Restoring a  Corsair for a friend. Cox_ba12
Restoring a  Corsair for a friend. Pixel
by roddie Today at 7:17 pm
by TD ABUSER Today at 3:13 pm
by Ken Cook Today at 2:41 pm
by Ken Cook Today at 2:37 pm
by getback Today at 12:52 pm
by roddie Today at 11:43 am
by GallopingGhostler Yesterday at 4:04 pm
by roddie Yesterday at 2:13 pm
by sosam117 Yesterday at 12:32 pm
by rdw777 Yesterday at 10:24 am
by rsv1cox Wed Nov 20, 2024 4:21 pm
by rsv1cox Tue Nov 19, 2024 7:35 pm
Restoring a  Corsair for a friend. Empty
Restoring a  Corsair for a friend. Empty Restoring a Corsair for a friend.
Post  WingingIt74 Tue Oct 08, 2013 4:13 pm
A friend of mine has one and he thinks the fuel tank is missing. What does it look like?
WingingIt74
WingingIt74
Restoring a  Corsair for a friend. Empty Re: Restoring a Corsair for a friend.
Post  pkrankow Tue Oct 08, 2013 4:51 pm
http://coxengines.ca/cox-049-rtf-fuel-tank-1-3-oz-plastic.html
maybe this?
Post  WingingIt74 Tue Oct 08, 2013 4:53 pm
Not sure, I know that's the one in the PT-19 and F-15. I haven't seen the Corsair yet.
WingingIt74
WingingIt74
Post  WingingIt74 Tue Oct 08, 2013 5:14 pm
Per this:
https://5dbfd882-a-62cb3a1a-s-sites.googlegroups.com/site/coxengineforumfiles/Corsair%20II.pdf?attachauth=ANoY7cqBxM0sPe2Xw0gZl2MklRkaZGJr8J27ir8dJrt0vEObITzQ4J1k7QxpRmN8ffzKfDUSf_SFt4ogKjSprPgEVv63DqZ2PhCZEn0-MRw0SZtKTPsHWWE6Ut4rfqBrej_6T9VuY0q0PuAlZ1D3qxylMbta4qVm7TCTGOncQMYGmZsyreMA3ZYxq6yrJEapkdVmKPl0vTmKpS1_1LthBEHyteHG3XfxL_dgvX-zvQUFfQJkBPbbQxI%3D&attredirects=0
The fuel tank is part of the lower cowling, is that correct?
WingingIt74
WingingIt74
Post  roddie Tue Oct 08, 2013 9:09 pm
Travis, yes... if you watch this vid, (scroll to 03:00) you'll see what the tank/lower cowling looks like.
https://www.coxengineforum.com/t2586-assemble-a-cox-049-corsair-in-five-minutes?highlight=corsair
The one Bernie sells isn't the one. Maybe he can mount a 1/3 or 1/2 oz. wedge tank in there somehow? ...or just make a tank from a plastic 35mm film canister... looks like it would be close to the size... maybe a little too tall though. It only needs a supply fitting on the bottom and a vent on the top.
Post  pkrankow Tue Oct 08, 2013 10:11 pm
Non-pressure bladder. Stuff a balloon with a piece of brass tubing in and push fuel in. Super easy.
Many options on this one at least, if this is a runner and not a shelf queen. Wedge tanks and similar are easy too. Pressure bladders are not out either.
Post  RknRusty Tue Oct 08, 2013 10:25 pm
pkrankow wrote:Non-pressure bladder.  Stuff a balloon with a piece of brass tubing in and push fuel in.  Super easy.
Or one of those round bottle type clunk tanks could probably fit in there and work well too. Either Sullivan or Dubro make the heat moldable plastic tanks like that in a 1 ounce size.
Post  roddie Wed Oct 09, 2013 10:39 am
or... one could try a clear-plastic vending machine "toy capsule"... not sure how fuel proof they'd be... but since they pop apart into 2 pcs., it would be easy to install the feed/vent lines. Drill out top/bottom for short length silicone fuel tubing "seals"... and insert brass tubing through the seals for a no-leak/no glue compression fit.
