by gkamysz Today at 9:29 pm
by roddie Today at 9:22 pm
by rsv1cox Today at 3:38 pm
What's rule one when shipping a model engine??????
Take the needle valve out!!!!!!!!!!! Tape it to the engine or otherwise secure it. I have always done this.
Zero for two in my last two internet buys. Ripped package lost the Bell crank I had been waiting for, now this:
Enjoy???? I don't think so. Valve is snapped off right at the junction, no way to get the broken inner part out. I blame the seller for this one. No apparent damage to the box, poorly wrapped in hard newspaper with no padding.
What a shame, beautiful little Holland .051 in new condition. $77.00 shipped. I hope it's insured because it's going back to the seller. I believe ebay/PayPal will make this good.
Re: What's rule one when shipping a model engine??????
Poor little Hornet!
You can use a Hobby knife to score a line into the exposed nub and remove the needle. You might could find a new one though.
It would be worth keeping if you were compensated for the busted needle.
The seller might not of known to do this. Was it indeed his item or was he selling it for a friend. Bottom line, he may make good on it. A Texas Timer spraybar might be able to JB welded into the case and it will work better than the stock. Make him pay for it. Ken
Sorry man.. that sucks. Ken Cook makes a good point though. I don't blame you for being upset; so soon after the "bell-crank" ordeal.. but I'd hang on to that engine.. Just let the guy know what happened and see if he offers to compensate you. I'm sure he doesn't want to compromise his seller's rating over this.
If you do decide to keep it (I would) and can some how remove the broken part, MECOA appear to currently have stock of the needle on its own for $8.25, or a complete NVA for $12.35 if you can't remove it. They look to be an authentic reproduction so I'd just replace the lot. Even at $77 you'd be hard pressed to find another one if the rest of this engine is good. Maybe the seller will cover the cost of the replacement??
Thanks for the shoulders to "cry" on and for the helpful suggustions.
I could carefully score a line on the slightly exposed brass nub and back it out with a jewelers screwdriver. But for me the value is in it's collectability, I never planned on running it as it's the best example that I have ever seen.
MECOA? New to me, is there a website?
Edit add.... Googled and found it. Thanks
https://mecoa.biz/shopdisplayproducts.asp?id=117
Oldenginerod wrote:https://mecoa.biz/shopdisplayproducts.asp?id=117
Thanks, found it. I will sleep better tonight.
We have to all understand that some of these older engines are being sold by surviving family members that never was in the hobby. I would suggest when buying such vintage engines and any fragile gear you should respond to seller with a little note requesting / discussing how the item with be packed to insure safe guards are in place.
Personally, I once asked a seller to remove the needle valve and tape it flat somewhere to protect it. When the engine arrived, he had carved out a neat hole in a polystyrene block to fit the engine, including a cover, then carved another small hole beside the engine the shape of the needle, to which he installed a carved cover which was neatly taped in place with the words, "check under" written. It as so neat I nearly missed the needle if it wasn't for his little note. Can't do much better than that!!
Rod
Rod
Oldenginerod wrote:Personally, I once asked a seller to remove the needle valve and tape it flat somewhere to protect it. When the engine arrived, he had carved out a neat hole in a polystyrene block to fit the engine, including a cover, then carved another small hole beside the engine the shape of the needle, to which he installed a carved cover which was neatly taped in place with the words, "check under" written. It as so neat I nearly missed the needle if it wasn't for his little note. Can't do much better than that!!
Rod
Sounds like a good guy to buy from.
Waffleman- Gold Member
Success
I used a razor saw to cut a groove in the exposed part of the broken needle valve without damage to the housing, not easy as at best only about 1/32" was exposed. I also put a drop of penetrating oil on the threads. Backed out the broken needle and all is right with the world.
The prop was also stuck on the shaft so I used a thin piece of soft plastic inserted through the exhaust ports to unscrew it. Discovering that the piston is domed at the same time. Pretty neat. I may just run it. But I don't care for the two hole mounting system. Even Wen-Mac/Testors/McCoy use at least three on their radial mount engines.
Now to order that replacement needle valve.
Thanks everybody for the concern and heads-up.
Looking into these a little further I find that they are being reproduced and are currently available for $79.00 minus tank.
Probably impossible to tell if this one is a reproduction or an original, makes little difference but there are signs of rust on the shaft. Nice to know that parts are available.
Good deal man !!! wish i could get the one broken that i tried to straighten Eric
Just for the record, Randy from Mecoa has made promises of that engine and several others for over 20+ years and to no avail nothing has been made. To the best of my knowledge he's never reproduced a Holland Hornet. I wouldn't hold your breath waiting for one. This is a business practice one can really enjoy seeing. Here it is direct from the website.
PLEASE DON'T CALL
for information, prices or try to order any of these engines.
We will notify everyone when they become available.
We won't help you with any questions concerning these engines.
We need the time to build them right now, not talk about them!
This has been on the Mecoa site since it existed. I love the line that we won't help you with any questions or concerns. Ken
PLEASE DON'T CALL
Yes, That's curious. He has a price on them but no where to purchase.
I did contact the seller of the damaged engine and he indicates that he will pay for the new needle valve.
Ken Cook wrote:Just for the record, Randy from Mecoa has made promises of that engine and several others for over 20+ years and to no avail nothing has been made. To the best of my knowledge he's never reproduced a Holland Hornet. I wouldn't hold your breath waiting for one. This is a business practice one can really enjoy seeing. Here it is direct from the website.
PLEASE DON'T CALL
The same monopolistic arrogance as that of California Dan (= Dan Sitter) when not even bothering to answer me on ebay why he was not willing to ship used 010 parts to my place (Hungary)
balogh, tell me what you want and I'll buy from him and ship to you at cost. The last time I looked at his stuff he didn't have many .010 parts.
I sent him a question about a Bee once and got a terse response also.
crankbndr- Top Poster
Well the flip side of that is the seller that sold me the Hornet that arrived with the broken needle valve. Instead of refunding me the $14.00 I asked for he credited my paypal account with $22.00. Pain and suffering on my part I guess. I left him positive feedback.
balogh wrote:The same monopolistic arrogance as that of California Dan (= Dan Sitter) when not even bothering to answer me on ebay why he was not willing to ship used 010 parts to my place (Hungary)
I did find Dan a little difficult to deal with but once we had communicated a couple of times he seemed to warm up. He had no issue sending parts to Australia. I purchased a "complete" Baby Spitfire from him and it arrived minus the needle valve. Without a complaint he refunded me the full purchase & shipping cost & said keep the engine. I think you need to catch him on a good day.
Crankbndr thanks I dodged him already by asking someone to buy from him the items for me.
Rod I am wondering why then he sells stuff to buyers on ebay if he simply looks down on us? I do not necessarily want to become the psychotherapist of a burnt-out person simply because I want to buy something that by the way he himself offers to sell.
Glad to hear everything worked out for the better.rsv1cox wrote:Well the flip side of that is the seller that sold me the Hornet that arrived with the broken needle valve. Instead of refunding me the $14.00 I asked for he credited my paypal account with $22.00. Pain and suffering on my part I guess. I left him positive feedback.
Shawn
sdjjadk- Platinum Member
» What engine model do i have?
» whats this gizmo then? Engine mount from toy?
» Cox engine .049 r/c & COX FUN MODEL
» Limited Edition "Terminator" engine - Shipping tomorrow
» What model Cox engine is this?
