"Spook" can it be done?
Page 4 of 4
Page 4 of 4 • 1, 2, 3, 4
Here are the rib templates that I have
All: Here are the rib templates that I have. The Top one is what Ron and I were going to use at first, but we thought the chord was too thick for a TD .020 engine and I thinned the chord to the bottom template. As you can see the top template is the same as the wing profile so you would have to thin the rib the thickness of the sheeting on both sides, usually 1/16 inch sheet balsa. The 2nd idea was to use a 1/4 inch triangular balsa piece for the leading edge and shape it for best wing profile and use 1/16 inch balsa sheeting on the trailing edge and shape the trailing edge as well. In the end we went with a "D" shaped leading edge and a triangular piece for the trailing edge and cut the appropriate amount off the ribs. It was easier to slot the leading and trailing edges and insert the ribs than trying to shape both leading and trailing edges to match the profile of the ribs-wing.
NOTE: On the bottom rib template the top shape is more uniform than the bottom so I would copy the top side, then turn the template over and copy the top side, now reversed, to the bottom of the ribs as you cut them. I used a jig saw to cut up to 4 sheets of ribs at a time, reversing the template each time.
Also note a 1/8 X 1/4 slot shown on the top and bottom of the rib template. I used a 1/8 X 1/4 inch piece of spruce hardwood for wing reinforcement. A 1/8 X 1/8 inch piece could be used to save a little weight.
I also considered using lightening holes or slots in each rib, but it seemed that would make the balsa rib too weak.
Top rib 6 inch X 1 1/8 inch thickness, bottom rib 6 inch X 15/16 inch thickness. adjust ruler accordingly.
See above posts for other pictures of the original Spook .020 build
happydad
happydad
happydad- Rest In Peace
Re: "Spook" can it be done?
kools...i always thought the spook was a 0.49 powered machine..as that is what i was hopeing to builds...i only have one 020 bee an its in use already
ekitten2- Gold Member
it is, fullsize
ekitten2 wrote:kools...i always thought the spook was a 0.49 powered machine..as that is what i was hopeing to builds...i only have one 020 bee an its in use already
the fullsize 24 inch version was for the .049, but Ron C. wanted a smaller version for the TD .020, so I made the smaller rib, and slightly smaller Spook .020 plane.
HD
I may have that in 1/2A ekitten2 Pdf. file let me LOOK Still looking ... No NO no I guess Not give me a minute. Eric
My Spook don't look nothing like that one ??? This is on paper 's and I don't remember where I got it from right off. If there was a Pdf. file I don't have it could have came in the mail?? Eric ? OK I found it at HPB far right http://www.hippocketaeronautics.com/hpa_plans/search.php?show_result=1&mode=search&action=removefromlightbox&id=2789
Last edited by getback on Sun Nov 01, 2015 9:13 pm; edited 1 time in total (Reason for editing : Link to wrong plane)
I have sent the Spook plan to Hip Pocket and it is now on line if anyone wants a copy. I tried to add the Mine Nemesis but Ratz says that model airplane news is still selling the plan. I have another practice 1/2A plane that was in the MACA news letter years ago and I will send that one to Hip Pocket if I can find a copy. It was actually a better design than the Mine Nemesis.
faif2d- Bronze Member
Fullsize Plans
faif2d wrote:I have sent the Spook plan to Hip Pocket and it is now on line if anyone wants a copy. I tried to add the Mine Nemesis but Ratz says that model airplane news is still selling the plan. I have another practice 1/2A plane that was in the MACA news letter years ago and I will send that one to Hip Pocket if I can find a copy. It was actually a better design than the Mine Nemesis.
Ron C. and I both have fullsize drawings of the original Spook. The plans are roughly 4 x 6 feet. If any one is interested I can scan portions of the plan at 8 1/2 X 11 inches or 11 x 14 inches and send the files, or I can send you the original print ONLY if you promise not to build over the plan. What I did was copied each section I was working on, cut and pasted the 8 1/2 x 11 inch sections together and put a layer of waxed paper on top and built over that.
happydad
This is the email I received from Steven Fauble...
"Please feel free to send this around to the rest of the guys that are interested."
Along with that note was a copy of the 1/2A Nemisis plans. Pretty sure Steve is the designer so if he is willing to share the plans then Hip Pocket shouldn't have any beef about it.
Yes I am the designer of the Mini Nemesis but I think Ratz does not want any hassle. As I said the Whetstone MK IV is a better flying plane and I hope that it will be up soon. I had a Sickle F2D design that when scaled down made and even better design but I can not find a plan so I guess that 1/2A will remain unpublished.
faif2d wrote:Yes I am the designer of the Mini Nemesis but I think Ratz does not want any hassle. As I said the Whetstone MK IV is a better flying plane and I hope that it will be up soon. I had a Sickle F2D design that when scaled down made and even better design but I can not find a plan so I guess that 1/2A will remain unpublished.
Well, don't I feel dumb now
I think I understand a little better. I guess it's not a big deal as those who want the plan will still have access.
I just added the plan of the Whetstone IV to my gallery. It is not very clear but if you Right click and "save as" somewhere on your computer it becomes clear. The ribs tail and stuff are full size with a dimensioned drawing of the plan form. It does tend to come out tail heavy with a teedee so keep the aft end as light as possible. I had machined some brass spinners and that helped with the CG on all the combat planes.
Well Thank You for the input and designs Sir, and could you or some one supply the link Please , Eric
Thank You ! saved
Did You get this Robbasdog ... http://www.hippocketaeronautics.com/hpa_plans/details.php?image_id=7942&mode=search Thanks to faif2d , getback
Yep, got that, many thanks! The photo-construction is a great help too, it's been a few years since I made any balsa-dust, so I guess I'm back on the learning curve again.
Robbasdog- Silver Member
» You don't see this often.....
» Box-o-Engines has Arrived!
» Any Spook flyers out there??
» Please, need some help to identify a Baby Bee ?
» Glue and covering adhesive for Cox Spook
Page 4 of 4
