Foam wing iron on covering Cox_ba12
Foam wing iron on covering Pixel
Foam wing iron on covering Empty
Foam wing iron on covering Empty Foam wing iron on covering
Post  crankbndr Fri Jul 13, 2012 8:37 pm
Anyone ever use an iron on covering over foam wings, I was thinking about trying it, would need a low temp covering.
Any advice would help. Thanks
Foam wing iron on covering Empty Re: Foam wing iron on covering
Post  fit90 Fri Jul 13, 2012 8:44 pm
I used to use econokote on Ace foam wings back in the 80's. I don't know if it is even around any more or what it is called if it is around. I would bet that Ultracote would work on foam. Just try a small piece of covering on a small spot at all necessary temps.
Good luck and keep us all posted.
fit90
fit90
Post  andrew Fri Jul 13, 2012 10:10 pm
I've used it and don't like the results of any plastic over foam. Both Ultracote and Econocote are supposed to have low temperature applications. Even though I got it to stick, the result looked like I had covered a cobblestone road.
Post  John Goddard Sat Jul 14, 2012 3:48 am
When we used to do it the foam was always covered with an obeche
Vaneer first,
Very Happy
John Goddard
John Goddard
Post  gcb Sun Jul 15, 2012 11:58 am
crankbndr wrote:Anyone ever use an iron on covering over foam wings, I was thinking about trying it, would need a low temp covering.
Try here: http://home.earthlink.net/~philcartier/webcat/catalog.html
Phil Cartier is a noted CL Combat guy and sells foam wings, kits, and coverng. He advertises in Flying Models every month.
gcb
gcb
Post  Ken Cook Sun Jul 15, 2012 12:26 pm
I use Phil's covering quite a bit. It takes some getting used to like anything else. Phil does an excellent job covering the planes he sells as ARF combat planes. On compound curves it can be a little tough. Practice usually gives terrific results. Seeing that we don't require paint schemes on combat foamies we generally use colored tissue glued with white glue followed with Phil's SLC covering. The covering though has been treated chemically and will accept paint as well as glue.
When we build combat foamies, we iron on strips of SLC covering to the root of the wing of both sides and then glue together using Gorilla glue. Your actually gluing covering to covering. It's unbelievably strong and Phil had to prove this to me initially stating that it was stronger than gluing foam to foam. SLC covering however after due time will lift if oil gets under the overlap as will every other iron on covering. Phil many times paints his foamies with Rustoleum over the SLC. He's done some pretty cool paint jobs on some of his combat warbirds.
Post  crankbndr Sun Jul 15, 2012 12:39 pm
That is a great site for foam info, thanks.
Post  Ivanhoe Sun Jul 15, 2012 5:51 pm
John Goddard wrote:When we used to do it the foam was always covered with an obeche
Vaneer first,
Very Happy
Hey, I remember those wings, some of the first foam wings I ever saw, are they still made like that?
Ivanhoe
Ivanhoe
Foam wing iron on covering Empty re: foam wings
Post  happydad Sun Jul 15, 2012 6:40 pm
Vaneer first,
Very Happy
someone on ebay is selling Ace foam wing replicas. can't remember his ebay name. just go there and search foam wings. i asked if he made an 8inch chord and he said see my website, but i couldn't find an 8inch chord, only the old Ace 5 1/2inch straight , tapered and semisymmetrical. about $10.00 each + shipping.
happydad Small Cox Logo
Futaba Radio
happydad
happydad
Post  andrew Sun Jul 15, 2012 8:17 pm
Steve (Skaliwag on RCU and RCG) has the 1/2A wings on his site. There are listed at the bottom of the page.
He also carries a number of kits and other 1/2A goodies.
Post  ahrma_581 Sun Jul 15, 2012 8:47 pm
Foam wing guy is McClain Wing Cores: http://www.mwcores.com/servlet/StoreFront
He lists a whole bunch of them, but website doesn't seem to provide much in the way of dimensions. Generic cores seem to (I guess) have the wingspan in the part number, but no idea what the chord is. May have to call/email to get all the details.
I think the owner (Jeff McClain) posts on RCG: at least I think I saw someone by that name in a foam wing core thread I was reading a couple days ago.
ahrma_581
ahrma_581
