» music vids.. some of your favoritesby 1/2A Nut Yesterday at 11:26 pm
by roddie Yesterday at 11:01 pm
by davidll1984 Yesterday at 8:49 pm
» Green vent..
by roddie Yesterday at 7:49 pm
by rsv1cox Yesterday at 6:59 pm
by Cox International Yesterday at 4:33 pm
» PSA propellors!!!
by robot797 Yesterday at 2:39 pm
by roddie Yesterday at 11:42 am
by roddie Yesterday at 10:51 am
by davidll1984 Wed Oct 16, 2024 6:15 pm
» OK Cub .024
by 049kid Wed Oct 16, 2024 12:31 pm
Guillows Spitfire park flyer FINISHED!!!!!!!!!!!!
Page 4 of 8
Page 4 of 8 • 1, 2, 3, 4, 5, 6, 7, 8
Re: Guillows Spitfire park flyer FINISHED!!!!!!!!!!!!
Kim:
Please see if I've got this correctly:
"Blocking" is sheet material pieces indidually cut to fit between the stringers then sanded to the contours of the framing. (as shown in you diagram) "Blocking" is best adhered with CA cement.
I THINK this it how it works. Lemme know if it's not. Thanks.
SuperDave- Rest In Peace
Blocking,, balsa chunk bondo.
Kim wrote:I used the term "blocking" as the pieces actually protrude beyond the frame, and are sanded down to assume it's shape. Sheeting, to me implies a layer, glued to the outer edges, which actually changes the dimensions of the frame. Blocking is a big help in areas like a 51's doghouse area, as it can help continue it with a true compound curve, rather than the series of flats you get with tissue covering.
I was wondering if you thought I "sheeted" my spit. I should have been more clear, I used balsa sheets to make the blocks.
Ron:
I believe, as you apparently do, that "blocking" implies the use of thick "chunks" of balsa between the stringers when, if I undertand Kim's diagram correctly, the "blocks" are often no more than 1/16 to 1/8" inches thick.
If so, makes sense 2 me.
SuperDave wrote:Kim:
Kim can correct me if I am wrong. Yes to all the above except no on the CA. Dry CA is much harder to sand than balsa so you end up sanding off more balsa than CA which leaves a wavy surface. Using a soft glue will allow you to sand off the balsa and glue at the same rate. Smoother finish. I didn't listen to Kim's suggestion and used CA on mine and that is what I experienced. I was able to salvage my mess by shaving the hard CA off with my razor knife. It worked, but it took a long time.
SuperDave wrote:Ron:
Yes, we agree. I made "blocks" or plugs using 1/16" and 1/8" sheets
Ron:
Hope you read my thread re: Sullivan Golden Cables as pushrods. I plan to use #507's on my Spit'.
PV Pilot wrote:Blocking,, balsa chunk bondo.
Blocks, rocks, chunks, and pieces....
Will do Super Dave.
OK here is the progress so far, basically I have covered most of the Spit with the exception of the aft fuselage. I installed the control rods, engine and modified the cowl to accept the TD .010. I used olive drab monocote and will paint the camo on when I have finished the covering. This thing is small......... I dont like the way the elevator functions as it is "v" notched in the rear and likes to flex when it moves up and down, the side the control horn is on has more movement than the other. I need to figure out a way to brace it so they move evenly without messing up the appearance.
[img][/img]
[img][/img]
Last edited by cribbs74 on Sat Dec 03, 2011 11:19 pm; edited 1 time in total (Reason for editing : Word choice)
Guess it'd take some surgery, but I usually used a round toothpick to connect the two surfaces. I'm sorry that it didn't occur to me to mention this earlier! Maybe you can notch into both surfaces (from the bottom side) and also cut a notch in the rudder post, then slip the toothpick in to be CA'd.
cribbs74 wrote:OK here is the progress so far, basically I have covered most of the Spit with the exception of the aft fuselage. I installed the control rods, engine and modified the cowl to accept the TD .010. I used olive drab monocote and will paint the camo on when I have finished the covering. This thing is small......... I dont like the way the elevator functions as it is "v" notched in the rear and likes to flex when it moves up and down, the side the control horn is on has more movement than the other. I need to figure out a way to brace it so they move evenly without messing up the appearance.
[img][/img]
Nice plane!
Can't wait till its done!
Will you be getting a video?
