Cox Tee Dee 0.10
Cox Tee Dee 0.10
Can anyone help me. I'm looking for throtle for Cox Tee Dee 0.10 which is on YouTube under the name 862mx.Link as a new user I can not paste yet
Hujsek- Moderate Poster
Re: Cox Tee Dee 0.10
Like this?
simple air choke using the existing NV
Or do you mean this mass of brass bolts and nuts:
Down fall too heavy and bulky.
Low weight option you can make a sleeve type exhaust throttle
AmpAbuser / 1/2A Nut
Published on Feb 1, 2016
Cox TD.010 with throttle sleeve
20% nitro and oil / Static Max 28,082 rpm.
Best reads 11.7k idle
Cox .010 prop modified
That is. I thought of the throttle from video No.1
The first one is just a cold-start choke...
The exhaust throttles are usually a better option.
I know but I'm still looking for a throttle from the first video
That was hand made you would have to fabricate one from a small block of aluminum.
Currently there is no RC carb on the market for the TD .010 and .020 perhaps soon
there is a design Greg had drawn up the TD .010 is so small a air choke throttle would
allow easy transformation by the end user. The throttle sleeve type would require grinding
off or filing down the cylinder flange in order to slide on the throttle sleeve.
I know that there are no factory carburettors for these engines, so I am trying to find the one who made the carburettor from the first video through this forum. Maybe I can negotiate to create one for me.
I bought Cox .049 Sure Start Throttle Conversion to install it on Tee Dee. I cut the plastic tube, but it's still too big for this engine. So I'm looking for the option to buy a smaller cold -start choke.
I wonder when watching video 1, if it is a piece that is attached to the original venturi, or is it a whole piece that includes the thread that screws in the crankcase?
MauricioB- Top Poster
MauricioB wrote:I wonder when watching video 1, if it is a piece that is attached to the original venturi, or is it a whole piece that includes the thread that screws in the crankcase?
I have a feeling that it is attached to the original venturi tube, although it is also possible that it is done with a new thread. In any case, the fuel supply is under the hood.
Hujsek wrote:MauricioB wrote:I wonder when watching video 1, if it is a piece that is attached to the original venturi, or is it a whole piece that includes the thread that screws in the crankcase?
Yes, I agree, the fuel supply is the original, it is below the air strangulation.
If the air strangulation is up and independent of the original venturi, it is possible that the venturi itself has been modified to make it fit into the upper part, so that this square block can not move to the original venturi, it can also that there is a pair of very small screws below that fit the original venturi.
There is not much space, practically nothing to put a joint tube, would intercede in the propeller.
It is likely that at some point I will try something here!
I wrote to the author of the video, but he did not answer me yet
I do not think a venturi tube appears on the top of the manufactured trottle. So I would say that the original venturi tube is under the flap, because the air intake for the fuel is very small, but I do not know how it is mounted on the original tube. We are waiting for the author's response .
Greg can make these easy enough.
1/2A Nut wrote:Greg can make these easy enough.
Great friend ... and ... what Greg thinks?
I won't run out of things to dream up. However, designing them to be cost effective to produce, let alone in a price range that makes sense is what's tricky. It seems some people are OK with just a choke type throttle and this may work. Others want to see air bleed or metering carbs. I'm working on the .020 design and if it works shouldn't be difficult to translate to .010. However, this is still some time out.
Greg
Greg
gkamysz- Gold Member
Awesome! I have seen a lot of interest in .010 throttles over the years on all the related forums I dabble with. There is definitely a market there, to efficiently throttle the smallest Cox TD seems to be a dream for many.
Tee Bee- Platinum Member
gkamysz wrote:I won't run out of things to dream up. However, designing them to be cost effective to produce, let alone in a price range that makes sense is what's tricky. It seems some people are OK with just a choke type throttle and this may work. Others want to see air bleed or metering carbs. I'm working on the .020 design and if it works shouldn't be difficult to translate to .010. However, this is still some time out.
Greg
If Greg, I understand you perfectly, we are many and at the same time we are few, that is, to manufacture in series we are few, to meet and unite passions, we are many and everything leads us to evaluate if something is possible to make it happen.
That is why in different parts of the world ideas and creations appear, each one trying to achieve its mission.
I am interested in the .010 driver, since, to make a ring, you have to work on the cylinder or make the extra extra. In contrast to the .020, as there are different types of cylinders, it is possible to solve the problem with a ring and finished matter, anyway, if you carry out a development, I believe that for those of us here we will be safe candidates.
Thank you for your dedication, we love this line of hobby, we are surely very hopeful in its development. Thanks again.
I have now ordered a new Venturi tube. I will install the flap according to Greg's drawing and put it to made it on a CNC machine, then I will solder on a venturi tube and I hope it will work
Hujsek wrote:I have now ordered a new Venturi tube. I will install the flap according to Greg's drawing and put it to made it on a CNC machine, then I will solder on a venturi tube and I hope it will work
It will be interesting to see your work and results, I wish you good luck !! ...
MauricioB wrote:Hujsek wrote:MauricioB wrote:I wonder when watching video 1, if it is a piece that is attached to the original venturi, or is it a whole piece that includes the thread that screws in the crankcase?
Did the author of the recording already answer?
Hujsek wrote:MauricioB wrote:Hujsek wrote:MauricioB wrote:I wonder when watching video 1, if it is a piece that is attached to the original venturi, or is it a whole piece that includes the thread that screws in the crankcase?
No, I have not received an answer ....
The tape flap is finished and installed. It's over the venturi. I did not have time to try the flaphow it works. I apologize for the bad images because they are made with the phone
Why do not images remain in the publication ??????
Must have not been posted correctly.
Hello, I could see the photos from copying the link and place it in the browser, inside the forum (in my case) I can not see them.
Good job, friend, I'm waiting for a video of your creation!
