randy randolph bee tween build Cox_ba12
randy randolph bee tween build Pixel
randy randolph bee tween build Empty
randy randolph bee tween build Empty randy randolph bee tween build
Post  nico010 Sun Mar 22, 2020 7:14 pm
Hello friends. I will take advantage of the fact that thanks to the quarantine I have time and I will share with you the construction of my bee tween, designed by Randi Randolph.
When I was very young I knew this model thanks to a modeller who had built it from the plan published in MAN magazine.
I had a copy of the plan but I have lost it. Not long ago I had the pleasant surprise of finding the plan on the OUTERZONE page again and do not hesitate a minute to print it.
Firstly, I built one for a friend (the model they will see in red), and I built it just like the plan, with the only exception that no landing gear would be fitted. The model flew extremely well, fulfilling everything said in the article.
The only drawback I had was that due to the control rods that I used for the tail surfaces, I found myself needing to add almost the same weight of the plane, in lead, in order to achieve a correct CG.
With all that lead added, the weight of the model remained at approximately 24 OZ. the model flew with a recycled babe bee. the behavior in flight was outstanding, the stability, the response to the controls and the behavior to handle strong winds are incredible. the glide was good but a little degraded due to excess weight.
Seeing all these positive and negative points, I decided to build another one, with just a couple of modifications:
1) F1 was moved forward to approximately the distance of the wing cord.
2) the controls are made with lighter materials
3) add landing gear
This new model (the white one) ended up weighing 14 oz. it flies much better than the first.
It is powered by a shure start with a fuel tank made from a syringe. With 20cc of fuel I have approximately 7 minutes of running, so the model goes to the stratosphere.
after that .. the glide is eternal ..
without further adieu I'm slowly putting the images I have of the construction and the videos of the flights I have.
I hope you enjoy.
Cheers
nico
nico010
nico010
Bronze Member
Bronze Member
randy randolph bee tween build Empty Re: randy randolph bee tween build
Post  nico010 Sun Mar 22, 2020 8:09 pm
As in all models, start by making a cardboard template of all the pieces to be cut.
then I cut the bulkheads in plywood and the sides of the fuselage in 2mm balsa wood.
randy randolph bee tween build 20190210
randy randolph bee tween build 20190211
to give a bit more rigidity to the structure use the same pieces of wood to make some internal reinforcements, as well as the doubler on the front
randy randolph bee tween build 20190212
with all the cured glue I put the F2 and F3. F1 I leave it for the last.
I have the habit of marking on the fuselage the lines that I then use as a reference to locate servos, take as a reference to align things etc. This is seen in the following images.
after gluing the bulkheads I place the uprights for the servos.
randy randolph bee tween build Img-2057
randy randolph bee tween build Img-2055
randy randolph bee tween build Img-2056
nico010
nico010
Bronze Member
Bronze Member
Post  nico010 Sun Mar 22, 2020 8:20 pm
After that I place the F1 with the holes for the engine, and close the top of the fuselage with balsa wood.
the bottom is the last thing I close after installing and testing the controls rods.
randy randolph bee tween build Img-2058
randy randolph bee tween build Img-2059
the construction of the tail surfaces is quite simple. the only precaution is that according to what I read in various forums, one half of the stabilizer is bigger than the other in the drawing, so I redrew it before putting it together. except this question, the rest is to cut and stick sticks.
randy randolph bee tween build Img-2060
randy randolph bee tween build Img-2061
randy randolph bee tween build Img-2062
it already begins to look like a plane
randy randolph bee tween build Img-2063
nico010
nico010
Bronze Member
Bronze Member
Post  gkamysz Sun Mar 22, 2020 8:28 pm
Great! It was one of my first models. I'm looking at building another myself, but maybe scaled to .020 size.
gkamysz
gkamysz
Post  NEW222 Sun Mar 22, 2020 8:42 pm
Very nice work. Loogs good. What do you plan on covering it with?
Post  nico010 Sun Mar 22, 2020 8:56 pm
all the model is covered with top flite- monokote .
I share a couple of videos of the start-up of the engine and the flight of the plane.
I do not know why it is not seen in hd.
Tomorrow I will continue with the publication of the second plane.
https://www.youtube.com/watch?v=unXZ6aHBLQw
nico010
nico010
Bronze Member
Bronze Member
Post  GallopingGhostler Mon Mar 23, 2020 5:28 am
Very nice work, nico010. The aircraft flies very well and very enjoyable to watch your construction fotos and flight videos.
Post  balogh Mon Mar 23, 2020 6:04 am
Nice build and videos, nico10..make me want to go to the filed and fly my planes..unfortunately following an early spring season of 20+C temperatures, this week winter is back again and as I write this post from my home office, I see the snow falling outside.
By the way, do you plan to swap the Surestart with the Black Widow you won on the T-shirt competition? I would expect a major power upgrade by the Black Widow because it has a SPI cylinder contrary to the non-SPI of the stock Surestarts unless you have changed the cylinder on it.
