Mid Engine Design-Air Corba & Stilleto
A few of you have asked for more details on the Mid Engine design that I used on the P-39 Air Corba, so here goes.
Since I retired a few years ago I wanted to find somethig to do besides fishing. I wanted to get into Cox model planes like I flew back in the 1950's as a kid. Back in Nov. I was looking at plans on E Bay & found the "Stilleto" and just had to build it. I had just started when the Speed Contest started so I switched over to The P-39 and built a profile design to enter. The P-39 was used in WWII in the Pacific but also used by other countries , mostly Russia. The P-39 & the later version the "King Corba" were both used in the Reno Air Races and the "Thompson Trophy Race in 1946 was won by Alvin "Tex" in a Air Cobra. The Thompson Race was a 30 mile course for 10 laps a total of 300 miles.
I also found a lot of info on the Reno Air Races at : AAFO Hangartalk--P-39 Racer. U tube has a lot more of course , just type in P-39 Air Cobra & Reno Air Races.
The Stilleto can be found on E Bay under Model Airplan plans in RC & Control line at: the Vergina 123 Store under "Model airplane vintage proto speed plane y2a. The plans come on a disk and are very complete, with a lot of engine details.
The pictures above show the drive train I used in the Corba with a 1/4" I D brass tube holding 2 slip bearings and a #5 steel rod threaded with a 5-40 die. This is not the design used in the Stellito which is the larger #8 steel shaft with the u joint & in the alu. tube. As soon as time permits I will go back to the Stilleto so more on it later.
The picture shows the the drive shaft & engine in the test stand that I used, unfortunately I dont have a way to measure the RPM's to find out how much I am losing. The compents are shown with the upper flange bering out of the tube. Its a pretty simple method once you get the parts.
Hope this helps, RK Flyer
RK Flyer- Gold Member
Re: Mid Engine Design-Air Corba & Stilleto
I am interested in this but I am having trouble seeing the "thumbnail" pictures. Any chance of getting bigger pictures?
I like to see the unusual and a mid engined model aeroplane is unusual. It reminds me of IC engined boats with a propeller shaft.
Do you have any problems starting it with the lengthened shaft? A boat IC usually has a flywheel and the engine started using the flywheel (string wrapped around it!)
Thanks Richard
Here are your pictures. I can see them now.
"Dumas" may still make a Marine drive hardware kit (#2306) designed for Cox .049 engine use in their small boat kits. The kit includes a steel drive-shaft that I believe is 5-40 threaded at both ends.. as is the stub-shaft for mounting the universal-joint/flywheel to the engine. This marine set-up did not require bearings.. but you could easily utilize RC car bearings if you wanted to.
Ian, Thanks for posting the larger pictures!
Roddie, I think the Dumas parts look interesting but the Dura Trax ball berings might be the best way to go.
I will try to finish the Stiletto that I started in the next couple of months. Are you going to build it?
RK Flyer
RK Flyer
RK Flyer wrote:Ian, Thanks for posting the larger pictures!
RK Flyer
Hey Richard, Not sure what I'm going to build next. Probably something easier.. The Rare Bear took a LOT of my time. I want to finish a Ringmaster that I have... so I can get some experience with a larger stunt model. I also want to build at least one more 1/2A C/L profile from one of the plans you sent me. Thanks again for those!!!
Roddie,
The Rare Bear is a great looking plane and it really does reflect the time & effort that you put into it!
I have another 1/2 A set of plans for an unusual Trainer comming ! This one is a S-l-o-w flyer!
RK Flyer
RK Flyer
» CEF Profile Scale Speed 2015!
» New Cox Reed Design
» BOXER BEE design
» Anyone knows this design?
» BOXER BEE design
