» So Cool If you haven't seen it by getback Today at 5:25 pm
by rsv1cox Today at 5:05 pm
» Ode to a dead cat
by rdw777 Today at 3:28 pm
» COX .020 RC PROJECT
by rdw777 Today at 3:21 pm
» Peewee power
by rdw777 Today at 3:04 pm
by rsv1cox Today at 8:53 am
» some pics....
» Thrust Washer
5-40 nuts for using a prop-stud
Hey all, Thought I'd throw this out there for anyone wanting to try them.
Running a 5-40 prop screw or "stud" all the way into the crank, is said to strengthen the front crank-housing in the event of a hard impact.
Some of us use long screws and cut them to size... so why not make a "stud" and secure your prop with a nut and washer? or a heavier "brass" nut/washer (tail heavy?)... or a "lock-nut" (no explanation needed...)
McMaster-Carr Co. carries 5-40 size hardware, for a variety of our uses.
STUDS
http://www.mcmaster.com/#standard-threaded-rods/=okay2i
LOCK-NUTS
http://www.mcmaster.com/#hex-locknuts/=okazsp
HEX NUTS
http://www.mcmaster.com/#hex-nuts/=okb0ao
WASHERS
http://www.mcmaster.com/#standard-flat-washers/=okb3kp
They also stock 5-40 hex head cap screws, as well as traditional slotted screws, in the lengths we typically need. (check out their selection of 2-56 screws too)
STUDS
LOCK-NUTS
HEX NUTS
WASHERS
» Norvel/AP .061 prop stud size compared to 5-40 stud
» Wanted: Prop Nut and Stud .049
» Help fixing model with very wrong CG
» This is nuts
» MY FIRST PROP ROD !!! AT age 57
» This is nuts
