by gkamysz Today at 9:29 pm
by roddie Today at 9:22 pm
by rsv1cox Today at 3:38 pm
removing medallion 049 backplate
How do you get the backplate off an 049 medallion. Mine has never been removed in over 40 years and none of my cox wrenches seem to fit. What do I need for a tool that won't damage the backplate? Would heating the crankcase help to loosen it?
Tinker Terry- Bronze Member
Re: removing medallion 049 backplate
yes, heat is the key, get'er pretty warm (uncomfortable to touch) and use the edge of wrench, should open pretty easy.
My preferred method is fitting an older TD wrench in the slats and unscrewing it. Don't use the standard black ones, they are too thin and will bend. If you think it's sticking, soak the engine in your solvent of choice (remove the carb body) for a few days first. Applying heat will help if there is sticky castor in there. Remove the needle so you don't bend it. Hold the engine the engine in a rag to insulate from the heat and provide a better grip. Don't let the wrench slip and ruin the slats. If you feel like you're using too much force, go back to more soaking and similarly more heat.
Edit: Mark beat me to it with the simpler version, but you get the idea.
I agree with Matt and Mark above, but one thing I do is a little different.
I put the wrench(like Matt's above) flat between the jaws of a vise.
Not having to hold the wrench seems to add a little more leverage.
Takes the challenge out of the job.
dckrsn- Diamond Member
If you are going to apply heat - take off the venturi. Don't melt the delrin!
and you can do this (but bee careful not to break the TITs! ) Getback
microflitedude wrote:My preferred method is fitting an older TD wrench in the slats and unscrewing it. Don't use the standard black ones, they are too thin and will bend. If you think it's sticking, soak the engine in your solvent of choice (remove the carb body) for a few days first. Applying heat will help if there is sticky castor in there. Remove the needle so you don't bend it. Hold the engine the engine in a rag to insulate from the heat and provide a better grip. Don't let the wrench slip and ruin the slats. If you feel like you're using too much force, go back to more soaking and similarly more heat.
It is exactly this wrench that is needed, but use the round end with its internal teeth stuck in the slats of the backplate as if removing a glow head...the bacplate and the glowhead have similar diameters..maybe you do not even have to apply heat..and yes, remove the NV to prevent it from bending..
You could also try finding a suitable steel flat-washer.. and mounting it 1/2 in a bench-vise. Even a (solid) Copper penny might work. The radius has a self-centering effect on that style nut, which will help keep it from slipping. It might also save your knuckles.. as long as they're away from the vise-jaws.
getback wrote:and you can do this (but bee careful not to break the TITs! ) Getback
Is that a beer-can opener Eric????
» Wanted:TD or Medallion .15 backplate
» Medallion 049 & Medallion 049; what is the difference?
» Removing QRC muffler
» Removing Wing Warp?
» Removing Carb Body from TD 0.049
