"Steam Bee" how it was made Cox_ba12
"Steam Bee" how it was made Pixel
"Steam Bee" how it was made Empty
"Steam Bee" how it was made Empty "Steam Bee" how it was made
Post  OVERLORD Wed Dec 11, 2013 10:34 am
This steam engine, using a 049 Babe Bee, was made without a lathe or milling machine. All materials can be bought at a DIY shop or come from the skip.
I removed the tank and made 2 aluminium L shaped profiles with 4 brass tubes to be able to reuse the 4 fuel tank bolts.
"Steam Bee" how it was made Imgp5413
The glow plug was replaced by a cylinder head that can take a standard plug. in the end of the silicone tube, I inserted a small piece of brass tube of about 4 mm long. The tube was then inserted in the hole starting from the cylinder end. The silicon-and-brass end screws thight in the spark plug hole.
"Steam Bee" how it was made Imgp6210
"Steam Bee" how it was made Imgp6211
The excentric for the valve was made out of a bearing you can find in roller blade wheels. The conrod was made with a 2mm piano wire bent around the bearing and soldered. That took a bit of a struggle and a lot of cursing. Inside the bearing, I glued a piece of dowel wood with a 3 mm hole drilled off centre for the mounting bolt. The crosshead comes out of an old lamp fitting.
"Steam Bee" how it was made Imgp5212
"Steam Bee" how it was made Imgp5110
"Steam Bee" how it was made Imgp5213
The valve is a piston that moves back and forth and connects the silicon tube to the steam inlet or outlet. The valve cylinder is made out of standard copper tubing and end caps. First, I made the piston out of dowel wood that I doped, but that seemed to bind in the cylinder due to humidity. I replaced it by a aluminium piston. The piston rod is 2,5 mm piano wire.
"Steam Bee" how it was made Imgp5214
"Steam Bee" how it was made Imgp5215
Because the Babe Bee is a square or even over square engine, it needs a big fly wheel. I replaced the original fly wheel by a heavier one and I also closed off the cylinder exhaust slits. If it works? I don't know. It should do. I don't have compressed air and my lungs or the the aquarium air pump only give enough pressure for 1 down stroke.
"Steam Bee" how it was made Imgp6212
It is a nice experiment and it can evoluate to a compound engine using a Pee Wee for high pressure and a Babe Bee for low pressure.
Lieven
"Steam Bee" how it was made Empty Re: "Steam Bee" how it was made
Post  SuperDave Wed Dec 11, 2013 10:54 am
Lieven:
Nice!  A feate of dedicated engineering and skill.
SD
SuperDave
SuperDave
Post  RknRusty Wed Dec 11, 2013 11:23 am
I read a book by Ken Follett called Hornet Flight. A Danish teenager converted his motorcycle to run on steam, powered by slow burning peat. Seemed like a pretty cool contraption. You just have to plan ahead before you have to make a beer run. That was a great book, a riveting tale of besting the Nazis... and an airplane!
Post  mx862 Thu Dec 12, 2013 12:06 am
Very cool! thanks for posting Cool
mx862
mx862
Post  jsesere Fri Dec 13, 2013 7:34 pm
A video of it running would be great.
jsesere
jsesere
