» Retail price mark-up.. how much is enough?by Ken Cook Today at 2:54 pm
by Ken Cook Today at 2:45 pm
by Admin Today at 12:34 pm
by getback Today at 12:30 pm
by 1/2A Nut Today at 10:34 am
by sosam117 Today at 8:15 am
by balogh Today at 7:42 am
Making a Starter for Cox Engines
I made this simple starter for small engines. I used a Mabuchi 540 motor of an old drill. It comes with a gear on shaft. A wheel collar also works instead of the gear. I mounted a piece of 5/16 inch inner diameter hard rubber hose on gear. I tied hose with wire and twisted wire ends. A piece of heat shrink tubing encloses the wire on hose. I epoxied a push button on side of motor can, then soldered terminals on motor connector and push button to change the battery when required. 2S 1000 mAh Li-Po battery supplies power. I wrapped the motor and battery with electrical tape.
【 ! 】 Engine piston must be at BDC so momentum help to carry piston through TDC.
【 ! 】 A drop of oil between drive plate and crankcase is needed to prevent wear. Using brass drive plate is recommended.
Levent Suberk- Diamond Member
Re: Making a Starter for Cox Engines
I like the way the batt. and motor are self contained but , i believe when the motor heats up the epoxy will give away ? I hope not ,, keep us up to date please .
getback wrote:I like the way the batt. and motor are self contained but , i believe when the motor heats up the epoxy will give away ? I hope not ,, keep us up to date please .
Thanks for comment. Motor don't heat too much because works several seconds.
Spinner became loose and propeller, spinner and screw sprung everywhere so I want to add:
【 ! 】 Propeller screw need to be tight to avoid loosing spinner.
Power is good enough to carry piston through TDC at full charge, so no need to position piston at BDC.
No heat on motor any.
Awesome! Quite an innovative idea! I applaud you and if you don't mind .... I'd like to "steal" your idea and make one for myself!!
modelbuilder49- Gold Member
The DC 540 motors are easy to source from old power tools of brand new from e-bay rather cheap
A single 8.4DC 3000mAhr NIMH RC car battery is more than enough and can be found well under $10 bucks these days
hint#1-- with a DC motor one can reverse the +/- leads and start a left hand crank engine
hint#2 ----make damned sure the engine is NOT flooded... bent crank for sure
Levent Suberk....good job I like it
Thanks for comments. I inspired this from:
https://www.coxengineforum.com/t11772-experimental-reed-valve-test-5-5-18
="fredvon4".....
hint#2 ----make damned sure the engine is NOT flooded... bent crank ....
For smaller engines I only bump up the starter speed a little then release the starter button before pressing the starter cone to the engine spinner so it is only the starter rotor inertia that will drive the engine crankshaft, with no electric power...thus chances of a bent conrod are reduced. I have a relatively small starter though..
I know mentioned in Roddies red neck thread...but this is a good one to bump up too
» Making TD 0.020 Snap Starter Spring
» Cox engines - Trying to make sense of non-sense - Picture heavy
» Making a Simple Tool for Cox Engines
» Making a Cox pusher?
