Damage on TD 049 crankcase Cox_ba12
Damage on TD 049 crankcase Pixel
by batjac Today at 10:05 pm
by gkamysz Today at 9:29 pm
by roddie Today at 9:22 pm
Damage on TD 049 crankcase Empty
Damage on TD 049 crankcase Empty Damage on TD 049 crankcase
Post  Dave P. Tue Feb 18, 2020 7:38 pm
Anybody ever seen this?
Damage on TD 049 crankcase Img_2088
Damage on TD 049 crankcase Img_2089
I recently acquired this thin wall TD.  The compression is pretty good and it doesn't appear to have been disassembled or if it was the guy knew how.  The curious thing is that the bottom of the rod appears to be undamaged.  The inside of the crankcase definitely has been scored.  Maybe a chip left from machining did this?  Or was it over-reved?
Dave P.
Dave P.
Damage on TD 049 crankcase Empty Re: Damage on TD 049 crankcase
Post  dckrsn Tue Feb 18, 2020 8:10 pm
I've seen that, Dave. There was a thread about it
a while ago, but I don't remember enough to find it.
The bulge was attributed to dull cutters used for
milling inside the case for lower rod end clearance.
I seem to remember someone seeing it on a brand
new  engine.
Nice looking old TeeDee. I see the oil hole on the crank
end of the piston rod. I'm guessing a thin wall cylinder?
Post  Cribbs74 Tue Feb 18, 2020 9:26 pm
What Bob said, poor tools and an early piston.
Post  balogh Wed Feb 19, 2020 12:50 am
I also remember seeing that bulge of a shade only on one of my TD-s crankcase but not being too protruding, I did not attribute too much of significance to it. Main operational stresses in the crankcase material are expected to arise parallel to the bulge and not perpendicular to it -as a longitudinal crack once let it be seen at the backplate below- so I think there is no reason to worry about it.
Damage on TD 049 crankcase 20200216
