Painting and covering Cox_ba12
Painting and covering Pixel
Painting and covering Empty
Painting and covering Empty Painting and covering
Post  andrew Wed Mar 18, 2020 5:13 pm
Since there have been recent building threads that involve painting and/or covering, I thought I would list the following link. I freely admit that my ability to visualize different paint schemes and colors is sadly lacking, so the following tool has proven quite useful for me. It is from Aviat Aircraft and allows you to pick different schemes then assign colors as wanted. Hope some of you can find it useful.
https://aviataircraft.com/husky-paint-schemes/
Painting and covering Empty Re: Painting and covering
Post  NEW222 Wed Mar 18, 2020 6:03 pm
Wow. Such nice aircraft. While looking at paint schemes, I noticed teh order form. I had a bit of fun there building one up too. Well over $500,000. Lol. Thanks for both the interesting / helpful, and fun link.
Post  Kim Wed Mar 18, 2020 6:04 pm
Thank you again for that roll of Exam Table Paper! Looks like it's gonna work!!!
Post  OhBee Wed Mar 18, 2020 7:48 pm
Covering....my biggest fear. I have the supplies, but not the desire to ruin all the previous hard work getting this far! Last time I did this was 1966! So far just looking at it and thinking about it!.....what would be wrong with just sheeting a wing in 1/32 balsa? Can't be any heavier than silkspan and several coats of dope! I did that to my Lil Satan in the early 60"s after several nasty crashes led to a major rebuild. It still flew just fine fully sheeted.
OhBee
OhBee
Post  Kim Wed Mar 18, 2020 8:13 pm
OhBee wrote:Covering....my biggest fear. I have the supplies, but not the desire to ruin all the previous hard work getting this far! Last time I did this was 1966!  So far just looking at it and thinking about it!.....what would be wrong with just sheeting a wing in 1/32 balsa? Can't be any heavier than silkspan and several coats of dope! I did that to my Lil Satan in the early 60"s after several nasty crashes led to a major rebuild. It still flew just fine fully sheeted.
Might work, I sheeted a Guillows P-51 back in the day, but that was the last time I can remember.
Post  OhBee Wed Mar 18, 2020 8:19 pm
Ya....I am finding that I am no longer any good at things I used to be really good at!
OhBee
OhBee
Post  Ken Cook Wed Mar 18, 2020 8:40 pm
I feel that sheeting a wing would be heavier than just silkspan.  After all the time it would take to sheet it, you still have to fuel proof it which is adding even further weight. Silkspan doesn't require dope for attachment. White glue thinned with water to milk like consistency, works well. In addition, it can be pulled and smoothed out with your fingers easier than using dope. If it's been 50 years just cover from tip rib to tip rib and treat the wingtips with a separate piece after it's dried. It makes it much easier until your comfortable doing so with one piece. Using a artist brush and just laying down a thin 1/4" wide amount of adhesive is all that's needed. It also prevents dope induced warps in lighter structures. When completed, 2-3 coats to shrink it up and you can use colored tissue for trim
Post  OhBee Wed Mar 18, 2020 9:44 pm
Was thinking of trying it that way Ken...thanks !  ...So you really only use the dope/ glue ,on the leading and trailing edges of the wing? You still dampen the silkspan first correct?
OhBee
OhBee
Post  Kim Wed Mar 18, 2020 10:38 pm
OhBee wrote:Was thinking of trying it that way Ken...thanks !  ...So you really only use the dope/ glue ,on the leading and trailing edges of the wing?  You still dampen the silkspan first correct?
I do it all with clear dope.  Put a coat around the outside perimeter of the wing, and let it dry.  Then sand it smooth.
With this Brave, or Squaw, or Warrior or whatever it is, I cut a panel of covering for each side.  I dip the panel in a cookie dish of water, then blot it on a double-thick strip of paper towels, so it's just damp when I lay it on the frame.
I then carefully go around the outside edge, brushing clear onto it.  As soon as it looks like it's all stuck down, I flip it over and do the other side as quickly as possible.
Painting and covering 6_119
I had REAL good luck with this paper Andrew sent me as it drew up really nice.  I'm gonna brush on lear dope oats with REAL LIGHT sanding in between, until I get a good enough gloss, then mask and shoot some color at it.
