help! it wont start Cox_ba12
help! it wont start Pixel
by 1/2A Nut Today at 7:27 pm
by TD ABUSER Today at 7:18 pm
by Kim Today at 12:35 pm
by Kim Today at 9:18 am
by Admin Today at 1:35 am
» Engine choice
help! it wont start Empty
help! it wont start
help! it wont start Empty help! it wont start
Post  nitros Wed Aug 31, 2011 2:37 pm
today my fuel came and i tested out my engine but it didn't work all that happened
there was fuel leaking out through the crankshaft and propeller driver,
there was also bubbling on the joint between the glow head and the cylinder i took the glow head off and there was no gasket
how do i fix it?
nitros
nitros
Bronze Member
Bronze Member
help! it wont start Empty Re: help! it wont start
Post  SuperDave Wed Aug 31, 2011 2:47 pm
For one, replace the missing head gasket.
Fuel running out of the crakshaft suggests a VERY tired engine that may have but parts value only.
SuperDave
SuperDave
SuperDave
Post  nitros Wed Aug 31, 2011 2:50 pm
could i get it fixed with a new crankcase
the auction info says this "A nearly new Cox 0.49 aircraft engine, this came direct from the agent in Canada, has only been run at factory and once or twice by me"
so it shouldn't me doing this
nitros
nitros
Bronze Member
Bronze Member
Post  RknRusty Wed Aug 31, 2011 2:55 pm
Yeah, just get a new crankcase with a crankshaft already installed. That will cost about $5.95 or so.
Post  nitroairplane Wed Aug 31, 2011 3:07 pm
or you could just be attempting to run it way too rich or flooding it on prime.
that is a common mistake that first time engine users make.
just get a gasket from dens model supplies they are the official UK supplier.
http://www.densmodelsupplies.co.uk/
then just try again you can probably get it to run.
are you still using that massive 8 by 4 prop?
that will stop it from running well.
It is normal for a bit of oil and or fuel to come out of the crankcase.
nitroairplane
nitroairplane
Post  SuperDave Wed Aug 31, 2011 4:23 pm
Not in a two-stroke engine which relies on crankcase pressure to induce fuel.
'The best solution is a simple solution." - from the collected "Timeless Wisdom's of SuperDave Smile
SuperDave
SuperDave
SuperDave
help! it wont start Empty Solution
Post  AT1984 Wed Aug 31, 2011 4:48 pm
But SuperDave...if he doesn't KNOW the solution, that doesn't make it "simple" does it?
lol!
Allen
AT1984
AT1984
Post  SuperDave Wed Aug 31, 2011 5:02 pm
Allen:
All too often the "unwashed" assume the very worst which is seldom the case. The vast majority of problems engines and life have simple solutions.
Very Zen, huh?
SD
SuperDave
SuperDave
Post  AT1984 Wed Aug 31, 2011 5:40 pm
You got me, there. Many times I've tried to think some problem out, and then I get that Homer Simpson "DOH" moment!
I'm truly not experienced enough with the Cox engines to troubleshoot...yet. I'll get there.
Allen
AT1984
AT1984
Post  fredvon4 Wed Aug 31, 2011 7:06 pm
In post # 2 Dave very precisly told you all you need to know
Auction sounds like e-bay
Many folks on e-bay significantly exagerate the conditiion of their goods or they really do not know what they are selling and say what other ads say....odds are you got a well used small engine (if fuel is really puking from the crank at thrust bearing)
No way from your post to know what cox engine. We asume not a collectable unique one, so we think typical 049
Two supporters here on this site will sell you a complete bottom end for under $7 a real good deal...in fact they have several different configurations
They also have all the gaskets, glow plugs, and enough compete parts to build the basic 049s
Or do as I do, don't expect much from used E-bay items and buy new from these folks for not much cash at all
Post  microflitedude Wed Aug 31, 2011 7:54 pm
I think he mentioned earlier it was a surestart. Who sells the engines for $7?
microflitedude
microflitedude
Post  fredvon4 Wed Aug 31, 2011 8:13 pm
complete bottom end = crank case and standard crank shaft... cox international and exmodelengines both have "front end" parts for $5.95 to 9.95
I call it the bottom end in my post...sorry for any confusion
Post  AT1984 Wed Aug 31, 2011 11:21 pm
fredvon4 wrote:In post # 2 Dave very precisly told you all you need to know
Speaking of eBay: I recently bought a Tee Dee .09 on eBay that looked almost brand new. Here is the seller's exact quote, copied from the listing:
"This is a used Cox .09 that is very clean, it is on a nice mount and ready to run."
When I got it, it was on a nylon mount. Like I said, looked almost new. It was locked up solid! Here is what the seller wrote, after I wrote to him and told him "Ready to run doesn't mean locked up".
"Most of these locked up engines will free up quickly by putting a prop on and heating the cylinder with a hairdryer, sorry you had a problem."
Huh? I get to "free up" a "ready to run" engine? Wow...
