Starter springs and Throttle rings Cox_ba12
Starter springs and Throttle rings Pixel
Starter springs and Throttle rings Empty
Starter springs and Throttle rings Empty Starter springs and Throttle rings
Post  Cribbs74 Fri Jan 20, 2012 3:05 pm
Received all my parts from Matt,Bernie and John Goddard so I can build my Texaco engine. Problem is I cannot install the no drag starter spring under the throttle ring. When I tighten the cylinder down,the throttle ring hits the spring and won't allow the throttle ring to rotate.
Has anyone else experienced this? If so what was the fix?
I am thinking about grinding down the spring wire to reduce the diameter allowing it to fit under the throttle ring.
Starter springs and Throttle rings Empty Re: Starter springs and Throttle rings
Post  nitroairplane Fri Jan 20, 2012 3:06 pm
Yeah ther is not "real" fix for this I have found.
nitroairplane
nitroairplane
Post  Cribbs74 Fri Jan 20, 2012 3:11 pm
nitroairplane wrote:Yeah ther is not "real" fix for this I have found.
So I guess I need to start grinding then!
Post  nitroairplane Fri Jan 20, 2012 3:19 pm
Yes unless you want to wait for others opinions as they may have some suggestions.
nitroairplane
nitroairplane
Post  Surfer_kris Fri Jan 20, 2012 3:29 pm
Some mufflers come with a spacer that one can put below the cylinder. There are also timing shims that one can use to raise the cylinder a little. Grinding the spring works too...
Surfer_kris
Surfer_kris
Post  Cribbs74 Fri Jan 20, 2012 3:36 pm
Ok, grinding works well. Just skimmed a little off the diameter of the wire. Works good and is not even noticeable. Thanks guys!
Post  balogh Sat Jan 21, 2012 11:51 am
cribbs74 wrote:Ok, grinding works well. Just skimmed a little off the diameter of the wire. Works good and is not even noticeable. Thanks guys!
Had the same experience but rather than thinning the spring I decided to grind the bottom of the throttle drum...a few runs on a fine sandpaper flattened on the table did the right job.
Starter springs and Throttle rings Empty same for peewee020
Post  Jaspur_x Sat Jan 21, 2012 7:56 pm
I had the same with my peewee020,so I shaved down the throttle ring with my dremel,all is well now lol!
Jaspur_x
Jaspur_x
Banned
Post  Cribbs74 Sat Jan 21, 2012 8:00 pm
I guess it could work both ways, I just figured the spring was cheaper.
Post  microflitedude Sat Jan 21, 2012 8:03 pm
Jaspur_x wrote:I had the same with my peewee020,so I shaved down the throttle ring with my dremel,all is well now lol!
THANK YOU! Very Happy
microflitedude
microflitedude
Post  nitroairplane Sun Jan 22, 2012 4:49 am
cribbs74 wrote:I guess it could work both ways, I just figured the spring was cheaper.
Yeah if you messed up the spring an new one is cheap but the ring would cost more.
nitroairplane
nitroairplane
Post  WingingIt74 Sun Jan 22, 2012 8:59 am
Why not just leave the starter spring off?
WingingIt74
WingingIt74
Post  Cribbs74 Sun Jan 22, 2012 10:16 am
It was a thought. I run my Tee Dee's that way. I never used to use starter springs but, since I started I find the engines fire off much quicker and usually run in the right direction.
Post  PV Pilot Tue Mar 27, 2012 6:36 pm
Since this is a really cool titled thread, thought i would put this here.
Did cox or estes cox or ? make a left hand no drag starter spring for a 049.
Just the spring, to be used with a round drive washer, no plastic hex driver piece.
PV Pilot
PV Pilot
High Tech Balsa Basher
Post  WingingIt74 Tue Mar 27, 2012 6:47 pm
Yes, look at my Odd Ball thread.
http://coxengineforum.forumakers.com/t1970-odd-ball-engine
WingingIt74
WingingIt74
Post  EXModelEngines Tue Mar 27, 2012 7:00 pm
We typically grind them down if a customer requests it to work with a starter spring!
Regards, Matt
EXModelEngines
EXModelEngines
Official Cox Dealer
http://www.exmodelengines.com
Post  Cribbs74 Tue Mar 27, 2012 8:28 pm
EXModelEngines wrote:We typically grind them down if a customer requests it to work with a starter spring!
Regards, Matt
Guess I should have asked then. lol!
Post  PV Pilot Wed Mar 28, 2012 11:41 am
So basically for a Left hand no drag spring. Take a #334 kit, toss the plastic drive hex piece, twist and hammer the spring until you get it where you want it.
yes? no?
PV Pilot
PV Pilot
Post  EXModelEngines Wed Mar 28, 2012 3:50 pm
Regards, Matt
Always next time lol!
Matt
EXModelEngines
EXModelEngines
Official Cox Dealer