Permanently assemble the 2 halves afterward with the appropriate glue; depending on the type of plastic. I believe the "clear" plastic is styrene; in which case, plastic model cement would work.
Even if eventually the tank didn't hold up to the fuel... the lines/seals could be pulled out and put in another capsule. Maybe a coat of clear polyurethane on the capsule halves... inside and out before assembly, would fuel-proof it?
Post  WingingIt74 Wed Oct 09, 2013 9:20 pm
Ok the fuel tank is all there except the bottom nipple is broke off. Any idea on how to fix it? I'd like to get it running for him.
Restoring a  Corsair for a friend. Img_4610
WingingIt74
WingingIt74
Post  pkrankow Wed Oct 09, 2013 9:27 pm
Brass or aluminum tube pressed and glued in with epoxy or silicone.
Post  RknRusty Wed Oct 09, 2013 9:49 pm
Or screw a muffler pressure nipple into it.
Restoring a  Corsair for a friend. Th_KGrHqEOKooFJNr0KPg7BSVZEzpLY60_35_zps8015196b
$1.00, buy it now on eBay
http://www.ebay.com/itm/like/380724392092?lpid=82
Post  WingingIt74 Wed Oct 09, 2013 10:00 pm
I was thinking both ideas... I'll have to see what the hobby shop has...
WingingIt74
WingingIt74
Post  pkrankow Wed Oct 09, 2013 11:45 pm
RknRusty wrote:Or screw a muffler pressure nipple into it.
I like that idea. I will try to remember it for later.
Post  WingingIt74 Thu Oct 10, 2013 12:34 pm
Any one have a red small rubber spinner and a LH spring/round cam (not hex)? These are the only parts he is missing so far.
See my want ad:
https://www.coxengineforum.com/t5753-wtb-corsair-parts#72151
WingingIt74
WingingIt74
Post  WingingIt74 Fri Nov 08, 2013 8:39 am
Thanks all for the suggestions.  I got it running last night.
I'm till looking for a red rubber spinner for it, if anyone has a spare.
WingingIt74
WingingIt74
Post  SuperDave Fri Nov 08, 2013 10:00 am
Advise that you ask your friend if he intends to fly the plane and if he has any experience doing so.
It would be a shame to go to invest the time,work and expense of restoration only to have it crashed and quite possibly destroyed by an inexperiened CL pilot.
Better to learn to fly CL with a simple profile "slab wing profile" than and valueable Cox plastic Corsair and risk further damage.
SD - "The voice of experience" sunny
BTW: Be sure any adhesives used are FUEL-PROOF. Huh...
SuperDave
SuperDave
Post  WingingIt74 Fri Nov 08, 2013 10:16 am
He says he has flown them when he was a kid. I told him he can do whatever he wants, I'm just the mechanic Smile
WingingIt74
WingingIt74
Post  SuperDave Fri Nov 08, 2013 10:31 am
Travis:
A "kid" and now are two different realities.
You might a least caution him per above. That's what friends are for.
SD
SuperDave
SuperDave
Post  WingingIt74 Fri Nov 08, 2013 10:36 am
I know Dave Very Happy
WingingIt74
WingingIt74
Post  Kim Fri Nov 08, 2013 10:45 am
Yo! I MAY have a skinny spinner !! I'm staggering my way toward the shop now...back in a bit...
Post  SuperDave Fri Nov 08, 2013 10:47 am
Travis:
I can think of lots of things I did as "kid" that I can no longer do. Strange how that works isn't it?
SD
SuperDave
SuperDave
Post  Kim Fri Nov 08, 2013 10:57 am
This the one?????
Restoring a  Corsair for a friend. 110
Post  WingingIt74 Fri Nov 08, 2013 11:19 am
That would be the one Kim! Let me know how much I owe ya.
WingingIt74
WingingIt74
Post  roddie Fri Nov 08, 2013 11:30 am
NICE JOB Travis!!!! Clapping Thanks for posting the vid! Does that Corsair use a standard 5 x 3 prop?
Post  WingingIt74 Fri Nov 08, 2013 11:31 am
Uses a Left Hand 3-blade prop, which turns in the opposite direction as standard.
WingingIt74
WingingIt74
