Landing-gear 1/2-A variations Cox_ba12
Landing-gear 1/2-A variations Pixel
Landing-gear 1/2-A variations Empty
Landing-gear 1/2-A variations Empty Landing-gear 1/2-A variations
Post  roddie Thu Mar 26, 2020 6:34 pm
Landing-gear on 1/2A size (and smaller..) model airplanes is not always preferred.. but I’ve always felt that it adds a scale realism and is also functional.
There are pros and cons, as one can imagine. If a model is intended to launch by ROG (Rise off Ground) then a landing-gear is obviously required. If the model must land on pavement, then it will need an undercarriage to protect the airframe from shock and abrasion. These points I would call “pros”.
Another “pro” is being able to tweak the models’ center of gravity via wheel-weight.. which I would consider to be a functional advantage. The wire-struts can also be adjusted (bent) fore/aft providing additional c/g trimming.
Some “cons” might be the added weight and aerodynamic-drag induced to a model that was built for a certain purpose. A control-line combat model (often a flying-wing) wouldn’t have a landing-gear. Scratch-builders may elect to omit L/G, if none was specified or illustrated on a plan or drawing. Even “if” a gear is shown.. some people don’t want or feel the need to fabricate one. Keep in mind, that a tail-dragger gear-design in a scale-like location on a small model could cause nose-over crashes when taking-off or landing.. especially on a grass field.
Materials usually include music-wire for the strut(s) which must be formed (bent) with an overall length to account for a “mounting” to the model. A strut formation must be long enough (with a subject wheel-tire mounted) to provide adequate clearance for subject propeller(s) and have an axle; long enough to accept a wheel or ski and a retention collar. Wire diameter for “mains” on a 1/2A model is generally .047”/.062”.  (1.2/1.6mm). Music wire in these sizes is relatively easy to source. K & S metals may still offer 36” lengths.. which is what I’ve bought. A single 12” length is generally enough material to form an inverted “V” gear for most half-A tail-draggers. A tail-skid can be as simple as a toothpick or sm. hardwood dowel.
I designed my 1st ever tri-cycle gear for a self-designed profile Lockheed T33 for the CEF 2017/18 Speed Contest. The wire is .062” dia. I used an inverted-“V” for the mains located approx. mid-chord in the fuses’ wing-slot and angled straight-down (90 degrees) The nosegear mount ties-into the lower beam engine-mount; is slightly longer than the mains.. and is angled slightly aft.. in an effort to dampen the shock of landing.
Landing-gear 1/2-A variations Dsc05010
Landing-gear 1/2-A variations Dsc05011
Landing-gear 1/2-A variations Tee-3312
More recently I designed my 2nd  half-A C/L model scratch-build of yet another Lockheed warbird; My profile P38 which I would design a different-style tricycle gear for. Its’ twin-booms/engine-nacelles required independent main-struts to provide for straight-ahead tracking.
Landing-gear 1/2-A variations Dsc05215
Landing-gear 1/2-A variations Dsc05216
Landing-gear 1/2-A variations Dsc05217
Landing-gear 1/2-A variations Dsc05218
Here’s how I did the P38’s nose-gear..
Landing-gear 1/2-A variations Dsc05219
Landing-gear 1/2-A variations Dsc05220
Landing-gear 1/2-A variations Dsc05312
Landing-gear 1/2-A variations Dsc05313
Landing-gear 1/2-A variations 20190829
My very 1st experimentation with a scale-like tail-dragger gear-design was what I came up with for the 1st annual CEF profi-scale speed-contest, in my 16” span model of the Grumman F8F-2 Bearcat/Rare-Bear.
I wanted scale-like (independent) gear-struts.. UNLIKE the common "inverted V"  that is often found WAY up-front on profile model kits.. or saddled in the fuse's wing-slot and strapped-against plywood nose doublers.
A sheet-balsa wing (alone..) would not be enough support for the upward shock of independent gear-struts on a less than graceful landing. I chose to build a 1/8" (3mm) thickness sheet-wing having a half-span hardwood "strip-spar" for two main gear-blocks to mount to.
Note the dark wood in the photo below.. I think it's Mahogany. It won't break..  Laughing
Landing-gear 1/2-A variations 11-14-10
Landing-gear 1/2-A variations 11-18-11
The independent struts were fabricated from .062" (1/16") music-wire and 3/8" square-hardwood (Cherry) blocks.
