Ringmaster Juniorish Cox_ba12
Ringmaster Juniorish Pixel
Ringmaster Juniorish Empty
Ringmaster Juniorish Empty Ringmaster Juniorish
Post  ian1954 Mon Sep 23, 2019 7:04 pm
Another build. The weather here is wet and windy again - so no flying and no engine running (S.W.T.S.M.B.O. won't let me run engines indoors!)
This time it will be a variant on the Ringmaster Jr. When finished, it should look like one but the construction will be different - both wing and fuselage.
I am very please with the take apart wing on the Ringmaster I am building and, although I am not planning on this being a take apart (more a build apart) - I like the principle of being able to completely finish the fuselage and wing before assembly.
Also, like ticomareado, I don't like trying to slide a wing through a profile hole and I prefer a laminated fuselage.
Another weak spot on these profile thingies is the fin. It is not integral with the fuselage and usually had to be cut in two parts for the grain direction. I have used slots, tooth picks ........... the make the glue joint to the fuselage stronger but it gets fiddly to get the fin in perfect alignment.
So on this the fin will be part of the central core of the fuselage and lite ply.
I have cut out the core and the central rib and am ready to use the core as a template for the laminations.
Ringmaster Juniorish Ringma20
ian1954
ian1954
Ringmaster Juniorish Empty Re: Ringmaster Juniorish
Post  Ken Cook Mon Sep 23, 2019 7:47 pm
I will tell you with experience a Ringmaster flying without a rudder makes absolutely no difference whatsoever. I take mine off flying inverted all the time. While you mentioned it's not as strong, it's sacrificial in my case. I will glue it back on for the Ringmaster Fly-Athon.
Post  ian1954 Tue Sep 24, 2019 7:05 pm
More "take apart" work with the core and the centre rib,
I cut out the lower fuselage piece first which was a mistake as I needed to get the rib central before I cut out the upper slot. So I had to tape it back together.
Ringmaster Juniorish Ringma21
I added the ribs that support the central sheeting to the centre rib.
Ringmaster Juniorish Ringma22
Ringmaster Juniorish Ringma23
Luckily, I got everything to line up.
Ringmaster Juniorish Ringma24
ian1954
ian1954
Post  Ken Cook Tue Sep 24, 2019 7:41 pm
Ian, one thing I found with all Rings are that the nose breaks off very easily. While I admire your take apart effort, they usually take themselves apart. While this is a scratch build, the stock Rings never offered enough doubler material and it stopped directly behind the leading edge. Being a take apart now, it looks like you have A lot of motor mount area and no support holding it together. I'm not a electric flyer and this appears to be nitro power, even though it's small, the top motor mount appears to extend very far back and the bottom has very little behind it now.
Post  ian1954 Wed Sep 25, 2019 6:59 pm
Ken, you are perfectly correct. This is what it would look like with an OS 15
Ringmaster Juniorish Ringma25
I definitely wouldn't be comfortable with this but that will not be the power plant. It will be and OS motor - OMA-3810-1050 - and that won't fit between the bearers. I will show the mounting when I have finished it.
Here it is ready to take the mounting,
Ringmaster Juniorish Ringma26
I was a lttle concerned after cutting out the wing hole and removing the wing bottom from the fuselage how narrow the upper spin was. However, because of the plywood core epoxied between balsa - it is incredibly strong. It will take some force to break it.
I keep looking for weak points have seen so many of these slab things break aound the wing area - front and back.
One of he strongest slabs I have seen is constructed with the engine bearers running the entire length of the fuselage with the wing inbetween the bearers.
ian1954
ian1954
Post  ian1954 Thu Sep 26, 2019 4:34 pm
It was time to set the centre rib today. Luckily, on this wing the spars were a nice press fit so I could assemble it without any glue.
I made sure that the rib was square to the spars in both axes.
Ringmaster Juniorish Ringma27
Ringmaster Juniorish Ringma28
Then inserted the wing in the fuselage for a double check against the fuselage.
Ringmaster Juniorish Ringma29
Ringmaster Juniorish Ringma30
Ringmaster Juniorish Ringma31
Then the dodgy bit. I tacked it with thin CA very carefully or I could have glue the wing in place prematurely.
Quick visual and then the wing back to the bench to complete the build.
Ringmaster Juniorish Ringma32
ian1954
ian1954
Post  Cribbs74 Thu Sep 26, 2019 9:10 pm
It’s looking nice and straight, can wait to see it finished! Any ides as to how much the electric gear weighs?
Post  getback Fri Sep 27, 2019 7:21 am
Looking good Ian ! Cool
Post  NEW222 Fri Sep 27, 2019 9:14 am
Agreed. Looking great!
