To gasket or not to gasket Cox_ba12
To gasket or not to gasket Pixel
To gasket or not to gasket Empty
Help! To gasket or not to gasket
Post  Oldenginerod Mon Sep 01, 2014 7:47 am
I wonder if anyone knows for sure.
When installing a plastic backplate on a reed engine which has the flanged type reed retainer, do you only fit a gasket between the retainer and the crankcase?  If so, wouldn't it potentially suck air between the retainer and backplate?  Thumbs Down
Also, I have the same concern about the steel exhaust deflectors which mount between the tank/backplate and crankcase.  Should you use a gasket each side of the deflector?   Huh...
Help! Re: To gasket or not to gasket
Post  pkrankow Mon Sep 01, 2014 8:12 am
"yes"
One must use a gasket between the case and retainer.
You may also use a gasket between the retainer and back plate (yes, 2 gaskets) but this is not generally necessary.
If sealant is used make sure it is aluminum safe.
Post  Oldenginerod Mon Sep 01, 2014 5:01 pm
I would have thought that a gasket between the retainer and backplate would increase the clearance for the reed, possibly causing it to "float". Has anyone had any experience with this?
Post  RknRusty Mon Sep 01, 2014 7:45 pm
Some came from Cox with no gaskets and ran fine. Others came with gaskets. Some seem to need them. It's one of those things that you do to suit each individual engine. Neither of my two NIB Black Widows came with a gasket. One had the famous shallow threads bored into the crankcase and a gasket helped for a while. I eventually Permatexed it, and later tapped it more deeply, which is the real answer. I prefer no gaskets if possible.
Post  Cribbs74 Mon Sep 01, 2014 7:56 pm
Reed "float has to do with RPM. Once a certain RPM is achieved the reed can no longer function as designed.
If you look closely the plastic reed retainer has a lot of space to allow the reed to move in and out freely. Adding one more gasket will not make a difference.
Edit: I originally wrote gasket float  lol!  in the beginning of this message, I meant to say reed float.
Last edited by Cribbs74 on Mon Sep 01, 2014 9:38 pm; edited 2 times in total (Reason for editing : Clarification)