Indra
Kim wrote:Guess it'd take some surgery, but I usually used a round toothpick to connect the two surfaces. I'm sorry that it didn't occur to me to mention this earlier! Maybe you can notch into both surfaces (from the bottom side) and also cut a notch in the rudder post, then slip the toothpick in to be CA'd.
Kim,
I used balsa to make doublers, there is actually four extra pieces of 1/16 balsa in there to beef up that notch. Toothpick didn't even cross my mind. I could carefully unglue and recover or I could do what you said
nitroairplane wrote:cribbs74 wrote:OK here is the progress so far, basically I have covered most of the Spit with the exception of the aft fuselage. I installed the control rods, engine and modified the cowl to accept the TD .010. I used olive drab monocote and will paint the camo on when I have finished the covering. This thing is small......... I dont like the way the elevator functions as it is "v" notched in the rear and likes to flex when it moves up and down, the side the control horn is on has more movement than the other. I need to figure out a way to brace it so they move evenly without messing up the appearance.
[img][/img]
Nice plane!
Thanks Indra,
Sure! I could video the inevitable crash for you.
Indra
microflitedude wrote:How much does she weigh?
Looks nice!
3.15 ounces including battery and servos. I don't have a receiver yet but I am hoping to keep it at 4 oz dry. We shall see. I plan on using a 3 blade .020 prop, Nitro said to keep the weight down due to lack of thrust. I like the look of a 3 blade better. Seems to be a better "fit" for a Spit.
Ron:
Know that I'm hanging on every Spit' post that you make. Your observations will be of great assistance when I build the larger vesion of the Guillow's Spit' which I BELIEVE (and hope) will arrive for Christmas.
"Standing on the shoulders of a pioneer" is always helpful.
Carry on!
Carry on!
"I dont like the way the elevator functions as it is "v" notched in the rear and likes to flex when it moves up and down, the side the control horn is on has more movement than the other."
You'd probably get great flick rolls though!
Ivanhoe- Diamond Member
Ron jut though I would remind you that monokote is like the heaviest covering around
Carry on!
Thanks SD,
That means a lot coming from you! If you decide to use a modern covering try and find one with a flat finish. The monokote is a bit too glossy for my liking. I think they make a flat clear coat and I may frost the entire plane with it to dull the finish and seal the decals. Another thing I learned the hard way is that when monokote shrinks it likes to warp. Took me a while and a few recoverings to set the dihedral back to where it is supposed to be.
nitroairplane wrote:Ron jut though I would remind you that monokote is like the heaviest covering around
Indra,
I did not know that! The good thing is since the model is so small it didn't add much weight. I think on a large plane it would definitely be an issue. Hindsight is always 20/20.
Ivanhoe wrote:"I dont like the way the elevator functions as it is "v" notched in the rear and likes to flex when it moves up and down, the side the control horn is on has more movement than the other."
If I was an accomplished pilot that might be ok, for now I am looking for stability. I don't want my elevator to be an aileron. I am beefing up my skills with a park zone playmate. The last 3 flights I have managed to not crash. This thing however will fly totally different. I only have 30 sec of experience with a low wing and it ended very badly. I am wary about flying my Sig hummer again.
cribbs74 wrote:Ivanhoe wrote:"I dont like the way the elevator functions as it is "v" notched in the rear and likes to flex when it moves up and down, the side the control horn is on has more movement than the other."
No pilot, no matter how experienced, could handle an asymmetric elevator!
The main problem with any model of a fighter is that the fullsize aircraft has GOT to be inherently unstable in order to make it manouverable enough in combat, extra dihedral on the model helps, as does a larger tailplane (Hor.Stab) but because the CG is above the wing the danger of sideslips, or rolling is always present, you get no pendulum stability as you do with a high or shoulder wing.
well as long as the asymetrical elevators are the same all the time, ou can fly. its just takes a lot of time and the tendancy to manualy mix elevator with right aileron and some rudder on final. dont ask me how i know that
that plane flew, but it sucked so bad i redid the elevator not long after.
nemoskull- Silver Member
» building a Guillows kit P 40
» Set of two Cox engine R/C airplane or micro electric park flyer epoxy canopy parts
» The Official "International Cox PT-19 Fly It If You Got It Day!" Thread
» Super Day at Buder Park !!!!
» Fly-in pictures from Delta Park 09/02
Page 4 of 8