Post  ian1954 Sat Sep 28, 2019 6:15 am
The engine mount, 4 layers of 3 ply laminated , now just needs the corners rounding off.
Ringmaster Juniorish Motor_11
This will be mounted using gussets at the back and front, top and bottom.
ian1954
ian1954
Post  ian1954 Sat Sep 28, 2019 6:52 am
The motor weighs 5.4 oz
Ringmaster Juniorish Os_38111
but with the ESC and timer - that gets pushed up to 7.5 oz compared to 6 oz for an OS 15
Ringmaster Juniorish Os_mot10
On Ron's hotel build of the Junior Ringmaster - i noticed concern over the weight of the engine and the model ending up nose heavy. On this I am clueless.
The motor is about 3/16" further back than the plan shows the IC engine and the ESC and timer will be mounted behind the motor.
The real killer is the battery. The battery projected for this weighs 6 oz but that can be shunted backwards and forwards to assist with the C of G. The battery projection is from one of the calculators and based on a 9x6 propeller.
The other thing to bear in mind is that the fuselage is 1/2 oz heavier that plan because of the ply core and epoxy for the lamination. The fin is also ply and so there will be a rearward shift with this. Who knows!
I also remebered Ron forgetting to put in any tip weight. On this I will miss out the tip weight. The propeller is a pusher and so will spin clockwise.
Nothing ventured, nothing gained.
ian1954
ian1954
Post  ian1954 Sat Sep 28, 2019 6:54 am
The wings are ready for a final sand and a trial fit.
Ringmaster Juniorish Ringma33
ian1954
ian1954
Post  Ken Cook Sat Sep 28, 2019 7:44 am
Ian, I have never seen Eric Rule's Junion up close. The standard Ring Junior by Sterling was not all that favorable. The problem lies with the wing loading. The lighter engines like a OK .14 and a Fox .15 suited these models. The Fox had more power than the OK but it weighed a touch more. The Junior Ring like almost EVERY Sterling profile is designed nose heavy. The Junior's wingspan was too narrow and too thin therefore the engine you show in the picture is oz's heavier. ANY modern .15 on a Junior is a very bad choice. It will fly fast in level flight but it will not perform throughout the maneuvers well. When the power cuts it lands like a meteor.
In theory as I'm quite certain others have used would be a Cox .09 Medallion or TD. The lightweight and power available would be quite beneficial. I had a K&B Torp.09 on one but it had to fly on shorter lines than I preferred but it did fly it quite well. Adding tail weight as I discovered on the Junior didn't make too much difference. While it assisted the turn, it certainly didn't benefit in the glide. I even went as far to extend the fuse a additional 2" and also made a brass tail wheel. It's a fun plane to fly unfortunately it's not the same as it's big brother. The electric on the nose could be a big game changer here as the powerband is consistent throughout. I never flew electric nor have a desire. Almost all of are club members are switching over. Bob Hunt flew his newest electric Sweet Sweep at our vintage combat last weekend and I will say it was incredibly impressive. I would certainly like to hear back on your results using electric on this plane. I truly feel it's a solution to a old design. Ken
Post  ian1954 Sat Sep 28, 2019 8:42 am
Thanks Ken. I don't expect miracles from my builds but it does help to be aware of potential problems.
I have not yet seen electric c\l combat models but have a couple of park flyer flying wings. They are foamies and fly well in mild weather but ......... eat propellers. You can get IC enginesto stop with the propeller horizontal but the elctric motor allows the propeller to turn. The elctric propellers I use are quite brittle and break easily. I wonder how those on a combat model fare on landing.
Combat flying is brutal on models and the results of a punctured battery is not something you want to see at close quarters,
I keep putting off building one of these because of the prop issue.
https://www.stevensaero.com/product/scram-control-line-combat-model/
I do think though that it would be an ideal candidate for a Bee.
ian1954
ian1954
Post  Ken Cook Sat Sep 28, 2019 10:05 am
Ian, funny you showed the video in regards to the battery. Bob Hunt had 3 people with him to assist him in flying. The one fellow William built a beautiful plane. If you've ever seen the Teosaki, this looked like a smaller version as it had a geodetic wing. It had a oversize motor and battery. Our vintage combat has changed a bit as the guys who build them don't want to fly them in a combat match. I do, but that's me. They have one event to see how fast you can fly and another where you fly the PAMPA stunt pattern as fast as you can. William was flying for speed and the plane got way ahead of him. Over the top and into the ground resulting in a fire and a meltdown. I'm thinking in my mind there goes several hundred up in smoke.
