Flight Box
Flight Box
I finally got off my dead rump and started building my flight box. I had been using my sons toolbox and he mentioned to Mom that he wasn't happy about it. This resulted in stink eye from my wife so...
Re: Flight Box
Nice. Now be sure to paint it before you start using it and it will look good years from now.
706jim- Gold Member
Re: Flight Box
Thanks, It's going to be finished in stain and spar urethane.
Re: Flight Box
Nice!
only thought is you might want to reconsider carrying around a gallon of fuel, years ago I moved from a gallon to 1/2 gal. container then finally to 1qt. I know you need to top it off more often, but it is a significant weight savings and I think in the summer the bulk of your fuel stays at constant room temp. in the shop, also if you're adding caster for different engines it's pretty handy.
Re: Flight Box
Thanks Mark,
Some days I have been know to burn through a full gallon of fuel. Once I learn how to fly better I will slow down and carry less. As it stands more air time is what I need.
Most times, the car to the field is less than 100yds.
I had some warping issues so I will add the side covers tomorrow when the wood dries.
Re: Flight Box
Looks good Ron! There's lot's of space there by the looks of it... If you're looking to counter-weight it.. you could cut-in a power-panel.. "high" on the end opposite the fuel can (just below the handle) and build a 12V. battery box inside.. below the panel; on the floor. Drinking-water bottles will offset the weight of that Gal. fuel can as well.
What type of Spar-Varnish are you using? Do you have wood-burning tips for your soldering iron? It would be cool to burn your name in somewhere... and maybe the date you built it?
Roddie
p.s. if you install a power-panel... you can power it "on the cheap" by using two 6V. lantern batteries in series; using an 18 ga. jumper-wire. (this is basically the same as x8 "D" size batteries worth of capacity to power the panel) The lantern batteries are inexpensive if you buy the non-alkaline type (3 or 4 dollars ea.) so.. if your Ni-starter dies at the field... you could have a back-up glow-driver... as well as a 12V. power supply for charging your cell phone by connecting a 12V. accessory socket to the panel. Heck... you've got enough space in that box to mount speakers and a car stereo!!!
Roddie
Re: Flight Box
http://www.ebay.com/sch/i.html?_odkw=New+12+volt+8Ah+Sealed+Lead+acid+SLA+Battery+12v+7+amp&_sop=15&_osacat=0&_from=R40&_trksid=p2045573.m570.l1313.TR0.TRC0.XNew+12+volt+7Ah+Sealed+Lead+acid+SLA+Battery+12v+7+amp&_nkw=New+12+volt+7Ah+Sealed+Lead+acid+SLA+Battery+12v+7+amp&_sacat=0
Theres will last almost forever, I replaced one last year, bought it in '01-'02?
Re: Flight Box
BTW,
I love that Silver Foxx sticker! I would love to have one of those. I wonder if Lew still has any?
Re: Flight Box
Ron, did you see Lew's truck? The door panels are that logo. It looks pretty cool. Ken
Re: Flight Box
Last time I saw Lew was about 4 months ago and he was driving a plain old 90's F150.
I have a Lew Woolard Fox .40 now and it runs like a dream. Instant break when the nose goes up. It's mounted on a Cardinal.
Re: Flight Box
yep, those reworked fox .40's are da bomb!!! I almost bought one from him years ago at the nats, but already had two nice .40FP's and a good running .46 la, so I passed...grrr!
I'm sure he got a zillion of those stickers, I got one (nfs) but I can scan it.
Re: Flight Box
Thank you good sir!
Re: Flight Box
Thanks Mark,
I added some stain, I'll be applying urethane tomorrow. The side lids warped again, apparently I un-clamped them too soon. They have been steamed and clamped again.
I also took a photo of me carrying the tote with a full gallon of fuel. All I have to do is choke up on the handle some to balance it out.
Re: Flight Box
I love it. And I need it. I have 1/2A and stunter support all crammed into one plastic 1/2A box. That'll make a nice project for this Spring, if not sooner. Right now I'm working on a fuselage/wing/stab jig for alignment while gluing the main pieces together. Should be simpler than it sounds.
Re: Flight Box
A nice bit of woodwork. I always think that the home made/ custom build is best. You get what you wanted!
Re: Flight Box
Thanks Ian, I am not a woodworker by any stretch. As long as it entails cutting straight lines or some easy angles I can handle it.
The main reason for me wanting to do a box was to save face when I show up at the field. Most guys I fly with have elaborate home built boxes that have 30 or more years of history behind them. I feel out of place with my black and yellow Stanley toolbox!
Re: Flight Box
How do you store/carry your big propellers? I cut a piece of 3" PVC to drop them in but it sticks up too high and falls over. If I build a box I might make a deep vertical compartment to drop them into. And another place with holes for glow Igniters.
Re: Flight Box
RknRusty wrote:How do you store/carry your big propellers? I cut a piece of 3" PVC to drop them in but it sticks up too high and falls over. If I build a box I might make a deep vertical compartment to drop them into. And another place with holes for glow Igniters.
A wooden cigar box would make for "easy access".. and add some real character! Glue in some partitions if you want. Some come with latches.
Roddie
Re: Flight Box
Good idea Roddie,
I am thinking now that partitions in the main part of the box would have been a plus. I am done though. I am going to add piano hinges on the lids as it will take care of the bow. Darn things curved on me when I stained them The whole reason I did a thread was to show how quick it can be done. 3 days roughly 6 hrs. The rest of the time was waiting for stuff to dry. No more boring pictures I promise.
Well maybe one more. Just because Rusty asked how I will store my props!
And one of my fan club, no those are not my tools. They are my 6 yr old daughters. Just in case any of you guys were planning on being wise...
Re: Flight Box
It's beautiful. I like pictures.
Re: Flight Box
I hope you let the "girls" out when you're "rustproofing" the shop with a fog of castor oil! (that vid was entertaining!!!)
Roddie
Re: Flight Box
I didn't see that second pic before. You got YardBirds in your garage!
Re: Flight Box
Yeah, they split and sound the alarm when I fire something up. I give them a handful of cracked corn to settle them down.
I usually only run with the doors closed when test running at night, it keeps the noise down. Neighbors say they can't hear anything.
Those 4 like to hang out with me in the shop. Fine by me as they like spiders. Problem is they leave presents from time to time.
» Cox Fun Model .049 ... flight, flight and flight!!! (page 3 & 5)
» My first flight for the Cox Flight Contest.
» Need help with a foam wing control line build
» McCutchen Wing AKA Charibdis
» PIYURIN .010 * flight video *!! and now also .020...*flight video*
