making thin washers Cox_ba12
making thin washers Pixel
making thin washers Empty
making thin washers
making thin washers Empty making thin washers
Post  roddie Thu Feb 27, 2014 6:48 pm
Did you ever need a small thin washer/spacer/bearing.. with a precise thickness and inside diameter? Here's how to make them. Most modelers have a drill index.. and it's even better to have a full set of # 1-60 drills. You also will need a standard hole-punch. If your hole-punch has a plastic cover (like mine did) to catch the punched scrap.. remove it... because you need to see the punch hole.
making thin washers Drill_10
Stock can be anything thin, that fits the application. Sheet metal should not be thicker than .005". Other materials include, but are not limited to; plastic packaging materials, styrene, cardstock, inner-tube rubber... or anything else that will punch cleanly.
First, find the drill that is the size of the washer you need's inside diameter... and drill several holes about 1/2" apart and about 1/2" in from the edge of your sheet-stock.
Finally; insert the sheet into your hole-punch and close the jaw to where a hole in the "sheet"... centers with the hole in the hole-punch. When centered, "cup" your other hand over the punch and squeeze the handle. (work over a bench/table, so as not to lose the piece you just made)
This produces nice custom washers in a pinch... and you can't beat the price!!!
making thin washers Empty Re: making thin washers
Post  roddie Thu Feb 27, 2014 7:26 pm
A Cox Tanked Bee engines' venturi gasket can be made in a pinch.. by using .020" (h/d) poster-board or rubber inner-tube material and drilling (or even better) "punching" a 9/64" (.140") hole. (rubber and card-stock don't drill well)
Post  RknRusty Thu Feb 27, 2014 7:44 pm
I'd hate to be an inner-tube hanging around in your garage.
Post  getback Thu Feb 27, 2014 8:17 pm
Huh... I liked the tank a lot better lol! it is looking good , like you said ....up Flying  I am still looking fore that 1/32 thread nipple ! bounce bounce
