» Happy 77th birthday Andrew!by akjgardner Today at 7:27 am
by TD ABUSER Today at 4:43 am
by roddie Today at 1:17 am
by TD ABUSER Yesterday at 9:13 pm
by Ken Cook Yesterday at 8:41 pm
by Ken Cook Yesterday at 8:37 pm
by roddie Yesterday at 5:43 pm
by GallopingGhostler Fri Nov 22, 2024 10:04 pm
by roddie Fri Nov 22, 2024 8:13 pm
by sosam117 Fri Nov 22, 2024 6:32 pm
by rdw777 Fri Nov 22, 2024 4:24 pm
by rsv1cox Wed Nov 20, 2024 10:21 pm
A Sanding Tip
A Sanding Tip
I often have a lttle trouble keeping a sanding line straight and constantly end up revisiting a piece - time and time again. Not too onerous with a small model but as they get larger it is not so easy to maintain a leading or trailing edge wing profile.
As usual, I take an easy way!
I use my building board - nice and flat - cut sand paper into strips and stick it to the board.
Then just rub the wing up and down it. Usually with two hands and a scrubbing motion. (Pictures are one handed - camera in the other hand!)
Straightening trailing edge
Smoothing the leading edge
Adusting the trail edge angle
Bevels on airlerons
Bevels on airlerons
Re: A Sanding Tip
Sanding tools are worth any effort it takes to make them. Many of mine are in need of new paper... Sticks and dowels of different grits are great for notching "ribs" and such...
To expand on Ian's "straight-edge"... I've often thought about making a long adjustable 2-piece "V" fixture, using 2" extruded alum. right-angle stock. The angle could be set at whatever taper you need to achieve on your edge. Angle stock would not flex (bow) and give an even cut, using equal feed-pressure (2 hands; like Ian stated)
This would make short work of producing quick/even straight tapers.
» Another proposed design by Roddie
» "Rodd-O-Gyro"
» Dope, Sanding Sealer, And The Like......
» Bulk-sanding balsa
» Sanding the primer coat
» "Rodd-O-Gyro"
