Crankcase assembly tool stuck!! Cox_ba12
Crankcase assembly tool stuck!! Pixel
by batjac Today at 10:05 pm
by gkamysz Today at 9:29 pm
by roddie Today at 9:22 pm
Crankcase assembly tool stuck!! Empty
Crankcase assembly tool stuck!! Empty Crankcase assembly tool stuck!!
Post  coxxoc Thu May 24, 2012 8:54 pm
Hi friends,
I used a cox crankcase assembly tool for the first time. When I finished
turning it until drive-plate was fully seated into crank and tried to remove
the hub from the stud..guess what? It won`t come out!..It`s stuck!!
Has anybody had this happen to them and what`s the best way to remove hub?
Mr G Flying
coxxoc
coxxoc
Crankcase assembly tool stuck!! Empty Re: Crankcase assembly tool stuck!!
Post  microflitedude Thu May 24, 2012 8:58 pm
Picture? Not quite sure what you mean.
microflitedude
microflitedude
Post  coxxoc Thu May 24, 2012 9:11 pm
Here`s the tool. The left photo shows a bigger pic of hub in stud followed by prop. Can`t take hub out of stud?
Mr G Flying Crankcase assembly tool stuck!! Crankc10
coxxoc
coxxoc
Post  microflitedude Thu May 24, 2012 9:15 pm
Does it move at all?
Put a thick silver wrench on there and twist it off.
microflitedude
microflitedude
Post  Cribbs74 Thu May 24, 2012 9:16 pm
coxxoc wrote:Hi friends,
Mr G Flying
You probably stripped a thread or two. It may be possible to apply pressure under the hub until it catches a thread. Worst case you take a hacksaw and cut the stud between the prop and hub. You will only be out a stud that way. There should be enough stud exposed afterwards to unscrew it from the crank.
You can then re-tap the hub and use a new stud. It should have came with a couple.
Post  coxxoc Thu May 24, 2012 9:23 pm
I don`t want to ruin the thread of the small stud. I can`t put a wrench on it yet.
I was thinking of maybe putting to bolts on other end of stud locked together
and then using a wrench to turn the inside bolt. Maybe that will budge it, but I
would have to put the hub in a vice or something similar.
The stud is not in the prop shaft. The stud is stuck with the hub only.
Mr G Flying
coxxoc
coxxoc
Post  Cribbs74 Thu May 24, 2012 9:54 pm
coxxoc wrote:I don`t want to ruin the thread of the small stud. I can`t put a wrench on it yet.
Mr G Flying
Oh.....
Well, the only reason it is stuck is because the threads are knackered. There really is no other reason unless it's cross threaded and even then the threads are toast. I wouldn't put much effort in saving the stud. The hub however is salvageable. I would advise securing the stud in a vice and working the hub back and forth until it frees up.
Post  RknRusty Thu May 24, 2012 10:14 pm
coxxoc wrote:...I was thinking of maybe putting to bolts on other end of stud locked together
Mr G Flying
That is the way a mechanic would do it.
Post  Cribbs74 Thu May 24, 2012 10:36 pm
Mr G Flying
Maybe Rusty but, a mechanic wouldn't put the part he wants to keep in a vice. Two nuts on the stud is a good idea however, you would need to clamp down on the hub.
The threads are either bad on the stud or the hub or likely both. One of them is going to have to be sacrificed to save the other. I would opt to save the hub.
Post  RknRusty Thu May 24, 2012 11:09 pm
Mr G Flying
Maybe Rusty but, a mechanic wouldn't put the part he wants to keep in a vice. Two nuts on the stud is a good idea however, you would need to clamp down on the hub....
Yeah he would, between a couple of oak blocks and tight as he can lean into it (helps to have a BF vice). Jam it with a Cox wrench or flat bar in case it still turns. Show that mother who's boss.
Post  Cribbs74 Thu May 24, 2012 11:27 pm
Mr G Flying
lol!
Post  coxxoc Fri May 25, 2012 1:12 am
Thanks Rusty I`ll do that!
Mr G Laughing
coxxoc
coxxoc
Post  John Goddard Fri May 25, 2012 5:40 am
You could always send it to me..........
I'd turn it into a beautiful 'hand crafted' paper weight.
Airplane
John Goddard
John Goddard
Post  gcb Fri May 25, 2012 8:56 am
Redneck method:
I'd use a vice grip to remove the stud from the hub, then discard the stud. It has had so many stresses put on it that it may not be safe anyway. Why take the chance.
gcb
gcb
Post  Cox International Fri May 25, 2012 9:12 am
Lot of posting for a small part lol!
Just email nichole@coxengines.ca
and she will send you a few hubs and studs today as, obviously, either the threads on the stud or the hub are defective.
Cox International
Cox International
Official Cox Dealer
http://www.coxengines.com
Post  microflitedude Fri May 25, 2012 9:16 am
Perhaps is was torqued down too much, and damaged the threads.
microflitedude
microflitedude
Post  RknRusty Fri May 25, 2012 11:29 am
Cox International wrote:Lot of posting for a small part lol!
The Man to the rescue!
Post  Kim Fri May 25, 2012 11:49 am
I THOUGHT I heard trumpets !!!!!
Post  fit90 Fri May 25, 2012 5:33 pm
Shortly after I heard the trumpets I saw a tall man in a bright red Mounty unifrom riding a horse with the needed parts in his hands! That's service!!!
fit90
fit90
Post  microflitedude Fri May 25, 2012 8:42 pm
fit90 wrote:Shortly after I heard the trumpets I saw a tall man in a bright red Mounty unifrom riding a horse with the needed parts in his hands! That's service!!!
And he looked like this...
Crankcase assembly tool stuck!! Canadian-mountie-zoom
microflitedude
microflitedude
Post  coxxoc Fri May 25, 2012 8:51 pm
good old Mountys!!
Mr G
coxxoc
coxxoc
