» Retail price mark-up.. how much is enough?by Ken Cook Today at 11:08 am
by 1/2A Nut Today at 10:34 am
by rdw777 Today at 10:04 am
by sosam117 Today at 8:15 am
by balogh Today at 7:42 am
Cox LazyBee Arf
Cox LazyBee Arf
Hey All,
So I have done a bit of digging and have not found an answer yet. Was the balsa version of the cox lazybee ARF ever put into production? or just the foam one? I am planning on scratch building a wood one from the factory plans, and was looking for some details that are missing. Thanks!!
makoman1860- Beginner Poster
Re: Cox LazyBee Arf
Cox didn't manufacture a kit of Lazy Bee, only made ARF foam model, at least I know. This model has been manufactured by Clancy Aviation in balsa build-up kit form.
What kind of info do you need about this model?
Levent Suberk- Diamond Member
Re: Cox LazyBee Arf
Levent Suberk wrote:Cox didn't manufacture a kit of Lazy Bee, only made ARF foam model, at least I know. This model has been manufactured by Clancy Aviation in balsa build-up kit form.
I kind of came to the same conclusion that the Balsa ARF must never have gone into production. The spar drawing on the wing was a bit confusing and I was hoping to see one to clear things up.....but.....guess I am on my own. This design is not built like Andy's, as it was intended as an ARF. Thanks!
Re: Cox LazyBee Arf
Hi,
I have those plans as well, but unfortunately they are not built the same as the Cox version. The Cox version had sheet fuselage sides, a single sheer web spar, sheet tail surfaces and a molded upper boot cowl that I will have to make in fiberglass I suppose. Plus this one is only around 35" span. I guess I will just have to start building it and see if it all makes sense!
Re: Cox LazyBee Arf
Kims Lazy Bee has been a testbed for numerous engine combinations. I'm not sure about its construction but it might be worth asking him about it.
Re: Cox LazyBee Arf
Is this of any help? See the current post re. the Lazy Bee
https://www.coxengineforum.com/t14486-clancy-aviation-yard-bee#189844
Re: Cox LazyBee Arf
What I gather, is that Cox was designing both a foam, and a balsa version......and the foam one was put into production while the balsa one was not. So....I guess once I figure this out....it will be the only Cox designed balsa lazy bee out there. Sounds fun!
Re: Cox LazyBee Arf
I was wondering if you have gotten any further on your lazy bee project ? I love lazy bees and would like to see it.
FSTP- Bronze Member
