» Retail price mark-up.. how much is enough?by roddie Today at 9:58 pm
by rsv1cox Today at 4:38 pm
by GallopingGhostler Today at 4:04 pm
by 1/2A Nut Today at 3:43 pm
by roddie Today at 2:13 pm
by sosam117 Today at 12:32 pm
by rdw777 Today at 10:24 am
by batjac Yesterday at 10:47 pm
by rsv1cox Wed Nov 20, 2024 4:21 pm
by 1975 control line guy Wed Nov 20, 2024 9:17 am
by rsv1cox Tue Nov 19, 2024 7:35 pm
by Cox International Tue Nov 19, 2024 1:01 pm
Stepped Cylinders
Re: Stepped Cylinders
Refer to the middle of page 10 in the COX Model Engine Handbook. (I hope I am not infringing the copyright..)
Stepped or grooved cylinders were mainly in production till 1972 when a new honing machine was purchased by COX that did not require the groove...but the old honing machine was also used till 1976 so - as the book claims - grooved cylinders still were in sporadic production till 1976.
I read somewhere that the reason for the thicker walled cylinders was for strength. If the cylinder was struck during a crash the weak area was where the exhaust ports were cut in - the cylinder would distort. They first added extra material around the exhaust area and left the bottom thin for weight savings, then later just made the whole lower section a uniform thickness. Is this entirely untrue?
Motra- Gold Member
I guess the story about strengthening the cylinder by leaving it thick-walled is true, although I have never experienced any crack around the exhaust port area of thin walled cylinders. Some say it was occassionally inflicted even without a hard landing, if e.g. the engine was overheated (too high nitro %, poor cooling etc...)
The weight reduction with the groove may not have played an important role in the development of the design: just think about the latest cylinder shape which is thick-wall, and can be machined with fewer steps i.e. shorter production time and lower cost.. The groove was made there probably for the earlier honing machine, as long as it was in use.
I really need to get one.....
http://www.modelenginecollecting.com/Cox%20Web%20Material/Cox-Book.html
WingingIt74 wrote:I really need to get one.....
Me too! I've wanted it for years but just never pulled the trigger.
Motra- Gold Member
I have one and read it with mixed feelings.
At least the TD family - my favorite, and maybe the most famous COX engines - is discussed in less than 2 pages out of the 68. For me important information like production period of tapered wall design, various piston and rod designs etc. are still missing. It is certainly not to be blamed on the authors who looked into every tiny corner to collect the information still available, but in general the depth of information varies a lot accross the book.
Tons of pictures on engines with reference numbers to sub-versions, without explaining the technical difference between them.
But if you have the 35 bucks, you still may like it.
If you re-read the article, it clearly explains why the thicker cylinders. it was never for strength or weight reduction.
The Cox book is missing a lot and is not 100% accurate, but it's the only show in town and well worth the money to a die hard collector or enthusiast.
WingingIt74 wrote:When where they produced? What bypass/boost configurations can you find on them?
I have the handbook and I don't think it specifically mentions the different configurations, although if you go through the manual and check out all the different engine configurations you could figure it out. I am pretty sure they were made in almost every possible configuration. I have personally seen or held the following stepped cylinders: #1, #2, #3, #4, #6, #7. I don't recall seeing a #5 or a #8 but I am pretty sure they made them. In my opinion, the black widow with the stepped #1 is the most desirable of the BWs. Just my opinion. Andy
anm2- Gold Member
Hi Travis, This is one of three #1 cylinders that I have. I believe it originally came on a Golden Bee.
This engine arrangement is planned for my little "Phred's Phault" 1/2A Voodoo foamie.
Below is a photo of an obscure Cox .049 cylinder of which I have no idea of it's origin. It has no anodizing, no #.. and is single bypass ported. I have a 3-piece piston that I believe may have come with this cylinder.
Note the cylinder's minimum OD...
» Stepped No4 cylinder?
» Stepped Babe Bee with a strange box
» Kyosho Cox .049 Mini Cooper Engine Assembly
» The Scientific Walt Musciano "Red Devil"? and the stepped Cox Babe Bee
» Space Bug, Space Bug Jr. and Stepped cylinder Babe Bee weights.
