compressor for cox radial Cox_ba12
compressor for cox radial Pixel
by batjac Today at 10:05 pm
by gkamysz Today at 9:29 pm
by roddie Today at 9:22 pm
compressor for cox radial Empty
compressor for cox radial Empty compressor for cox radial
Post  cox radial Thu Dec 20, 2012 2:45 pm
rear of compressor
Last edited by cox radial on Thu Dec 20, 2012 3:01 pm; edited 2 times in total (Reason for editing : no picure)
cox radial
cox radial
Moderate Poster
Moderate Poster
compressor for cox radial Empty cox compressor
Post  cox radial Mon Jan 07, 2013 12:05 pm
compressor for cox radial Cox319
Last edited by Admin on Mon Jan 07, 2013 12:11 pm; edited 1 time in total (Reason for editing : Fixed image)
cox radial
cox radial
Moderate Poster
Moderate Poster
compressor for cox radial Empty Re: compressor for cox radial
Post  Shnitzl Sun Jan 13, 2013 6:47 pm
nice same design I will be using Smile
have you run yours?
Shnitzl
Shnitzl
Bronze Member
Bronze Member
Post  ekitten2 Fri Jan 18, 2013 8:48 am
ohh wow thats friggen grouse
ekitten2
ekitten2
Post  TheotherGeoff Wed Jan 23, 2013 6:41 pm
I do hope you will succeed. There are a couple of engineers on RC Groups who swear a vane type compressor will not work at this size. I think it will. Check out the RCG engines forum for details, since as a newbie I can't post a link.
The other Geoff
TheotherGeoff
TheotherGeoff
Moderate Poster
Moderate Poster
Post  RknRusty Wed Jan 23, 2013 8:32 pm
If you're talking about iamplanecrazy's thread, it's turned into a real mudfight over that subject.
http://www.rcgroups.com/forums/showthread.php?t=1362796
The last few pages are getting tense.
Post  Jason_WI Wed Jan 23, 2013 8:48 pm
It's only heated because of one tool posting in that thread. I have him blocked so his posts don't show up on RCG. I believe he was banned on RCU for doing the same thing over there. It gets old fast.
Jason
Jason_WI
Jason_WI
Post  pkrankow Wed Jan 23, 2013 9:03 pm
Are there springs loading the vanes or is it just centripetal forces keeping it sealed and outside?
Post  Jason_WI Wed Jan 23, 2013 9:07 pm
Every vane pump I have worked on they are pushed out by centrifugal force. The only spring loaded device I have encountered in an engine are apex seals in the OS Wankel engine.
Jason_WI
Jason_WI
Post  TheotherGeoff Thu Jan 24, 2013 11:29 am
I had suggested to iamplanecrazy that he consider the very light carbon rotor and vanes from a forced air kerosene heater. He's built his radial with only a drill press and a good imagination, so is severely lacking in machinery! The nay-sayers jumped all over me, swearing that friction losses would exceed output with my suggested vane & rotor.
Jason, does your avatar show a rear rotor Olympic? Do you have a disassembled photo somewhere?
Geoff Mk II
TheotherGeoff
TheotherGeoff
Moderate Poster
Moderate Poster
Post  cox radial Tue Jan 29, 2013 8:07 pm
This compressor has spring loaded vanes to insure constant contact with case. I tested compressors without springs and sometimes vanes failed to slide out properly, I think due to fuel causing sticking and the light weight of the vanes. Also tolerances have to be close to make a good seal. This is one proto type. Other options would be a larger diameter compressor or a longer compressor for more volume. The goal is to make the engine look realistic in size as well as run properly. I also have in mind a 6 cylinder radial with 3 cylinders running the engine and 3 pumping fuel under pressure. I am also about half way finished with a cox outboard motor. I hope to post pictures in near future.
cox radial
cox radial
Moderate Poster
Moderate Poster