Painting and covering Img_1210
Painting and covering Img_1310
Post  OhBee Wed Mar 18, 2020 10:51 pm
By quickly flipping and doing the other side,do you mean the other side of what you just covered...or the same side on the other side of the fuselage? How do you keep from ruining the sde you just did?
OhBee
OhBee
Post  andrew Wed Mar 18, 2020 11:06 pm
Not to step on Kim's explanation, which is exactly the way I apply silkspan, but he meant to cover one side of one wing panel, then flip it over and cover the other side of the same panel.  Apply the silkspan damp by sticking it down around the perimeter (no doping the open areas) then flip and apply.  The silkspan is only damp, not doped all over.  By applying to the other side quickly, the top and bottom will dry and shrink at the same time and rate, but since they're on the same panel, it will be less prone to warp due to uneven shrinkage.
Kim, glad the exam paper is working for you.  I've had good results and it's a damn sight less expensive than the old silkspan.
Post  944_Jim Wed Mar 18, 2020 11:15 pm
Have you guys discovered a grain to the paper? I figure it runs parallel with the length of the roll...not across the roll. At least that is how I've used it.
Post  OhBee Wed Mar 18, 2020 11:21 pm
I was wondering about warpage! .......and which way is the "grain" supposed to run when applying it? I really can't see a grain in it? Looks ramdom to me.
OhBee
OhBee
Post  andrew Wed Mar 18, 2020 11:35 pm
944_Jim wrote:Have you guys discovered a grain to the paper? I figure it runs parallel with the length of the roll...not across the roll. At least that is how I've used it.
I treated it as running lengthwise down the roll.
OhBee:  Normally, the "grain" should run in the longest direction  --  for wings, that will be spanwise (end to end of the panel), not chordwise (front to back).  Silk is applied the same way.  Generally, the greatest shrinkage occurs grain wise.  By applying the grain tip to root on wing panels, it will decrease the amount of sag in the bays (between the ribs).  Although it's not foolproof, take a 2" square and tear it in half with fingers; take another 2" square and do the same, but with the tear at 90 degrees to the first square.  The tear with the straighter edge and fewer fibers extending out runs parallel with the grain; the jagged tear with more fibers runs crosswise to the grain.
Chinese habotai silk shrinks about 8% lengthwise (running down the roll) and 1% in width (running across the roll)
Post  Kim Wed Mar 18, 2020 11:47 pm
andrew wrote:Not to step on Kim's explanation, which is exactly the way I apply silkspan, but he meant to cover one side of one wing panel, then flip it over and cover the other side of the same panel.  Apply the silkspan damp by sticking it down around the perimeter (no doping the open areas) then flip and apply.  The silkspan is only damp, not doped all over.  By applying to the other side quickly, the top and bottom will dry and shrink at the same time and rate, but since they're on the same panel, it will be less prone to warp due to uneven shrinkage.
Yeah, I got some foam blocks that I use as an airplane holder (I'm a shameless dumpster diver!)
Painting and covering 6_812
Post  Kim Wed Mar 18, 2020 11:54 pm
I looked for a grain, but couldn't detect any, tearing some test pieces in different directions. So far, it's drawing down nicely, but it's stuck to the Warrior, so we'll see. Gonna do that tear test again...in the morning!
Post  Levent Suberk Thu Mar 19, 2020 1:58 am
How to determine the grain:
With thinner papers it is harder to tell the grain direction, heavier papers are more obvious and easier to determine.
Three quick tests to check for grain direction:
1) Tear Test – Take a sheet of paper and tear it horizontally and then vertically. One tear should have been straighter than the other. The tear that was straighter is parallel to the grain, the jagged tear is going across the grain.
2) Bend Test – Take a sheet of paper, bend the paper (don’t fold or crease it) horizontally and vertically. There will be less resistance in one direction than the other. The bend with less resistance is parallel to the grain.
3) Fingernail Test – Take a sheet of paper and using the fingernails of your thumb and middle finger pinch the paper and slide them across and then down the paper. One direction should produce a “wave”, the wave indicates that you went across the grain.
(Excerpt from https://printingpartners.wordpress.com/2013/06/06/paper-grain-direction/)
Post  944_Jim Thu Mar 19, 2020 4:09 am
Then there is the ink blot, or water drop test. A round drop nof think liquid is dropped square on the paper so the creep can be observed. The fluid will creap along the paper most parallel to the grain, which is how I tested the DocSpan. There was an increase of creep (by just a bit more) lengthwise on the roll.