Landing-gear 1/2-A variations 11-19-13
The assembly is RIGID. The Rare Bear has a 16" wingspan. The 1/8" (3mm) thickness Mahogany strip-spar is 8" long and 3/4" wide. The Cherry gear-blocks are 3/4" long.. and tie-into the strip-spar with #3 X 1/2"L. wood-screws.
This type of strut assy is made by drilling-through the gear-block to receive a straight-length of the strut-wire. The block is then "notched" to accept a short (1/4")  L-bend (90 degrees) which is made in the strut-wire AFTER it is inserted through the block. The lower-strut's length is then measured, cut and bent 90 degrees to form the axle. This assembly is now captive. It's important to be accurate when measuring for the bends. We're making a "pair".. and they need to be the same length. The axle's length can vary slightly.. but if the o/a strut-lengths vary.. it will show-up on static-display.. and there's not much you can do to correct that after the fact. Yea.. it's a bit of fuss, but it makes for a more stout/scale-like main gear.. and if you're like "me".. you find this type of challenge enjoyable. Maybe it's because it's "smaller".. and takes more patience or ingenuity to design/build a particular component?  Huh...
Here are the pair of strut-assemblies with simulated gear-doors made from clear plastic sheet..
Landing-gear 1/2-A variations 11-19-14
The hardwood strip-spar; I ripped a piece of 3/4" (19mm) hardwood to the same thickness of my sheet-balsa wing.. and butt-jointed together with CA. The strip is approx. 1/2 the wingspan.. or 8". It's not terribly heavy for what it does.. and being designed as a speed-model; I wasn't terribly concerned with its overall weight.
Landing-gear 1/2-A variations 1-25-111
The gear-doors are simple to make. The wheel-collar locks them onto the lower-end.. and the upper section is fastened to the gear-block; trimming-out the entire strut assembly nicely.
Landing-gear 1/2-A variations 3-30-112
I have to admit that I enjoy the designing/fabricating/building-processes quite a bit. I wish I had the same patience.. when it comes to finish/painting..
Landing-gear 1/2-A variations Empty Re: Landing-gear 1/2-A variations
Post  NEW222 Thu Mar 26, 2020 8:00 pm
Great tutorial roddie. Thanks for taking the time to do it.
Post  daddyo Thu Mar 26, 2020 8:15 pm
I hadn't seen baking soda used for filler, does that work with C/A glue? Do you find the joint crumbly at all?
daddyo
daddyo
Post  roddie Fri Mar 27, 2020 9:37 am
NEW222 wrote:Great tutorial roddie. Thanks for taking the time to do it.
Thank you Chancey, It's a pleasure for me to share some of my methods here. Smile
Post  roddie Fri Mar 27, 2020 10:14 am
daddyo wrote:I hadn't seen baking soda used for filler, does that work with C/A glue?  Do you find the joint crumbly at all?
I haven't used baking soda as a filler. Sometimes I use baking-soda as an "accelerator" for the C/A glue. Occasionally a C/A glue-joint won't "set". Sprinkling a "pinch" of baking soda over the problem-area usually helps. I believe it has something to do with the two surfaces' to be joined; pH levels. This can also happen when joining dissimilar materials with C/A glue.
Be careful not to use too much of either; C/A or baking soda in areas where a smooth-finish is wanted. IT DOESN'T SAND WELL.. and on balsa.. this can be disastrous.
There are small pump-spray bottles containing a "liquid" accelerator for C/A glues.. usually sold by the hobby-grade C/A manufacturers such as "ZAP". It's sometimes called "Kicker". When a C/A glue-joint sets/grabs.. it's commonly referred to as "kicking". Smile
Post  GallopingGhostler Fri Mar 27, 2020 11:00 am
I've found lightweight synthetic spackling putty or paste sold in home improvement stores and sections in department stores works well to repair imperfections in balsa and foam, dries reasonably quick, is easy to sand.
Post  roddie Fri Mar 27, 2020 5:55 pm
An inverted "V" of .062" (1/16") diameter music-wire, inset into the models firewall. The wheels are wooden craft-store items size 1.5" X .145".
Landing-gear 1/2-A variations Dsc06028
Landing-gear 1/2-A variations Dsc06029
Landing-gear 1/2-A variations Dsc06027
Landing-gear 1/2-A variations Dsc06026
Landing-gear 1/2-A variations Nose-g10
Landing-gear 1/2-A variations Nose-g11
My "Flying-Blind"
Landing-gear 1/2-A variations 20200317
