» Stick built rubber powered Scientific ME-109by TD ABUSER Today at 4:07 pm
» Modelsmodels
by rdw777 Today at 4:01 pm
» Ignition Points for Ohlsson 23
by crankbndr Today at 2:29 pm
» 010 head stops glowing
by Cox International Today at 11:00 am
by Cox International Yesterday at 10:35 pm
» Unique Foxie partzie. Potential fishing line/paper weight or something else.
by rsv1cox Yesterday at 2:48 pm
» Cox P-40 Clone Project - I just can’t leave well enough alone.
by akjgardner Yesterday at 10:32 am
» COX .020 RC PROJECT
by TD ABUSER Yesterday at 9:29 am
by roddie Tue Sep 17, 2024 6:51 pm
» some pics....
by roddie Tue Sep 17, 2024 6:21 pm
by GallopingGhostler Tue Sep 17, 2024 9:22 am
by sosam117 Tue Sep 17, 2024 8:58 am
Page 2 of 2
Page 2 of 2 • 1, 2
Re: Stick built rubber powered Scientific ME-109
Good point!TD ABUSER wrote:Well you've had 34 years to cut them out..! Even if you only averaged 3 parts per year, you'd be done by now..!roddie wrote:Look at all these parts needing to be cut-out... When I bought the kit (from Tower back in the 1990's...) I thought it was a die-cut kit..
GallopingGhostler wrote:Good point!TD ABUSER wrote:Well you've had 34 years to cut them out..! Even if you only averaged 3 parts per year, you'd be done by now..!roddie wrote:Look at all these parts needing to be cut-out... When I bought the kit (from Tower back in the 1990's...) I thought it was a die-cut kit..
............ You must have attended CSM Charles... (the Cribbs School of Motivation.. )
If you decide to build that P-38 Roddie here are some tools you may be interested in….They are notching tools for cutting in the notches for stringers and spars…. Just a piece of sandpaper edge glued a piece of balsa the same width as the spar or stringer…. Depth stops are added as required for the depth of the spar….
The Guillows kit I am building is an older die cut version and the fuselage formers and wing ribs were not notched so I used these….. Good to have around in different sizes for general modeling IMO…..1/16x1/16 and 1/16x1/8 in the photo…..
rdw777- Diamond Member
roddie wrote:GallopingGhostler wrote:Good point!TD ABUSER wrote:Well you've had 34 years to cut them out..! Even if you only averaged 3 parts per year, you'd be done by now..!roddie wrote:Look at all these parts needing to be cut-out... When I bought the kit (from Tower back in the 1990's...) I thought it was a die-cut kit..
good afternoon Roddie..I'm just testing your sense of shame...that's all...
TD ABUSER- Gold Member
Page 2 of 2 • 1, 2
» The flight before Christmas:Ace littlest stick powered by throttled Cox teedee 051
» Scratch Built 2 chan Babe Bee Powered plane - The Northern Flicker
» Hand launched rubber powered, whip, and vintage models
Page 2 of 2
