Latest plane. Finished yesterday, maidened today Cox_ba12
Latest plane. Finished yesterday, maidened today Pixel
Latest plane. Finished yesterday, maidened today Empty
Latest plane. Finished yesterday, maidened today Empty Latest plane. Finished yesterday, maidened today
Post  batjac Tue Sep 03, 2013 2:43 am
So, since the Delta Park fly-in was today, I needed a new plane to fly there.  I decided I wanted to do a PeeWee powered plane, so I dug around for designs for the .020.  I settled on the Little Gem from the June 1961 issue of Model Airplane News.  It had a few unique things about it that made it my choice for the next building project:
1) It was old Vintage.
2) It had an offset fuselage.
3) It had a diamond airfoil.
4) It wouldn't take up too much of my on hand balsa.
5) I could fly it all day on two ounces of fuel.
As usual, I forgot to take a picture of the "kit" I cut out from my wood supply.  I was almost finished with the wing before I remembered to get the camera:
Latest plane. Finished yesterday, maidened today DSCN0623_zps590c1094
And gluing on the leading and trailing sheet.  Diamond airfoils were a fad for a while back then.  I don't know that they had any flying advantage, but I wanted to try building one as I figured it'd be easy to build the wing flat on the board with the straight angles, instead of a curved airfoil that would need a jig to build.
Latest plane. Finished yesterday, maidened today DSCN0625_zps06cc5ba0
The wing, minus the center section, and the rest of the "kit".
Latest plane. Finished yesterday, maidened today DSCN0627_zps378d6155
Mounting the bellcrank.  The plans call for an aluminum sheet bellcrank, but I find that it's easier for me to just cut one out of 1/16 ply and put a layer of thin CA over it to harden it.  I've done this with two other planes, as it's cheaper for me to use my scrap ply than the $2.00 Goldberg bellcranks from Cox International (sorry Bernie).  I just trade an hour of fabrication for the $2.00 for the plastic ones.  I guess my time is pretty cheap.  Time will tell if they last.
Latest plane. Finished yesterday, maidened today DSCN0628_zpsc42fc525
The parts covered and ready for final assembly.
Latest plane. Finished yesterday, maidened today DSCN0630_zpsa9febef9
And assembled, waiting for the motor.  I had to test run the motor and get it tweaked in before mounting.
Latest plane. Finished yesterday, maidened today DSCN0632_zps0101f00f
With the motor mounted.  This is my $6.00 eBay PeeWee.
Latest plane. Finished yesterday, maidened today DSCN0638_zps2c07c050
The plane ready to fly weighs 2.25 ounces, or for our friends across the pond, 64 grams.
Latest plane. Finished yesterday, maidened today DSCN0636_zps0c1436cd
Latest plane. Finished yesterday, maidened today DSCN0637_zps1d34f606
At first, I was a little worried that it'd be really squirrely, since the bellcrank holes are only about 1 1/8" apart.  But, it was okay after I got a toss from Duke's eldest son.  But, on 18' lines, this thing was FAST! I tried counting, and it seemed like I was doing about 2.5 second laps.  this was with the standard 4.5x2 Cox prop.  The MAN article says to use the 3 bladed prop if using a stooge for great verticals and for speed.  I don't even want to know how fast this thing would be on the 3 bladed prop.
The Vintage Mark
Latest plane. Finished yesterday, maidened today Empty Re: Latest plane. Finished yesterday, maidened today
Post  Cribbs74 Tue Sep 03, 2013 8:16 am
Mark,
I built one of those too for my son. I didn't offset the wing and I chose to sheet the entire wing. It flies ok.
I too built a bellcrank out of ply. I am using the 3 blade prop.
Your's looks great! Here is a pic of mine.
Latest plane. Finished yesterday, maidened today 6Mcz87Ol
Post  duke.johnson Tue Sep 03, 2013 8:52 am
Mark let my son fly this little plane yesterday and now wants to build one. He loved it!
duke.johnson
duke.johnson
Post  andrew Tue Sep 03, 2013 8:56 am
The Lil' Gem was my first scratch-build; the full size plans were a pullout in MAN, circa 1961.  I didn't have a .020, but did have an .049 from a COX plastic Cub, so I scaled it up a little larger.  I don't remember if I built it with the offset or not.
Latest plane. Finished yesterday, maidened today Little10
Post  batjac Thu Sep 19, 2013 5:55 pm
Cribbs74 wrote:Mark,
Ron, that looks great! I was thinking about doing another one without the offset like you did. I have another fuse cut out, so I could just do another wing and tail set. I was thinking of making the wing tips and tail tip diamond shaped also, just using a wing rib cut in half to give the half-diamond shape. And maybe making the snout a little more pointed also.
The Pointed Mark
Post  Cribbs74 Thu Sep 19, 2013 8:55 pm
Mark,
I would consider adding some offset. As designed it has no tip weight or rudder offset. While rudder offset is not really needed without engine offset I feel it would go slack in anything besides a large flowing inside loop. Not to mention it may have a tendancy to roll in without the tip weight.
Just a thought, I haven't given mine enough of a workout to get a true feel of things. For some reason my controls are stiff and need to be looked at. It was my second or third scratchbuild and I did things I would not even consider doing now.
The Jr. Falcon decals were for my then 6yr old son. He wanted something on the wing and I had those laying around.