Post  roddie Sat Sep 28, 2019 2:29 pm
Hi Ian, It will be exciting for me, to witness the maiden-flight of this/your model. You may or may not know that I have an original kit-built Sterling S5 Junior Ringmaster that's been "ARF" status for decades.
Ringmaster Juniorish 7-14-112
I have a few glow-engines that would be well-suited to fly the airplane.. but I also have parts for an electrickery-installation at my disposal.. (less a timer)..
Post  dirk gently Sun Sep 29, 2019 4:48 am
I'm not sure this is supposed to be a vote, but in case it is, I vote glow.
dirk gently
dirk gently
Post  aspeed Sun Sep 29, 2019 7:42 am
Myself I would go glow.  Top Fuel for me.  Having said that, a pistol car transmitter with a leckie might be interesting for a local park where no one would notice you or grumble.  I think an OS .10 or TD .09 would be ideal on .012" 52 ft. lines.  I don't have a Ringmaster but will go out and maybe fly someones next week. I seem to be a pilot [bleep].  I was watching a normal size Ringmaster fly and it seemed quite a good flyer.  The tail was lengthened and elevator enlarged. Anyway, it looks like this one should be ready for next weekend? (edit) The weight would be a wash with the .15. There would be a bit extra weight with the tank to bring the total up to maybe the same. Then again there is the firewall with the blind nuts which might be offset if the nose is shortened if needed for balance.
aspeed
aspeed
Post  ian1954 Thu Oct 03, 2019 3:39 am
No glow chaps. Don't want to invoke the noise police and want to fly this locally.
Seeing Roddies Ringmaster Jr reminded me of Ken's recommendation to use ceconite/koverall for cloth hinges. I really like the strengthe and longevity of cloth hinges and the speed of fitting but they are not pretty,
Ringmaster Juniorish Hinges10
No matter how neatly you apply them, they stand proud and are not disguised by finishing.
Ringmaster Juniorish Hinges11
I should have ironed those before applying them!
So for the Junior, I tried Ken's recommendation. I had to take 6 photos and keep changing amgles before I could show them!
Ringmaster Juniorish Hinges12
They were applied using dope and cut using a raser blade. They are strong.
ian1954
ian1954
Post  Ken Cook Thu Oct 03, 2019 3:45 am
They work great, look great. The Koverall also accepts paint without making them bind and get stiff.
Post  ian1954 Sun Oct 06, 2019 9:23 am
A one week gap and back to it.
I glued the tail plane on and it was easy to line up as the plywood fin is integral to the fuselage. I spent quite a while assembling the electrickery , drilling the mounting holes, bending the undercarriage and making the reinforcing gussets for the motor mount.
Ringmaster Juniorish Ringma34
Ringmaster Juniorish Ringma35
Ringmaster Juniorish Ringma36
After looking at the model and realising there was a distinct nose heaviness, I put balsa either side of the fin mow ready for sanding. This actually mad quite a difference to the C of G and brought it to only slightly nose heavy.
Ringmaster Juniorish Ringma37
I think it will look better but not sure where the C of G will end up after finishing.
Having the wing removable has definitely made wing fitting easier and more precise.
Ringmaster Juniorish Ringma38
Ringmaster Juniorish Ringma39
The bottom fuselage piece is now permenantly glued on and there is a good fit at the top of the wing. I will cover the wing before finalising that joint but it will only be a few swipes of sandpaper.
I used an RC pushrod for the elevator.
Ringmaster Juniorish Ringma40
and here is the wing being pulled off
Ringmaster Juniorish Ringma41
Ringmaster Juniorish Ringma42
Ringmaster Juniorish Ringma43
A nice tight fit and now the wing is ready for covering
Ringmaster Juniorish Ringma44
ian1954
ian1954
Post  ian1954 Mon Oct 07, 2019 5:57 am
Engine mount now gussetted
Ringmaster Juniorish Gusset10
Fin shaping started
Ringmaster Juniorish Fin10
ian1954
ian1954
Post  rsv1cox Mon Oct 07, 2019 6:45 am
Progressing nicely Ian.  I like your new hinge system, big improvement over cloth which I used for years.  But I tend to stick with pin hinges, I love the freedom of movement but they have to be added after everything else is completed or they get contaminated.
After cleaning the castor goo off two Ringmaster Jrs. yesterday and removing and cleaning the engines I can appreciate the convenience of electric.
The "Happy number" - Bob
Post  getback Mon Oct 07, 2019 7:41 am
She is looking good Ian !! Want bee long now till in the air . Very Happy
Post  ian1954 Tue Dec 31, 2019 8:54 am
After getting sidetracked on numerous other projects finally finished it
Ringmaster Juniorish Ringma45
No longer take apart but glued together after painting.
ian1954
ian1954