So, between the barely observable tear test, and drop of fluid test, I determined it to go long. That's how I've been using it.
So I guess there is a concensus in that assumption.
Post  Levent Suberk Thu Mar 19, 2020 5:57 am
Thanks for the tip. I tried it. Ink spread more along the paper grain and less across the grain. Better than any other grain test.
Post  Kim Thu Mar 19, 2020 7:33 am
Great info guys!   Gonna do these checks once my morning coffee is gone.  Gonna gamble on the Warrior's covering being OK...we'll see how this goes!
Post  Mike1484 Thu Mar 19, 2020 9:20 am
That is some super great info on the grain of paper , Thanks guys . Learn something new every day . I new about the tear test but the others are new to me . I bet this paper would really be a strong covering if it was applied over some 1/3 mil mylar . Good to see some building going on .
Mike1484
Mike1484
Mike1484
Post  getback Thu Mar 19, 2020 9:28 am
lot of good info / thats easy to forget if not applied often , i have never used thinned glue to ste the silk But i also used full strength dope on the models i did back when i was covering More . St.Pats Beers
Post  OhBee Thu Mar 19, 2020 2:15 pm
Do you lay the damp silkspan over the framework first ,THEN apply the dope on the edges? Or dope the edges first then try to get it applied correctly before the dope drys?
OhBee
OhBee
Post  Ken Cook Thu Mar 19, 2020 3:03 pm
First, insure you have enough dope on the framework. This is generally 3-4 coats. Don't even sand the first coat, sand the second coat and don't spend a lot of time sanding. Using very fine sand paper, slightly radius the tops and bottoms of your ribs. If the center section is sheeted, radius the edge of the sheeting facing the open bay.  This way, when you apply dampened silkspan and it shrinks, the covering runs a lesser chance of splitting on the rib or sheeting. Kim has mentioned the most important step in doping which is look for the wood to shine.
          I prefer to lay the dampened silkspan onto the doped framework and brush through it with thinned dope. But, I only do this on the leading, trailing edges and tips. If the center section of the wing is sheeted, I pull the silkspan back and quickly brush the thinned dope onto the sheeting and lay the paper back and squeegee out the dope. In my earlier years, I would always have some slight bubbling which isn't always a easy fix. This insures that over solid sheeting the covering is fully attached.
             Once the covering is applied and your ready for first coat of dope brush in this manner. With the brush full, start ON the  trailing edge and brush in the same direction of the ribs up to the leading edge. When the bays are first coated, brush your leading and trailing edge out and DON't puddle dope at the intersection of the fuse to wing joint. This can cause blistering of the dope in the fillet of the fuse which doesn't generally appear until later as the gasses escape causing the covering and or dope to blister. When completed, I like to make passes over all of the rib tops with one more brush stroke of dope. The rib tops are the first to sand through so you can't apply enough dope there.
      Second coat, you can brush the opposing direction from fuse out to tip. The reason I like to brush from trailing edge is due to puddling the dope. When you brush first coat in this manner, your forcing dope through the silkspan and it puddles underneath the covering along the rib.Brushing with the rib on first coat prevents this which seals and the second coat can progress. This can cause the covering to also pull down which you don't want or it can show through the finish appearing like a run in the paint.
Post  Kim Thu Mar 19, 2020 3:15 pm
I dope the perimeter with full-strength clear, let it dry (you should feel an almost "gritty" texture as the balsa fibers have been petrified with the dope), and sand it smooth with some worn-out sandpaper.
I lay the damp panel on the frame, and dope it's edges with 50-50 clear/thinner.  This is where I'm gonna do good or mess up---you can't just swipe the brush along the edge 'cause the paper will wrinkle or come loose.  I do some "strategic outward dabbing" to try to get it tacked down evenly, then hit it all the way around, brushing outward.
I had GREAT luck with this exam paper (knock on wood), and got it all to lay down pretty nicely.
Once dry, I start brushing on coats of Brodak Clear (AKA "Liquid Gold") 'till I get a shine I like or get enough of the whole deal and break out the paint gun.  The longer you wait between coats, the better, but my aged irritability often wins out over my desire to be seen as a craftsman.  Though, I got to admit, I REALLY like this part, as the paper starts making the plane look "airplaney".....
Forgot to mention, but you already know---the frame's ribs and anything the paper is gonna touch need to be sanded as smooth as possible before any of this happens.
