an entry level 1/2-A speed event AFAIK, (proto?). I've got two of those.
Engines I posted about that I recently received from a friend were of the newer 290's with horse shoe back, one from a 2 channel Sportavia RC RTF the other from a Corsair CL RTF. Both have slit exhausts, very large single port on each side, no extra porting for a total of two and no SPI. Pulled the jug off my Sure Start, cylinder certain appears to be the same. Both engines use the same needle thead as the Sure Starts.
The Sportavia engine uses a brass reed valve and wire retainer whereas the Corsair engine is plastic with teflon or nylon reed valve like the Sure Starts.
Except for the choke tube, they certainly seem identical to me. May be I'm wrong. Tired w/ Coffee Read Popcorn
Post  TDbandit Fri Jan 30, 2015 11:27 pm
Here's a pic of the cylinder off my Sure Start it's not the best but if you look carefully to the left of the port, you can see the extra milling and raised edge on the top left corner indicating the boost port it however does not have SPI as previously said. (Bandit)
Differences between Sure Start And Product Engine With Horseshoe Backplate  Ss_cyl10
Sorry for the pic quality.
TDbandit
TDbandit
Post  Mark Boesen Fri Jan 30, 2015 11:40 pm
Differences between Sure Start And Product Engine With Horseshoe Backplate  Cylind10
Post  Oldenginerod Sat Jan 31, 2015 12:51 am
NEW222 wrote:As I was going through MH Aerotools, I saw what looked like a Baby Bee engine that they call Super Bee.  It has a description of the transfer ports, which I will look at.
The Super Bee looked the same as a typical Babe Bee of the era except that it had 2 bypass ports to the Babe Bee's 1, which was identified by number 1. It has SPI as do the early single port Babe Bees and the cylinder was marked "P-40" as the engine was specifically built to install in the Cox P-40 model. It was a heavy plane so the second bypass was introduced to increase power. The P-40 could also be considered a "product engine".
Have a look at "Cylinder Identification" under "Info" on the left of this page.
Post  GallopingGhostler Sat Jan 31, 2015 7:51 am
TDbandit wrote:
GallopingGhostler wrote:Here's a pic of the cylinder off my Sure Start it's not the best but if you look carefully to the left of the port, you can see the extra milling and raised edge on the top left corner indicating the boost port it however does not have SPI as previously said. (Bandit)
Photo quality is fine, Bandit. Out of curiosity I pulled the heads off both the Estes Sure Start and Cox 290 Corsai engine.
Differences between Sure Start And Product Engine With Horseshoe Backplate  Sure_s10
Sure enough there is a second milling, which wasn't evident upon intial inspection, showed up in the photo. in this case, the extra milling's boost must be so subtle as it is hardly noticeable, hence why I didn't see it the first time. Looking especially at the gaps between slit and port milling, width of both appears about the same. Neither have SPI. Seems to me both have about the same volume. Both engines probably have about the same performance. About the only way to know for sure is to tach them, except I don't have a tach.
Both place on sport models, I'd probably never notice the difference. lol!
Post  TDbandit Sat Jan 31, 2015 9:22 am
In stock form theres not really much of a difference infact the 290 may edge it out a little. This is due to to the poor fit of the estes sure starts. Now if you rework em a little (IE) refit the piston, clean up the reed, check the case excreta it will wake up a little bit. I bet estes used this same cylinder on their version of the killer bee. (Bandit)
TDbandit
TDbandit
Post  GallopingGhostler Sat Jan 31, 2015 10:18 am
TDbandit wrote:In stock form theres not really much of a difference infact the 290 may edge it out a little. This is due to to the poor fit of the estes sure starts. Now if you rework em a little (IE) refit the piston, clean up the reed, check the case excreta it will wake up a little bit. I bet estes used this same cylinder on their version of the killer bee. (Bandit)
Bandit, your advice is spot one. One thing I noticed is that the 290 has a round venturi shaft with no restriction flats whereas the Sure Start does. I put drops of light machine oil in the Sure Start and now it has compression. 290 uses a brass reed, I could replace with a teflon one.
Yes, I heard that Estes apparently had folk who didn't know what they were doing, not recognizing the difference between performance and standard parts. Their so-called Killer Bee had the power of a Babe Bee. Estes is now a company of Hobbico. I don't know if they are still in Penrose, CO or moved. Difference now is Cox International and EX Cox with a few others are doing a much better job in matching pistons and cylinders, or so I gather. One is assured to get a quality product.
Nonetheless, since a friend gave me these 290 engines and I want to make a good showing of them, am now consider plane candidates. For the Sportavia 290 I'm thinking of a 30" span poster foamboard Simple Delta with elevons. The Corsair 290 deserves a suitable CL plane.
Post  TDbandit Sat Jan 31, 2015 11:32 am
Sig 1/2A stagger wing! I would look good in it. Very Happy I'm fixing to build one once I'm done with my wildcat. and as far as the Sure Start back plate is concerned, I took the restrictor out of mine and drilled the snorkel which woke it up a good bit. (Bandit)
TDbandit
TDbandit
Post  GallopingGhostler Sat Jan 31, 2015 12:37 pm
TDbandit wrote:Sig 1/2A stagger wing! I would look good in it. Very Happy I'm fixing to build one once I'm done with my wildcat. and as far as the Sure Start back plate is concerned, I took the restrictor out of mine and drilled the snorkel which woke it up a good bit. (Bandit)
That Sig 1/2-A is still a classic, love the looks. A counterpart would be Walt Musiciano's hollow log Scientific Waco cabin bipe. You could take a photo of you with your headset on, color print it to scale and paste it over the painted windows. Could have your face facing looking out with your hand giving the thumbs up. Very Happy
I had a Dumas 1/2-A Ercoupe at one time, it was a profile with solid wings and Cox 049 Babe Bee. Too bad I don't have plans of it, but wouldn't be hard to make another from an Ercoupe 3-view.
Got a Scientific Piper Super Cruiser hollow log kit (original), not sure what engine to put in it yet. May just template and preserve the kit. Have Walt's Building and Flying Scale Model Aircraft book with his 1/2-A P-61 twin Mustang and 1/2-A Aeronca Sedan hollow log. Those 2 are classics, too.