Post  getback Mon Mar 23, 2020 6:53 am
Thanks for bringing us along on the Build and Flight , enjoyed the pics and the flight was very stable . Looks like a plane you can have fun with for awhile ! Stay safe . RC Plane
Post  akjgardner Mon Mar 23, 2020 7:14 am
Very Nice , I enjoyed Watching the video . RC Plane
Post  nico010 Mon Mar 23, 2020 11:49 am
balogh wrote:Nice build and videos, nico10..make me want to go to the filed and fly my planes..unfortunately following an early spring season of 20+C temperatures, this week winter is back again and as I write this post from my home office, I see the snow falling outside.
Andras
how are you??
At the moment I have no intention of changing the shure start. For the type of flight I intend for the plane is more than enough.
the other day inspecting the piston I saw that it has a small crack in the joint with the connecting rod. more or less I could fix that things with the piston reset tool. Later (when the world situation improves due to the covid-19) I intend to buy a black widow piston and cylinder set on the cox international website and exchange it.
nico010
nico010
Bronze Member
Bronze Member
Post  Mike1484 Mon Mar 23, 2020 12:12 pm
That is a very nice plane and you have done a great job on the building . I always liked that plane and I should build one but I am not a big fan of three channel set ups . Good to see people making the most of this lock down time by building and sharing on this forum .
Mike1484
Mike1484
Mike1484
Post  balogh Mon Mar 23, 2020 12:14 pm
Thanks Nico..that crack you refer to is probably a gap between the socket and balljoint end of the conrod that, once properly reduced to the desired small value with the resetting tool will make your engine good again.
Post  nico010 Mon Mar 23, 2020 6:29 pm
balogh wrote:Thanks Nico..that crack you refer to is probably a gap between the socket and  balljoint end of the conrod that, once properly reduced to the desired small value with the resetting tool will make your engine good again.
no .. unfortunately no. It is cracked. the break in the piston socket is perfectly noticeable.
I have used the piston reset tool to accommodate things a bit. I will use it in this way while it lasts
nico010
nico010
Bronze Member
Bronze Member
Post  nico010 Mon Mar 23, 2020 6:38 pm
Continuing with the bee tweens saga, I pass some photos of the second model.
I remind you that the main modification was the relocation of F1. In the following images you can see the difference between the templates of the first and second models.
randy randolph bee tween build Img-2073
randy randolph bee tween build Img-2075
randy randolph bee tween build Img-2074
internal reinforcements are identical to the first model
randy randolph bee tween build Img-2077
in the last photo you can see the new fuselage with the wing of the first model
nico010
nico010
Bronze Member
Bronze Member
Post  nico010 Mon Mar 23, 2020 6:53 pm
Now ... I leave some photos of the landing gear bending, the construction of the wing is exactly like that of the first model, and some photos of the almost finished model. so far almost nothing new.
randy randolph bee tween build Img-2085
randy randolph bee tween build Img-2084
randy randolph bee tween build Img-2083
randy randolph bee tween build Img-2086
randy randolph bee tween build Img-2087
nico010
nico010
Bronze Member
Bronze Member
Post  nico010 Mon Mar 23, 2020 7:05 pm
now is where it gets interesting. The engine is a set of new and used parts from other engines. I had to make a wooden extension to be able to adjust the engine to F1 and that the air intake does not disturb.
The fuel tank is manufactured by cutting a syringe and installing a pair of pipes for the fuel load and the air inlet, in this way, the outlet of the syringe where the needle is placed comes out from under the fuselage and is directly connected to the engine, without the need to disconnect this line every time you want to load fuel.
randy randolph bee tween build Img-2089
randy randolph bee tween build Img-2088
randy randolph bee tween build Img-2090
randy randolph bee tween build Img-2091
randy randolph bee tween build Img-2093
randy randolph bee tween build Img-2092
As I mentioned before with this fuel tank I have a running time of approx 7 minutes, which is more than enough to have fun in the air
nico010
nico010
Bronze Member
Bronze Member
Post  nico010 Mon Mar 23, 2020 7:13 pm
again the model is coated with monokote, the hinges are also made with monokote and the control rods this time are made with 1mm steel rods that move inside thin nylon tubes.
in this way I managed to reduce the weight of the rear of the plane.
randy randolph bee tween build Img-2094
randy randolph bee tween build Img-2095
randy randolph bee tween build Img-2096
randy randolph bee tween build Img-2097
randy randolph bee tween build Img-2098
randy randolph bee tween build Img-2099
nico010
nico010
Bronze Member
Bronze Member
Post  nico010 Mon Mar 23, 2020 7:30 pm
Unfortunately I don't have any more photos of the model under construction, just a couple of the model finished.randy randolph bee tween build 20200311
randy randolph bee tween build 20200310
randy randolph bee tween build 20200312
Here I want to tell you an interesting story. the second Sunday that the plane flew, after the fuel was consumed and close to landing the plane, the model caught on a thermal current and gained such altitude that I lost sight of it, along with other modelers and after looking for a while upwards we managed to see the plane.
Luckily that story had a happy ending since I did not lose the model.
back at home, place under the wing and the stabilizer a pair of orange monokote strips, to make the model a little more visible.
randy randolph bee tween build Img-2100
I am going to share some videos of the model's flights.
after several flights try to perform some acrobatic maneuvers. the model flies perfectly in inverted, makes some great loops and the maneuvers like rollers go out quite well for being a 2 ch model
nico010
nico010
Bronze Member
Bronze Member
