Pretty in pink Cox_ba12
Pretty in pink Pixel
by batjac Today at 10:05 pm
by gkamysz Today at 9:29 pm
by roddie Today at 9:22 pm
Pretty in pink Empty
Pretty in pink
Pretty in pink Empty Pretty in pink
Post  jsesere Thu Jan 19, 2012 10:14 pm
Pretty in pink Pink_010
jsesere
jsesere
Pretty in pink Empty Re: Pretty in pink
Post  RknRusty Thu Jan 19, 2012 10:21 pm
Whad you do, wash it with your shop rags?
That's what happened to my Mechanix Gloves the other day. lol!
Seriously, that's a beautiful engine. The backplate looks brand new. What piston/cylinder is it?
Post  jsesere Thu Jan 19, 2012 10:30 pm
It has a 2 bypass, no boost cylinder. I'm not sure if this series came that way or not. Most Golden's I have seen were single bypass. Mark B. may know and answer if he sees this post.
jsesere
jsesere
Post  Mark Boesen Thu Jan 19, 2012 10:59 pm
Hi Joe,
Nice, but you need to get rid of that later cylinder, compare these photos to yours.
Pretty in pink Golden10
Pretty in pink Img_0610
Post  jsesere Thu Jan 19, 2012 11:12 pm
Mark I have a couple of these with and without a throttle ring.
Pretty in pink 049_0011
jsesere
jsesere
Post  Mark Boesen Thu Jan 19, 2012 11:17 pm
no, the stepped cylinder is from the early seventies, you need a early babe bee single port cylinder. Thats pretty neat you have one still in package, nice collectable.
Post  jsesere Fri Jan 20, 2012 12:14 pm
Mark, can you post a picture of the rear of the back plate?
Joe
jsesere
jsesere
Post  Mark Boesen Fri Jan 20, 2012 10:20 pm
It should look like one of these, only with no vent tubes.Pretty in pink 00914
Post  Admin Sat Jan 21, 2012 12:24 am
oh yes, Mark is right! You need to swap that cylinder! Either dig in your parts for a thin #2 (may not have a # on it) single bypass, SPI cylinder or post a wanted ad on here for one or buy a vintage Babe Bee from eBay and jack the cylinder or buy this http://www.ebay.com/itm/COX-049-WEN-MAC-OK-CUB-AIRPLANE-ENGINE-HUGE-PARTS-LOT-PROPS-TANKS-PUMP-TOOLS-/190628118782 and just take the thin cylinder off that crankcase in the back and sell off all the parts. There's a seat for you dune buggy! You'll probably make money, glow head clips sell for $5+, thin neck crankcase assemblies sell for $5+ ea. and so on.
https://sites.google.com/site/coxenginecollection/choosing-a-cylinder
Post  jsesere Thu Jan 26, 2012 12:38 am
Mark, is this any better?
Pretty in pink Pink_011
jsesere
jsesere
Post  Admin Thu Jan 26, 2012 1:18 am
jsesere wrote:Mark, is this any better?
That looks much better!
Post  jsesere Thu Jan 26, 2012 1:23 am
It has the same back plate as the one Mark has. So ths is now correct?
jsesere
jsesere
Post  Mudhen Thu Jan 26, 2012 7:23 am
Mudhen
Mudhen
Post  jsesere Thu Jan 26, 2012 11:41 am
Would this be the correct glow head?
Pretty in pink 302-1_10
Pretty in pink 302-1_11
jsesere
jsesere
Post  John Goddard Thu Jan 26, 2012 1:36 pm
I can't see through that pack very clearly Joe but on mine which I think is the same as we are talking about
the first two fins on the glow are the same diameter the third is slightly smaller and the top is as
usual ie smallest.
J
Wink
PS if you look closely at Marks first shot you can see that.
John Goddard
John Goddard
Post  PV Pilot Thu Jan 26, 2012 1:39 pm
I think Mark B's side by side photo up above shows the correct head fin style.
PV Pilot
PV Pilot
High Tech Balsa Basher
Post  jsesere Thu Jan 26, 2012 4:31 pm
I copied the following from Warrens Wkipedia Cox page
1.#302 Pre 1955 Standard Head - Hemispherical shape - Low Compression - Smaller dia. threads - used on Space Bug, Thermal Hopper, Space Bug Jnr and Strato Bug Only.[21]
2.#302-1 Post 1955 Standard Head - Hemispherical shape - Low Compression - Larger dia. threads - used on all engines produced post 1955 until the #325 head was produced in 1979.[22]
3.#325 Standard Head - Hemispherical shape - Low Compression - Larger dia. threads - used on all post 1956 engines except Tee Dees, QZ, Killer Bees, Venom and Texaco. Replaced 302-1 head in 1979.
I was hoping Mark, Matt or Bernie would be able to clarify.
jsesere
jsesere
Post  fit90 Thu Jan 26, 2012 6:25 pm
How about the spinner. I thought the "pink" Golden Bees had the earlier spinner that does not have the flange type base. The engine looks really clean. Very nice regardless of what you do with it.
fit90
fit90
Post  jsesere Thu Jan 26, 2012 6:43 pm
Thanks. I found the proper spinner in my parts bin and will add it latter today. I'm almost there with the restoration.
jsesere
jsesere
Post  Mudhen Thu Jan 26, 2012 6:46 pm
Mudhen
Mudhen
Post  Mark Boesen Thu Jan 26, 2012 11:09 pm
fit90 wrote:How about the spinner. I thought the "pink" Golden Bees had the earlier spinner that does not have the flange type base. The engine looks really clean. Very nice regardless of what you do with it.
Good call Bob, I missed that, lol!
Post  Admin Thu Jan 26, 2012 11:57 pm
Yep, mine has one! You can get a reproduction one here> http://www.ebay.com/itm/COX-ENGINE-049-SPACE-HOPPER-O-R-049-SPINNER-/280811852071
Post  Cribbs74 Fri Jan 27, 2012 8:14 am
That is a nice one you got there! Looks better than mine, prob more collectable too! Oh well I only paid 8 bucks for mine Very Happy
Just kidding, seriously that is a nice engine. Have you run it yet?
Post  jsesere Fri Jan 27, 2012 9:51 am
I have to wait for better weather to run it. I think I have a line on a period glowhead.
jsesere
jsesere
Post  jsesere Mon Jan 30, 2012 8:09 pm
I believe it's correct now.
Pretty in pink Pink_012
jsesere
jsesere