To his credit, he did totally refund my money, no questions asked, on the spot. AFTER I start the engine, I might pay him what I think my trouble is worth. The engine does look good inside and out, but once I try to start it, we'll see. I did disassemble and clean the TD, and can't tell why it was locked up. No scoring, heat damage...nothing as far as I can tell, other than old gunked up castor...which I expected. Once reassembled it turns like brand new. I can still see what I think are factory hone marks in the cylinder. BTW, I paid less than what most TD .09's are going for.
"Caveat Emptor" is right! I might have to stay away from TD's, and start getting into .049's from the Cox dealers! lol!
Only probelm is I really like TD's, and no one is selling them anywhere else, that I know of.
Sorry...just my "two cents worth" rant on used engines!
Allen
AT1984
AT1984
Post  microflitedude Thu Sep 01, 2011 8:01 am
Pretty much all engines that are frozen will run again - It's just years of hardened oil that will come off easily with the right stuff. Power dissolver, WD-40, fuel, whatever. If he refunded you completely, that was some great customer service!
microflitedude
microflitedude
Post  AT1984 Thu Sep 01, 2011 10:28 am
It was good customer service, even though the description was more than a bit misleading (to me, anyway). That's why I will do as he suggested, and pay him what I think the engine and my time is worth...once i know it runs.
Allen
AT1984
AT1984
Post  Admin Thu Sep 01, 2011 11:19 am
(wrong post) caught myself....
Post  AT1984 Thu Sep 01, 2011 11:48 am
microflightdude:
I found an article on "Flying Lines" about cleaning and maintaining TD .049's. It was a great help with the TD .09. I just used alcohol to soak it, and cleaned the heck out of it. I contacted the author (Barrie Hobkirk), and he was a lot of help, too.
Here's the link, if anyone is interested:
http://www.flyinglines.org/bh.teedee.html
Allen
AT1984
AT1984
Post  microflitedude Thu Sep 01, 2011 12:02 pm
AT1984 wrote:microflightdude:
Allen
Great tutorial, I think ti should be stickied here.
microflitedude
microflitedude
Post  nitroairplane Thu Sep 01, 2011 2:29 pm
Allen
I also prefer front rotor engines I have never been a fan of Redford although I do quite like the pee wees
nitroairplane
nitroairplane
Post  AT1984 Thu Sep 01, 2011 2:38 pm
Nitroairplane:
Redford? You lost me...
Allen
AT1984
AT1984
Post  nitroairplane Thu Sep 01, 2011 4:04 pm
AT1984 wrote:Nitroairplane:
Allen
Sorry I usually use my iPhone on here hence some wrong words being put I. By the autocorrect because it does not recognise names and abreviations.
Redford was what my phone changed reedies to.
Also some of my words are joined by a single letter likenthis
Because I have rather large fingers and the touch screen is über sensitive so when I miss the space bar even slightly I put a letter in by mistake.
So when my spelling or grammar is particularly bad or that a sentence doesent make sense remember I am probably on my phone.
Just tell me if you notice anything and I will be happy to try and correct it.
nitroairplane
nitroairplane
Post  AT1984 Thu Sep 01, 2011 4:24 pm
nitroairplane:
OK, I got it, now...maybe you should turn off the "auto correct" on your iPhone. lol!
I also like the .049's, but with the 8cc tank...preferably the aluminum tank.
Allen
AT1984
AT1984
Post  nitroairplane Thu Sep 01, 2011 4:51 pm
I should but it is hard to type and sometimes it does a good job like correcting simple words. But not scientific ones.
nitroairplane
nitroairplane
help! it wont start Empty Most of my Cox engines .....
Post  Laramie Sat Sep 03, 2011 1:55 pm
..... have come from ebay. I especially like buying the large lots of junk, partial engines, parts etc. I start by cleaning enough parts to build a few, than running them. My best used engines were the ones that were stuck with old castor oil. The ones that tuned & were gummed up were worn worse .....
I also buy piston/cyl. sets, gaskets, glow heads etc from the suppliers that advertize on ebay, with good results so far.
I have yet to be disapointed in my ebay purchasses, but than I dont bid very high, either.
In my expiriance, the Tee Dee engines are the hardest to get going, tune, maintain, etc. There are better NVAs from the after-market that offer better tuning. If one is new to Cox engines, there are easier ones to cut your teeth on, but the Tee Dees offer better performance.
A happy medium is the Medallion line, great for sport flying.
But the Baby Bee always takes me to that warm, fuzzy place .....
Laramie.
Laramie
Laramie
Beginner Poster
Beginner Poster
Post  nitroairplane Sat Sep 03, 2011 2:58 pm
Laramie wrote:..... have come from ebay. I especially like buying the large lots of junk, partial engines, parts etc. I start by cleaning enough parts to build a few, than running them. My best used engines were the ones that were stuck with old castor oil. The ones that tuned & were gummed up were worn worse .....
I cut my teeth on a red and gold tee dee .010 it was what really got me into model flying and building.
Laramie.
nitroairplane
nitroairplane
