Cleanin 020 cylinder bore Cox_ba12
Cleanin 020 cylinder bore Pixel
by roddie Today at 9:22 pm
by roddie Today at 8:58 pm
Cleanin 020 cylinder bore Empty
Cleanin 020 cylinder bore Empty Cleanin 020 cylinder bore
Post  ebeneezer Fri Feb 15, 2013 2:37 pm
Having now switched the cyinder and piston off my peewee onto my now, unsiezed TD 020, it runs great now. I now have a 020 cylinder whose piston wont pass where it was siezed. It's as if theres ridge of soms sort. However I can't see or feel anything I just wondered if it is possible to remove it, or try and polish it out with something.
Cheers Cleanin 020 cylinder bore 4201307885
ebeneezer
ebeneezer
Cleanin 020 cylinder bore Empty Re: Cleanin 020 cylinder bore
Post  Cribbs74 Fri Feb 15, 2013 2:43 pm
Could it be a burr? They are hard to see and feel. Thin wall cylinder?
Post  ebeneezer Fri Feb 15, 2013 3:03 pm
I suppose it could, right off then?
ebeneezer
ebeneezer
Post  Ken Cook Fri Feb 15, 2013 3:24 pm
I've had a lot of success with lapping in the piston. I would find yourself some form of tubing that fits into the underside of the piston. From the skirt up to the top of the piston crown is tapered on the inside. My experience is with .049's, but I'm assuming the same applies here. If the tubing is loose into the underside of the piston, wrap some tape around the tubing until the piston has to push on. Insert the piston into the bore but install it upside down so that the skirt is at the top. The tubing will work as a handle and you can use various polishing compounds. When I'm trying to limit the material being removed, I use liquid metal polish. I've had very good success using white rubbing compound as well. You twirl the tubing holding the piston in a up and down motion. You focus on the area that you may think is where the damage is located and don't spend time at the top of the cylinder bore. Make sure all traces of this are washed and hot soapy water works well followed by a heat gun to dry. I use compressed air as well as I don't want water trapped in the ball socket joint. Follow up with assembly and a good oil . Ken
Post  Cribbs74 Fri Feb 15, 2013 5:11 pm
ebeneezer wrote:I suppose it could, right off then?
No it's salvageable, I have never cleaned up a burr like Ken just suggested, but it sounds doable that way.
I usually just find the burr and scrape it away with a knife or if it's sizeable use a round file. You could probably do what I suggested followed by what Ken suggested and have a really nice cylinder when you are done. Either way you can't go wrong.
Post  ebeneezer Sat Feb 16, 2013 1:30 am
Thanks guys. I'll give it a go, I'll let you know how it goes Cleanin 020 cylinder bore 4201307885
ebeneezer
ebeneezer
Post  ebeneezer Sat Feb 16, 2013 8:48 am
Thanks Guys, Mission accomplished. You were right I thing there was a burr on the inside of the port. Possibly from cylinder removal. Anyway PeeWee running like a bird again now, they seem to be so dependable, Like the Babe Bee, I just love 'em to bits. One more question because the red anodising is damaged, is it easy to polish it off. I fancy a nice polished ali tank. Very Happy Very Happy Very Happy
ebeneezer
ebeneezer
Post  RknRusty Sat Feb 16, 2013 9:32 am
Bravo, another one saved! Can't tell you about removing the anodizing. I do believe it's better to have it on the inside of the crank tube.
Post  Cribbs74 Sat Feb 16, 2013 10:11 am
If you want to remove the red anodize then chuck it in the drill and use fine sandpaper and sand it away. I have a couple scrap tanks. I will try it on one today and get back to you. That way you don't ruin one of your good ones.
Post  ebeneezer Sat Feb 16, 2013 11:42 am
Thanks Ron. That's what thought. Cleanin 020 cylinder bore 4201307885
ebeneezer
ebeneezer
Post  Cribbs74 Sat Feb 16, 2013 11:55 am
It works!
I used 180 grit to get the anodize off, then jumped to 1000grit to clean it up. Took all of 3 minutes.
Cleanin 020 cylinder bore ToktyUB
Cleanin 020 cylinder bore MolGJYc
Cleanin 020 cylinder bore HMpYtDC
Post  ebeneezer Sat Feb 16, 2013 12:18 pm
Thanks, that looks great. I will then polish it with some autosol.
ebeneezer
ebeneezer
