Cox cylinder Cox_ba12
Cox cylinder Pixel
by roddie Today at 8:58 pm
Cox cylinder Empty
Cox cylinder
Cox cylinder Empty Cox cylinder
Post  crankbndr Sun Jan 22, 2012 6:49 am
I was wondering what engines this cylinder came on. Cant find out much about it. Its a sub-induction cylinder, 2 bypass with 1 boost per bypass and the top exhaust port
is smaller then the bottom. It has a 1 on it.
Cox cylinder Img_0714
Cox cylinder Empty Re: Cox cylinder
Post  Cribbs74 Sun Jan 22, 2012 7:01 am
Wikipedia site says black widow pre '96 and Medallion. Yours has slits though..... Huh...
Post  nitroairplane Sun Jan 22, 2012 7:02 am
Well it is a late number 1 cylinder.
not sure what it came on as it is not mentioned on the table.
http://en.wikipedia.org/wiki/Cox_model_engine#Cylinders
nitroairplane
nitroairplane
Post  crankbndr Sun Jan 22, 2012 7:09 am
The way the piston fits it seems to be tapered, but not sure.
Post  Cribbs74 Sun Jan 22, 2012 7:12 am
crankbndr wrote:The way the piston fits it seems to be tapered, but not sure.
I guess slit exhausts are a later post '96 type thing. Tapered fits are usually found on the TD no?
Post  Cribbs74 Sun Jan 22, 2012 7:21 am
Upon further review, apart from the numbering it has all the attributes of a '96 killer bee to include the taper grind.
Post  Admin Sun Jan 22, 2012 1:16 pm
It sounds and looks like you have a Killer Bee cylinder. It is tapered? A Killer Bee cylinder is a 2 bypass, 1 boost port on each bypass, top fin milled, has SPI, has tapered grind. I have no idea why it has a #1 on it. I have seen a mix of different numbers stamped on slit cylinders and post Estes cylinders (you may have a post Estes cylinder).
https://sites.google.com/site/coxenginecollection/choosing-a-cylinder
Cox cylinder -1412
My Killer Bee .049 Cylinder
Post  RknRusty Sun Jan 22, 2012 7:54 pm
Unless there are some very early slit cylinders I don't know about, a slit cylinder doesn't "have" SPI. It's only the piston skirt height that makes the set SPI, not the cylinder. In other words, if a slit cylinder set has a non-SPI piston, it's non SPI. If the same cylinder has an SPI piston, then it is SPI. Maybe some early slit sets were made with lower exhaust ports, but they wouldn't work well with a short piston from the newer SPI sets.
Post  crankbndr Mon Jan 23, 2012 6:10 am
Here is another oddity I found in my stack of stuff, piston with swirls in the top. Came on a Black Widow.
Cox cylinder Img_0715
Cox cylinder Img_0716
Cox cylinder Empty swirls
Post  Jaspur_x Mon Jan 23, 2012 6:16 am
That piston is interesting,I never got 1 of those yet.
Jaspur_x
Jaspur_x
Banned
Post  dckrsn Mon Jan 23, 2012 6:38 am
That's one for the books. I too have never seen one of those. I'm still not sure
I've seen one.
Bob bounce
Post  PV Pilot Mon Jan 23, 2012 7:11 am
Time travel piston.
PV Pilot
PV Pilot
High Tech Balsa Basher
Post  Godsey3.0 Mon Jan 23, 2012 7:40 am
That is weird. I have seen something like that somewhere. It was a long time ago (for me at least). Around the time I got my first engine and was researching how to use it.
Godsey3.0
Godsey3.0
Post  Admin Mon Jan 23, 2012 8:08 am
crankbndr wrote:Here is another oddity I found in my stack of stuff, piston with swirls in the top. Came on a Black Widow.
Can you take a picture of the inside of the piston, that design is commonly seen on lightened pistons. Did it come with that cylinder? My friend used my killer bee cylinder and piston with his black widow for his winter comps, worked well but he somewhat messed up my set.
Post  Jason_WI Mon Jan 23, 2012 8:10 am
Looks like the Whirlpool galaxy. Very Happy
Jason_WI
Jason_WI
Post  crankbndr Mon Jan 23, 2012 8:13 am
Sure will, it came on a new Black Widow with plastic backplate with that cylinder.
Post  nitroairplane Mon Jan 23, 2012 12:20 pm
I believe some venoms had that but it is usually much less pronounced.
nitroairplane
nitroairplane
